Hello, first of all sorry for another help topic. I hope one day I will contribute to this forum.
2 years ago I bought a $9 cheap green laser that can light matches. But I did not know about batteries back then. So I bought a random Samsung battery which turns out to be Samsung 26F.
I have learned that it is 5A battery. So I do not know what would happen if I put a high ampere battery into that laser.
In flashlights, if the light has FET or enough 7135s. It can handle a lot of power (LEDs capability is not discussed). But how about lasers? They use 7135? I am almost sure that cheap laser does not have fet but maybe it has another thing to handle high ampere.
So, how does high ampere cells work with hand held pointers/lasers?
Basically, the only thing you have to worry about is voltage in the first place. If the laser pointer (or any other electronic device) uses a single standard power/drain 18650, then it does not matter whether you use 26F or 30Q, as the (effective) voltage is the same. So it should be no problem.
I’m not into electronics, but my guess is no. The reason is that usually the laser’s output is fixed, for example 5mW. The device will be demanding a certain power from the cell to generate this output, therefore it should not matter whether you use a high drain cell or not. I think the principle is the same regarding the Skilhunt H03 (another question you asked). I replied that max output does not matter whether you use 30Q or NCR18650B.
Hi…i am a new user here. As per my knowledge you should check voltage in the first place. If the laser pointer uses a single standard power/drain 18650, then it does not matter whether you use 26F or 30Q, as the voltage is the same.
with those illegal 2-4W 445nm blue laser weapons it matters which battery you have
especiqally as blue laser diodes have a relative high forward volatge
high power >500mW 532nm DPSS lasers have a 2-3W 808nm pump diode which need only 2.8-3V so the voltage sag of the battery does not matter
with more current the voltage sag of 30Q is a lot less than for 26F
for those <100mW lasers the battery does not matter as the power the driver needs is very low
