Here’s the final piece of the carbon fibre square concept set, it has a Cree XP-G3 centre emitter on DTP MCPCB and four 3mm red emitters operated by a mercury tilt switch at around 30° so depending on which way the light is held, tilted or rotated they will be active or not. This mode is mostly used with the XP-G3 on moonlight level.
Powered by a 16340 or cr123 cell with reverse clicky switch 3 modes and ARC glass this mule is cool
Now that you’re out of carbon fiber, I’m wondering if you would consider making a larger light sometime. You are the sultan of small , the monarch of the minuscule, the duke of the diminutive, but I think you can and should go bigger occasionally.
Hey, I have made a couple of 18650 lights , but you’re right enough about larger lights, I just don’t have much use for anything bigger than pocket carry or small lights dotted around the house. One day I’ll surprize y’all with a huge build
