Jensen567's Entry for the 5th Annual Old Lumens Scratch Build Contest - Machine Made Category
55 posts / 0 new
Jensen567
Last seen: 1 year 4 months ago
Hi all,
This will serve as my build thread for this year’s 5th Annual Old Lumens Scratch Build Contest. I am entering the machine made category. This will be my first ever scratch built light. I have done plenty of mods and made parts in the past but have never made a full light, so I am excited to see how this goes.
Not entirely sure what I will be building yet, but I do know some basics, in that I want to build what I see as “the future” of mass produced lights, which incorporate things that I want to see become standard in the flashlight world from makers like Convoy, Lumintop, Jaxman, Thorfire, etc. Specifically, I want to design a light that is based around a 21700 battery with a driver size of 22mm. I also want to use modern low Vf emitters with good tint and high CRI, and a driver that maintains regulation through the entire discharge of the cell, and is PWM free.
On the driver front, some of you may recognize me as the guy who has been reverse engineering the Kaidomain boost drivers, and has also started the design process for my own boost driver. I would love to use my own custom driver, but I am not sure the MP3431 Boost IC will be available yet, so a heavily modified H2-C may have to be a stand in. But be sure I will at least document all of my modifications and use some custom firmware so others can follow suit.
Currently my two main ideas are to build scaled up versions of my favorite 18650 lights, being the Convoy M1 and Jaxman E2L. Still tossing around ideas though.
Jensen567
08-10-2017: First cuts being made for the 21700 battery tube
08-11-2017: First pass at a model for the head.
Jensen567
Reserved
Jensen567
Reserved
lostheplot
lostheplot's picture
Last seen: 2 months 4 days ago
Great cant wait to see what you build
sorry all images down
thanks photobucket
CRX
CRX's picture
Last seen: 48 min 24 sec ago
Thumbs Up
Barkuti
Barkuti's picture
Last seen: 1 day 1 hour ago
Wassup Jensen567?
Pretty sure this is going to be a nicely regulated flashlight. Wink
H2-C driver? Are you planning in some triple XHP35 setup?
A little question, by the way. I really like the Jaxman E2L but, is there any chance to fit an H1-A in its driver boot?
Regards,
Salvador Party
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
Localized AliExpress links mess up with the language setting of whoever clicks or taps on them. While this is a fault of the AliExpress system, turning localized links into global links helps and is easy; just change the locale letters in the url for www. Example:
https://es.aliexpress.com/item/bla-bla-bla.html turns into https://www.aliexpress.com/item/bla-bla-bla.html. Thumbs Up
Jensen567
Yep, pretty sure the E2L driver pocket is basically the same as the Convoy C8, M1, M2, so if the pocket is bored out a bit combined with filing down the driver edges to the vias, it should barely fit under the stock retaining ring. I plan to do this exact mod myself whenever my extra drivers arrive to play with.
No triple XHP35, well, maybe, nothing is totally ruled out yet.
Mostly I want to use H2-C because I want a 22mm driver pocket, as I feel 22mm should be the standard for 21700 lights when they start being produced.
Technically the H2-C MP3428 IC supports higher power output on paper too, but the thermal design of that PCB probably limits it to about the same as the H1-A TPS61088 driver in real world usage. I plan to investigate modifying the H2-C to reduce the output voltage though, as it should drive 6V and 9V setups no problem as well with the right feedback resistors.
DavidEF
DavidEF's picture
Last seen: 4 days 12 hours ago
Welcome to the party! Party
- The YKK Philosophy
Jensen567
Thanks! Taking my first cuts. I’m just going to start with the 21700 tube light because I’m almost positive I can get that done in time, if it goes quicker than expected I’ll try the scaled up M1 as well.
EDIT: Sorry if I format this all wrong, but I am going to start putting all the pictures in the reserved posts only after this one.
MRsDNF
MRsDNF's picture
Last seen: 2 hours 54 min ago
Looking forward to the build Jensen. Beer
FmC
FmC's picture
Last seen: 6 months 3 days ago
Good luck with your build – looks like you have got out to an early start!
Jensen567
Really all I have done so far turn the outer diameter of the battery tube to see how it looks, I like it so far. Unfortunately the x-axis on the lathe DRO has gone whacky, so I’m back to using the knobs and measuring manually.
I’m also drawing some parts in solidworks and looking around Kaidomain for lenses, reflectors and switches. I’m considering a few different optics too.
Anyone know where I can buy a Samsung INR21700-30T? I realized I don’t even have a 21700 battery to check the tube sizing.
MascaratumB
MascaratumB's picture
Last seen: 1 hour 53 min ago
Maybe you can HKJ about where to get the battery! Wink He did a review of those: http://budgetlightforum.com/node/53534 .
Good luck with the build!
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 / PT18pro / PT28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior / OW Mini // ON THE ROAD: M1 / i3 / M3 Pro / 311 / Z821 / i5 // ROVYVON: A2 + A5R / E300S / A8 / A23 / E200u // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 / E12R / E61 // XTAR: PB2 Charger // Mods: 1 / 2 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review’s Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
Jensen567
Been awhile since I updated this. Ordered some tools from China almost 2 months ago, and they finally came in last week. So had a chance to do a bit more work.
As of now, plans have changed, I decided a tube light on this scale just wouldn’t look right with the Khatod quad optics I want to use, so instead it will have a slightly larger head and tailcap than battery tube.
Speaking of battery tube, I finally figured out how to thread on my lathe, so the tube is done! Final dimensions are 25.4mm OD, 21.5mm ID, 75mm long. Threads are a weird mix of metric and inch since I couldn’t get the metric pitches to work right. Its a 25mm major diameter, 22.9mm minor diameter, and 18 threads/inch.
Next I will probably try to get the tailcap machined, and will see how internal threading goes. Now, on to the pics
One side threads about done, first time cutting threads on this lathe.
Shaved to length and threaded the other side, as you can see a 21700 fits nicely.
Sandblasted to clean it off, and because I just like the finish that way.
MRsDNF
MRsDNF's picture
Its good to see an update Jensen. The threads look real neat. I’m liking the sand blasted look but maybe would of not done the threads.
FmC
FmC's picture
Good to see more progress Thumbs Up
Any progress is good progress, unless small assistants are involved, then it may not actually be progress.
Jensen567
I thought about that, but I plan to do a bit of hand finishing with a triangle file, then use some nice Teflon grease so it should be OK.
Jensen567
Had a little bit of time today so I made the copper insert for the light engine and started the head. Cut my first internal threads on any lathe ever, and they actually work!
Right now the plan is to have the head be mostly aluminum, then have a press fit copper insert that holds the MCPCB and driver so I can solder the driver in rather than having to make a retaining ring setup. Not sure my tooling could even do threads fine enough for that. On to the pics!
Boring out the driver pocket
Emitter side
Driver pocket
My first ever internal threads. It fits!
MRsDNF
MRsDNF's picture
Nice work on the threads Jensen. Thumbs Up
CRX
CRX's picture
Looks good Thumbs Up
Jensen567
Quick update for this morning’s progress. Machined out the front of the head and pressed in the copper insert. It has a 0.01mm ish interference fit, and if I had thought ahead some I would have frozen the copper and heated the aluminum, because holy cap was it tough to get in there. I actually bent the handle on my vice beating it with a hammer. But it’s in, and it won’t be going anywhere. If I were to do it again I would just press a copper slug into the aluminum tube, then do the driver and emitter pockets, and the head threads after, was nervous about messing up my previous work, but it worked out.
Once it was in I made a quick pass with the boring bar to clean up the scuffs and open the hole up enough so the optics can drop in. For the first time I think I can actually see this maybe becoming a flashlight.
Copper insert pressed in, look at those score marks! Thing won’t be moving anywhere, plus thermal and electrical contact won’t be an issue.
Cleaned up and optics dropped in, now I just need to cut the head down to length and figure out the bezel. And of course give it some style. Starting to be able to picture it as a light though!
Jensen567
Lots more progress today. Head is done! Just need to fill it with the electronics. The bezel ended up being deeper than I wanted, which means the optics sit pretty far back from the face (about 3.5mm), but on the plus side it should be more resistant to something breaking the lens.
I’m getting really excited now, it actually looks like a flashlight, and seems like everything should fit well. All I have left is to build the tailcap and switch.
Bezel made and the top of the head threaded. Fitment of everything is good, should hold the MCPCB to the head nicely for thermal transfer. I lost a bunch of pictures between these and the next one.
Completed head! I shaved the outside down to 27mm, and shortened up the bezel as much as I could, then added the grooves. Grooves are mostly just for looks, not deep enough to make a huge impact on heat transfer. Finally I sandblasted it all aside from the bezel threads, and screwed the tube on. Really excited to see this thing light up.
Jensen567
I also did start the tailcap by making the brass insert ring I will solder the driver to. I figured I would employ a classic Old-Lumens method, and make something out of plumbing hardware, so an extra fitting from my bathtub install was used as the material.
Switch is a nice beefy Omten PBS-101 on a 20.5mm board. Bonus of having the larger diameter cell is you can easily use the larger Omten switches. I was originally going to go with a 22mm PCB, but I found this assembly so went with it.
MtnDon
MtnDon's picture
Last seen: 21 min 50 sec ago
Coming along, looking good!
MRsDNF
MRsDNF's picture
What Don said. Looks like you are going to finish in plenty of time. Thumbs Up
FmC
FmC's picture
Yep, coming along fast! You’ll be sitting down having a drink by the time I get mine done. Party
Jensen567
Well I sort of made the decision to just say forget all the plans and drawings, I’m just gonna build the thing and solve the problems as they come. As a result I’ve spent a lot more time actually making the light and less trying to figure out how I can make it perfect. Along the way I’ve learned a lot, and could probably make a second one much nicer.
I’m hoping to have it done by the end of this week or early next week, then I’m going to enjoy the heck out of it because it’ll have lots of run time and beautiful tint. Plus I may have the only light designed specifically for a 21700 right now.
lostheplot
looking good
thanks photobucket
Jensen567
Little bit more progress today. Got the tailcap mostly done, all the internal geometry is cut and the threads are cut. I spun the outside down to size to match the head.
Hoping tomorrow I can finish up the outside profile on the back, as it is a little bit long, and I want it to tailstand, so I need to recess the switch boot. After that I just need to make the switch washer and put the brass insert into it. Then the host will be complete!
Making some chips. The inside is already done at this point, just taking down the OD.
Can see how much extra material I left on the back. That small hole on the bottom is what the switch boot goes through.
Jensen567
Light is done! Really happy with it, a nice 4000k color temperature, guessing around 2000 lumens, beautiful beam from the khatod 10 degree quad optic and RMMs quad board, and lots of runtime from that almost 5Ah 21700 cell. The host doesn’t look half bad either. Lots more details with the pics.
Finished up the machining on the tailcap first. Some grooves to match the head and give it a little style. Sand blasted finish of course.
Tailcap assembled. Brass ring was a very tight fit, but not interference fit like the insert in the head, so I used a center punch to peen it into the tailcap around the edges. Won’t be going anywhere. After that it is a standard tailcap assembly, boot, washer, switch. Then soldered in place. Measured it at about 5 milli-ohms at 10A with the big Omten.
Now to take care of the driver. I used a heavily modified H2-C from kaidomain. First I removed the reverse input protection FETs on the bottom and bridged them with lots of copper braid and solder. Should help with heat from the IC too. I have covered this more in my thread on buck and boost converters here.
http://budgetlightforum.com/node/54900
After that I changed the spring for a convoy spring and bypassed it with solder braid. I also replaced the short wire off the inductor from 24ga to 20ga, and replaced the output wires with nice short 20ga as well. That was the easy stuff. Next, using the schematic I posted (also in the driver thread above), and the MP3428 datasheet I did some resistor mods to change a bunch of parameters.
Once the inductor is off we can see the circuit. The purple circle is the current sense resistor, stock is 2XR100 in parallel, giving about 1.5A on high. I replaced these with an R025, R075, and R500 in parallel to give me about an R018, which I measured at 4A on high. In the green circle we have the high side FB resistor (R1 in my schematic) for setting the output voltage. Stock the driver is setup to run an XHP35, but to help efficiency I wanted to run 2P2S emitters so I needed a 6 volt type output. I swapped the 200k resistor for an 82k, giving me about 7.5V OCV, which is decent for 2S emitters. Finally, in the blue circle is the high side resistor for the battery voltage divider (R11 in my schematic), this is used for driver LVP. Stock is setup to reduce current and eventually cut out at 3.0V, I wanted to get a lower cutoff, so I stacked a 130k resistor on top of the stock 33k resistor to give me a 26.3k resistor for a roughly 2.7V cutoff. Put it all back together and it worked great. 4A on turbo to the emitters, after 60 seconds it starts dropping to about 2.8A over another 60 seconds. Low mode is about 20mA to the emitters, nice and low.
Next up was emitters, since it was a quad I would need 4, and Nichia is my go-to, after using the 90 CRI Nichias, nothing else seems good enough. I used one of RMMs MTN Quad boards which I slightly modified. It is setup for Carclo quad optics, the khatod has the same emitter spacing, but the standoffs are further out, so I turned the optic leg holes into slots, the khatod optics hit the edge of the board to press it to the head once the bezel is tight. Since i am a fan of tint mixing and Vf mixing with boost drivers, I decided to go with 4 separate emitters, and get as much red as I could at 4000k. I went with a 219B SW45k R9080 in parallel with a 219B SW40 R9080, then those were in series with a 219C SM4070e and a 219C SM353 in parallel. The net tint is about 4000k, with a nice rosy hue. The reason I decided to stick the two pairs of emitters in parallel is so that I should be able to keep running if any 2 emitters fail.
Finally time to assemble the head. First I dropped the driver in, perfect fit, and soldered it around the entire ring. Next up was the emitters, some AS5 thermal paste for the MCPCB, solder the driver wires, then just stack on the khatod optics, Kaidomain AR lens, and screw down the bezel. Now there is just one thing left, screw the parts together, pop in a battery, and turn it on. And….
It works perfectly first press of the button!
