Test/review of Efest LUSH Q2 Charger 2017
3 posts / 0 new
HKJ
HKJ's picture
Last seen: 15 min 49 sec ago
DSC_0178
DSC_0179DSC_0180
This is a simple dual cell mains powered LiIon charger without any settings.
DSC_0140 DSC_0141 DSC_0142 DSC_0143
It arrived in a small cardboard box with specifications on it.
DSC_0173
The box included the charger, a usb cable, a warranty card and the instruction sheet.
DSC_0181
The charger has a mains socket for power and is universal power (100-240VAC 50/60Hz).
DSC_0571
The only user interface is a led light for each channel, white when charging and blue when finished.
DSC_0182
Specifications are on the bottom, but not very easy to read.
DSC_0184DSC_0185
The slots uses the classical slider construction and it works fine.
The slots can work from 27.5 mm to 70mm. This means that it will handle most 18650/26650 batteries, except the longest ones.
supportedBatteryTypes
supportedBatterySizesDSC_0509DSC_0510DSC_0511DSC_0512DSC_0513
The charger can handle 70 mm long batteries including flat top cells.
The charger current is on the high side for regular small cells, but close to acceptable for IMR batteries
Measurements
  • When not connected to power it will discharges with about 8mA.
  • When power is connected with a full battery, the charger will discharge with 0.05mA
  • Below 0.55V the charger will not detect a battery
  • Between 0.55V and 2.75V the charger will charge with about 170mA to 200mA
  • Above 2.75V the charger will use regular charging.
  • When one cell is full, the other will be charged with the full current.
  • Charger will restart when voltage drops slightly.
  • It will restart charging on reinsertion of the battery or power cycling.
  • Power consumptions when idle without battery is 0.17 watt
Efest%20%20Lush%20Q2%20%28SA18650-33%29%20%231
The charger has a nice CC/CV voltage curve with termination around 100mA.
With one battery the charge current is about 2A.
Efest%20%20Lush%20Q2%20%28SA18650-33%29%20%232
The second slot is the same.
Efest%20%20Lush%20Q2%20%28SA18650-26%29%20%231
Nice charge curve and termination.
Efest%20%20Lush%20Q2%20%28PA18650-31%29%20%231
This cell has enough voltage drop for the charging to restart, but only at a slow frequency.
Efest%20%20Lush%20Q2%20%28BE18650-26%29%20%231
With a older battery the charger stops, but restart again when the voltage drops, i.e. the termination do not work very well.
Efest%20%20Lush%20Q2%20%282xSA18650-33%29
With two batteries the current will be reduced to 1A.
Temp4493
M1: 47,0°C, M2: 51,1°C, HS1: 77,5°C
Temp4494
M1: 48,0°C, HS1: 62,3°C
Efest%20%20Lush%20Q2%20load%20voltage%20sweep
Sweeping the battery voltage from zero to 4.25 shows charge current at the different charge levels.
I did also add a curve to show how much heat is generated in the charger, most of the time the voltage will be between 3.5V and 4V, i.e. a bit above 4 watt.
Poweron1
The charger is very fast at starting.
Poweron2
Also with two batteries.
Conclusion
The charger uses a rather high current and it has problems terminating with old batteries.
I will rate it fairly good for IMR batteries, but only acceptable for other LiIon batteries, due to the termination.
Notes
The charger was supplied by Efest for review.
Edited by: HKJ on 08/08/2017 - 01:48
will34
will34's picture
Last seen: 4 hours 32 sec ago
Thanks once again for the review!
Nice charger for high drain cells.
rizky_p
rizky_p's picture
Last seen: 1 day 13 hours ago
Just went through Efest website and found this charger and looking around for review what a coincident. thanks for the review.
