Led4power.com : LD-4 CC linear drivers, ILC-0/1 illuminated tailcaps, optics, MOSX, copper DTP MCPCBs...
1281 posts / 0 new
led4power
led4power's picture
Last seen: 2 hours 5 min ago
  • LD-B4HV is linear driver, but since mosfet is not on driver's pcb, there is no problem with heat, so you can use any cells without problems.
  • LD-B4HV has LDO (smaller sleep current)
  • Yes, driver will cycle modes backward
steel_1024
steel_1024's picture
Last seen: 2 days 3 hours ago
New order.
ILC-1B
Change to 40uA per channel please.
Sorry for my poor english.
beam0
beam0's picture
led4power wrote:
  • LD-B4HV is linear driver, but since mosfet is not on driver’s pcb, there is no problem with heat, so you can use any cells without problems.
Thanks, but then maybe then I don’t understand this at all, where is the mosfet mounted, on the led board? Is that included or I would need to buy separately? If separately do you also sell it?
"Over 2000000 hours (about 200 years) standby time"  (DQG Tiny 4th)
"27,157 results for zoomable flashlight" (ebay)
beam0
beam0's picture
OK I see it now, so for XHP50.2 I’d need your mosled board and the mosfet installed, and run 5 leads to the ledboard.
Maybe luxeon MZ is better. But this might be complicated for me right now.
led4power
led4power's picture
Yes, B4HV has 5 wire connection, 2 for NTC, 1 for gate, and two thick wires for LED. If you want, I can solder wires on MCPCB and install XHP50.2+fet+ntc (I think I have one spare XHP50.2 somewhere).
beam0
beam0's picture
Thanks! In that case I can put this back under consideration again. I’m not sure if it would be easier for me to solder the wires on to the mcpcb or the driver! So I’d need to decide that, please let me know your thoughts on that.
Having you install/reflow the XHP50.2+fet+ntc would be most helpful, that’s the main thing I was worried about.
Let me know if you find the XHP50.2 and what CCT, I’m needing NW around 4500-5000K. Or if there’s something else you have with similar output and beam. I’m sub’d to this thread so you can just post about it here or pm, either way is fine.
Also could you pre install the phosphor bronze spring on the driver?
And can that spring be stretched a few mm longer? (I need about 15-16mm total from driver board) or maybe add a few mm solder blob on the free end?
Thanks!
led4power
led4power's picture
Soldering wires to mosX boards is not trivial, so I recommend that option. I have one piece of 4000K J4 XHP50.2, is that ok?
It's this LED: https://hr.mouser.com/ProductDetail/941-XHP50B00D0BJ440E
I can preinstall spring, but I don't think I have spring that long, which host is that?
beam0
beam0's picture
Thanks, yes that LED might be OK. I have a few 4000K XML/XPL lights I like a lot them but they’re quite warm, not sure how it will be in XHP. I’m also getting your LuxeonV 4000K on 16mm for another light. The warmer tint is fine in the smaller lights but on the larger lights I prefer more towards 5000K, which is what I was leaning towards for this light, but 4000K could be fine, so I need to consider.
And yes great if you could add the wires to the mcpcb it will be very helpful.
For the spring the one listed on your store are 12mm length correct? (High current gold plated phosphor bronze spring 12×9×1mm)
So it only needs about 4mm more, can that spring be stretched a few mm longer? Then add a few mm thickness solder blob on the free end?
The host is a rebuild/conversion of an older Led Lenser V2 TL Tactical Light, (Made in Germany)
It looks exactly like this current one but has only one switch button:
The latest version has a side led (map reading light) built into the side of the head, reason it has the second switch.
beam0
beam0's picture
I’ve also considered XHP35 HD CRI80 http://www.kaidomain.com/p/S026064.Cree-XHP35-HD-D4-50E-White-5000K-LED-Emitter
The Led Lenser V2 TL has a TIR (spot) optic. Maybe the xhp35 would be better suited? Heat and current for xhp50.2 could be a concern, (one reason I like your set up with the temperature sensor in the led board) although it’s a very solid built light, thick walled and tight fitting threads
I see he driver also works with XHP35 but are the voltage difference is too great? (12V-8.4V)
led4power
led4power's picture
XHP35 is 12V led, which type and how many cells you plan to use in that light?
beam0
beam0's picture
I’m using 2*26650, 8.4V
thijsco19
Last seen: 6 hours 42 min ago
Then it isn’t possible to use a xhp35 with this driver.
You’ll need a boost driver for that.
You can use the xhp50.2/70.2 in 6V configuration.
contactcr
Last seen: 2 hours 30 min ago
4*26350 then choose 4S option for the driver.
Btw, is that even a mechanical switch? It looks like it could be an electronic switch and if that’s the case you need to find another driver anyways.
Also, if this is a 3xC cell light and you are trying to make it a 2× 26650 I dont think you should just be using longer springs to take up the room. You should either make or buy a “dummy cell” (a 0 voltage spacer)
KawiBoy1428
KawiBoy1428's picture
Last seen: 5 hours 34 min ago
3xC you could possibly do 4×26500’s for the XHP35…
KB1428 “Live Life WOT
beam0
beam0's picture
Thanks everyone. Ok just so I understand, the driver is not boost or buck it does not change the voltage, and it’s okay to run the 6V led at 8.4V with the 2S cell config, and since 4S was suggested I assume it’s okay to run the 12V emitter at 16.8V? Are there limits for powering emitters at higher voltages than their listed/rated voltage?
  • Switch: I believe it’s a mechanical switch. You cannot do momentary presses until after the switch has been fully clicked ON, like a reverse clicky. (it’s currently single mode so after 1 full click to ON the half presses just blink the led) From my understanding of them a momentary e-switch doesn’t “click” or “latch” to ON.
  • longer spring: The longer spring isn’t for the battery length, for the battery compartment spacing (about 12-14mm) I plan to make a short dummy cell type spacer. The longer spring is for the distance between the bottom of the driver and the top of the switch, which has a center contact. The switch sits between batt+ and driver+ and occupies/seals off the forward part of the tube (like a Maglite)
  • Cell configuration: It will also fit 3×26500 for 12.6V, however 26500 seems to be nearly non-existent, MTN has some but I’m not sure what currents they can provide as they don’t list the spec. there but they may work. I’ll need to look into the 4*26350 idea and consider the costs to go that route.
vinte77
Last seen: 16 hours 55 min ago
Do you have an eta on when an e-switch driver will be available?
led4power
led4power's picture
@vinte I'm currently busy with other stuff, so I can't tell eta.
beam0
beam0's picture
LD-B4HV is linear, so that means input v = output v, correct?
For my options:
  • 2S / 8.4v input = 8.4v output to led
  • 3S / 12.6v input = 12.6v output to led
  • 4S / 16.8v input = 16.8v output to led
doubleone44
doubleone44's picture
For my options:
That correct. The driver can convert some voltage down, like 8.4V at the batteries -> 6V at the LED, but burns the excess voltage away as heat in the FET, which is also the reason the FET is placed on the ledboard.
contactcr
Also 3S is going to sag below 12v instantly when load is applied so dont use that for a 12v LED
led4power
led4power's picture
LD-x4(HV) is linear constant current driver, linear means driver regulates output current by burning excess voltage into heat (via electronically variable resistor,which is mosfet in this case),so its output voltage can't be higher than input voltage; constant current means output is current regulated, driver doesn't care what output voltage would be, as long as LED voltage is lower than battery voltage, output current will be constant.
beam0
beam0's picture
Did you mean 4×26350? A 26500 is basically the same length as a C cell (about 50mm incl. button)
I have about 150mm battery space.
beam0
beam0's picture
Thanks everyone for the helpful info.
beam0 wrote:
For my options:
  • 2S / 8.4v input = 8.4v output to led ( Thumbs Up for 6v LED)
  • 3S / 12.6v input = 12.6v output to led (voltage will sag below 12v)
  • 4S / 16.8v input = 16.8v output to led (26350 cells are only 2000mAh)
So in my case, from what I’ve just learned, XHP35 is not a viable option with this driver.
contactcr
Plenty of people have made hot rod type lights with 4×26350 but if you really want to use XHP35 you may be best served to wait for a good boost driver so you have more battery options. (or go with one of the existing mediocre boost drivers that are out there)
KawiBoy1428
No I meant 4×26500’s, for some reason I thought C’s were the same length as D’s cells just smaller diameter? I have several lights that run 3 cells (18650/32650) and now they run 4×26500’s and 4×18500 with the XHP35HI/HD’s in them, that’s why I stated possibly I wasn’t too sure of it. Smile
beam0
beam0's picture
I understand it would work, but I don’t think I’d be happy dealing with 4 cells for only 2000mAh.
But maybe xhp35 is more efficient to run than xhp50.2? Or does the drivers output current rating determine efficiency?
Not sure I’d consider this a “Hot Rod” by today’s standards, but I suppose it could be.
I could get the MTN-MAXlp HP, but this LD-x4(HV) seems to have much more going for it, almost like a “Dream Driver” ?
Sorry if it’s been mentioned already but does the mosfet create additional heat at the mcpcb?
beam0
beam0's picture
Ok I see, thanks, ya D cell is about 61mm so about 11mm taller than C.
beam0
beam0's picture
So now I am back to the original plan of using XHP50.2
I need to decide on which current range to get.
Output current – (wattage)
  • 2-3A (12-18W)
  • 4-6A (24-36W)
  • 7-9A (42-54W)
Are these estimates correct for wattage at the LED? (assuming 8.4v input will reduce to 6v output)
Also I assume the cells must be capable of supplying even higher input currents to enable these output currents?
Cree specs show 3A/18W Max. (I know it can be overdriven though)
I’m leaning towards 4-6A, any suggestions?
Considerations:
  • Higher wattage = increase lumen output = more heat
  • 1. Body is full sized, tube/neck is very thick (about 5mm) Head is thinner, and no cooling fins.
  • 2. Unsure of power handling capability for the switch.
  • 3. 50W @ LED could melt the TIR optic?
Also, how to run the 3 additional leads through the pill (16mm mcpcb space)
I assume I’d simply enlarge the existing holes? It looks like the mcpcb’s cutouts are wider than usual for this:
beam0
beam0's picture
Just noticed there doesn’t appear to be a pad for the mosfet on the 16mm mcpcb?
Also just noticed that’s a 4040, and there dosen’t appear to be a 16mm 5050.
led4power
led4power's picture
I would say go with 3Amp driver and XHP50.2, that light has no cooling fins and questionable switch current capability, everything above 3Amps would be too much for this host.
