High - 2.6A, Med - 0.7A, low 0.15A. (it does not go above 2.6A no matter with which good battery (Sanyo/Panasonic/Xtar/Solarforce) or which voltage level between 4.1V to 4.2V, very stable)
Throw = 17k from the OP reflector. (DX meter - 17k is corrected figure)
It has square threads.
Tint is 1A so that's really cool white, but i am cool with that.
Best thing - Not PWM driven. Immeasurable on the DMM, and also on the fan on both med/low there is none of those "pattern". Even on a fast 4kHz PWM you can detect the pattern on the fan on high speed easily.
Quality is good old Shadow quality, ie very near to Fenix. Cutting could be a bit sharper to give you that "punch" look of the premium lights but i am ok with this.
The hotspot is somewhat smaller than the regular U80/C8 lights. Need to do whip out the meter when it's dark.
Wow...the UI is very similar to Balder. On high it will blink once after 3 seconds. Switch it off immediately and the blinky modes will be gone (SOS/Strobe). Do the same to return to blinky mode.
That's the Kingfire big head http://www.cnqualitygoods.com/goods.php?id=1311 But the cutting and anodising is a wee bit rough.....more like Ultrafire/Trustfire level than Shadow level. Just part of the collection man....i mean you don't check out your lights at 30cm distance. I like the looks.
Put it this way, Shadow is like Solarforce. The anodising is so smooth....and i have yet to get chipped edges on the Shadow TC6. It might not be HA though, but it does not chip and you get ugly exposed aluminum.
I have the JM07 Pro coming, suppose to be even better. Hope it will surpass Fenix level.
Thats a very attractive light. Much better looking than the stock photos we were all looking at a few weeks ago. Its always cool to see a company with descent CNC equipment put their mills to good use in producing such intricate creations. Did you also receive the "fat" battery yet? I wonder if the smaller hotspot means greater throw from that size reflector.
Yeah well, "show lights" is what I'm talking about. I ask because I've been having second thoughts about different colored boots. The GITD boots don't stay glowing long enough to matter so, it's an aesthetics thing and I'm begining to think it's a green-pea thing that goes away the longer I'm into flashlights.
This site might just be my new favorite. Very few lights there that I don't like but that Xin TD is going to be my next purchase. I like that you can choose between 3 and 5 mode and that screw-in pill - very nice. I want the 3 mode with the SS bezel.
