Luxeon V
16 posts / 0 new
djozz
djozz's picture
Last seen: 4 hours 21 min ago
Luxeon V
It is a long time since Lumileds released an interesting emitter for flashlight use, but the new Luxeon V looks really promising:
*single chip
*4×4mm, but what looks to be a XP footprint (!)
*4800 mA maximum drive current, at which current 1700 lumen is produced (!)
*0.8 degC/W thermal resistance (!!! Shocked )
I would not mind testing one on a DTP-board Smile
Link to Lumileds page
Datasheet
link to djozz tests
“I used to think that top environmental problems were biodiversity loss, ecosystem collapse and climate change. I thought that thirty years of good science could address these problems. I was wrong. The top environmental problems are selfishness, greed and apathy, and to deal with these we need a cultural and spiritual transformation. And we scientists don’t know how to do that.”   (Gus Speth)
Edited by: djozz on 08/09/2017 - 18:41
AlexGT
AlexGT's picture
Last seen: 7 hours 48 sec ago
Weird that they didn’t change the nomenclature for this chip since the 2005
Jensen567
Last seen: 2 months 23 hours ago
2.84Vf typical is a good sign that this is a new generation low Vf emitter. Hopefully someone starts carrying these.
Lexel
Lexel's picture
Last seen: 14 hours 39 min ago
interesting LEDs
they would work with 4S LEDs at 3S Battery in DD
or a decent 1S Buck driver
Lightbringer
Lightbringer's picture
Last seen: 4 hours 38 min ago
Lexel wrote:
interesting LEDs
My F13s would love these…
alphazeta
alphazeta's picture
Last seen: 1 month 4 days ago
“…4800 mA maximum drive current…” -> that’s only on paper so wow, that is pretty interesting. I’m interested in seeing how hard it can be driven…
Ford Prefect
Ford Prefect's picture
Last seen: 3 months 5 days ago
Very interesting emitter. Hadn’t even thought about luxeons for years.
Thx for the link.
rizky_p
rizky_p's picture
Last seen: 15 hours 4 min ago
lol i thought you are revering to the old Luxeon V the naming is odd right? should have called it Luxeon V.II or something. Still have my old Luxeon III on 2AA and and Luxeon V on 2xICR123 which i never used now.
MRsDNF
MRsDNF's picture
Last seen: 2 hours 29 min ago
djozz wrote:
I would not mind testing one on a DTP-board.
I wouldn’t mind reading your test results. Smile
My current and or voltage measurements are only relevent to anything that I measure.
Budget light hobby proudly sponsored by my Mastercard and unknowingly paid for by a hard working wife.
djozz said "it came with chinese lettering that is chinese to me".
battery
More fodder for the D4?
Texlite
Last seen: 10 months 3 weeks ago
Weird indeed.
Cool find djozz.
JaredM
JaredM's picture
Last seen: 18 hours 24 min ago
Very interesting!
I'm thinking it's not going to perform up to it's potential on an XP footprint. First off, it'll be tricky getting it reflowed and not shorting. (If carefully centered it should work fine.) The XP thermal pad is only 60% as wide as the Luxeon. So I'm curious how much that'll diminish its performance.
For a package that is ~33% larger than the XP, it's rated wattage is only about 20% greater than the XHP35. Efficacy is similar to a typical top binned HD at 85*C. If that exceptionally low thermal resistance is to be believed then there should be major overdriving capabilities here. My guess is peak output at ~12A. This maybe the closest thing we will see to an 'XM-L3'. Though, on that topic, the XP-L2 and XHP-50.2 kinda cover those bases well enough already.
But considering it's likely not a good dedome candidate, and that the rated-wattage-window efficacy and peak output are so similar to an XHP35 HD, AND that the new footprint requires new DTP boards, I don't see this LED becoming very impactful UNLESS there are some Nichia rivaling HiCRI versions offered. Right now I see it as a better XP-L2 or 3V XHP35 HD.
djozz
djozz's picture
The Luxeon V solder pad area (3.5 × 3.85) is closer to XP than the Oslons, so at first thought I do not expect performance problems from that.
link to djozz tests
The_Driver
The_Driver's picture
Last seen: 9 hours 40 min ago
It seems nice at first, but it all depends on the die size! If it’s XP-G2 sized, then it’s very good. If it’s XM-l2/XP-L sized, then it’s not very good. According to your test the Luminus SST-40 is around 200 lumens brighter at 5A.
The thermal resistance is very good though which makes me wonder. So it should at least become very bright at extreme currents.
djozz
djozz's picture
The Luxeon V has the specifications to be a great performer but our tests will tell how it performs in our weird way of abusing it Smile
I have not seen it for sale yet, once it is there I’d love to test it!
link to djozz tests
TBone
Last seen: 30 min 42 sec ago
The story continues here…
