Parts For a Triple LED Flashlight Build
17 posts / 0 new
Northwoods
Last seen: 1 week 6 hours ago
Looking for suggestions for a triple led flashlight. Looking to buy from Mt electronics.
So far I picked the host, JAXMAN E2L Triple LED Flashlight Host
Looking for suggestions on a 20mm led, 17mm driver , the lense and 18650 battery. Thanks in advance!
sp5it
sp5it's picture
Last seen: 2 hours 21 min ago
Fet driver, no doubt and 30Q cell.
Mike
When you’re born you get a ticket to the freak show. When you’re born in America, you get a front-row seat.
Northwoods
Any particular fet driver?
sp5it
sp5it's picture
Northwoods
Not finding it.
Firelight2
Firelight2's picture
Last seen: 35 min 31 sec ago
I suggest the H17F driver from Mountain Electronics.
Not cheap, but in my opinion it’s the best clicky driver available. It pretty much has everything: Temp sensor, double-click shortcut, all modes fully programmable, multiple 7135 chips plus a FET. I consider it to be much superior to the BLF A6 driver.
Northwoods
Led recommend? Lense? Seems to need a lense if domed?
Firelight2
Most common type of reflector for these triples is the Carclo 10507 (also available from Mountain Electronics).
You don’t need to purchase a separate lens to go on top of the optic. The Jaxman E2L host from Mountain Electronics comes with one.
For LEDs, the following will all work with the 10507 optic:
XPL HI – produces high lumens and the brightest hotspot.
XPG2 – similar beam pattern to XPL HI, but less bright.
XPG3 – Slightly brighter than XPG2 and dimmer than XPL HI. Gets hot fast.
Nichia 219C – gets very hot very fast. Very wide floody beam with much less throw than XPL HI. Can be purchased in high CRI
XPL2 – similar beam pattern to Nichia 219C, but brighter.
Personally, I recommend XPL HI in 5000K neutral white. The XPL HI 3A tint is a good choice.
Northwoods
This one?
http://www.mtnelectronics.com/index.php?route=product/product&path=60_10...
Barkuti
Barkuti's picture
Last seen: 1 hour 55 min ago
Another way to do it, with a modified H1-A boost driver and an in series triple. Jensen567 example(s): #19 in Buck and Boost Drivers, Testing, Modding, and Discussion
The H1-A can reliably handle 2.5A for a triple, ≈25W, maybe a tad more but it may start having trouble with its 10A input limit and non-heatsinked driver ground plane (because of reverse polarity protection). To me this is no problem, that's already a nice lot of power for an E2L, and you attain fully regulated modes in a truly useable light without having to worry about blowing up emitters, PWM and other *cough cough* driver nuisances.
Cheers
Jtm94
Last seen: 3 hours 12 min ago
Honestly I’d only go with a boost driver only if he were going to use a higher voltage single LED at the moment. For now I’ll keep recommending the MTN17DD running Bistro and using the temp sensor. Once all the great folks here get a boost driver running something like Bistro/Biscotti then I will make the change.
I’d also recommend getting a few if not all of the Carclo 3-UP optics just so you can swap them to preference or based on use. I have an E2L with stock XP-G2s that I put the MTN17DD in and I prefer the wide frosted optic for anything indoors or up close. The narrow optic is actually rather concentrated.
NeutralFan
NeutralFan's picture
Last seen: 1 day 3 hours ago
I built my JAXMAN E2L with the MTN-17DD FET + 7135 driver with Bistro, Nichia 80+ LEDs, and narrow spot optics. I really like Bistro since it has up to 8 brightness levels (plus a great moonlight mode) and medium press to lower the levels. I don’t think the H17F driver has the medium press function which I use all the time.
For the battery, the Samsung 30Q will give you maximum output, but the Panasonic NCR18650B 3400mAh will give you a longer turbo time before it gets too hot. I would also go with a flat top.
You may also want to get the deep carry pocket clip.
I’d rather use my flashlight around the house than turn on the lights.
Northwoods
Here’s what I think I’ll go with
FET + 7135 Driver – 17mm – MTN-17DDm
JAXMAN E2L Triple LED Flashlight Host – Grey
10507 Carclo Lens – 3-UP Narrow Spot Optic
Samsung INR18650-30Q 3000mAh Unprotected Flat Top
(3) CREE XP-L High-Intensity V2 3A LEDs on NOCTIGON 3XP MCPCB + PRE-BRIDGED
Northwoods
Finished the light, she’s bright!!!
Newlumen
Newlumen's picture
Last seen: 31 min 37 sec ago
I recommend xpl hi v3 led.
Newlumen
Newlumen's picture
I know your light put out 1600 lumen and 15k lux.. nice light!
hank
hank's picture
Last seen: 4 days 4 hours ago
This thread is a great example of what BLF does best. Thank you all.
