Led4power.com : LD-4 CC linear drivers, ILC-0/1 illuminated tailcaps, optics, MOSX, copper DTP MCPCBs...
1371 posts / 0 new
led4power
led4power's picture
Last seen: 1 day 7 hours ago
Chatika vas Paus wrote:
And when the spacers for c8 i x6 will be available?
I will put spacers this weekend, I'm busy more than usual, so there is delay for some stuff.
Niko
Last seen: 1 day 48 min ago
Is there any chance to have distance ring for standard reflectors and this new osram?
led4power
led4power's picture
I don't think there is one, probably simplest solution is to rotate 3535/XP centering ring.
-X3-
-X3-'s picture
Last seen: 21 hours 23 min ago
Just ordered 3 of them Smile
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 56 min 39 sec ago
Apart from the LD4A, are there any alternative 2S (buck) drivers for tail clickies that would be appropriate for the new Osram-LED? So far, this one here looks okay but it cannot deliver the required 5 amps of current.
http://kaidomain.com/Flashlight-DIY-and-Tools/Circuit-Board-Driver-Board/S025382-FX1-20mm-3V-8_4V-2_5A-1-cell-or-2-cells-2-Group-of-3-Mode-and-5-Mode-Driver-Circuit-Board
The best would be a buck driver (2.9V - 8.4V), e.g. in a Convoy L2 (short and long tube) running at full power over the entire voltage curve.
Agro
Agro's picture
Last seen: 1 min 1 sec ago
MTN buck driver. But it’s out of stock…
Lux-Perpetua
Agro wrote:
MTN buck driver. But it's out of stock...
I'm not sure if this one is for tail clicky lights or e-switch lights. It's also quite expensive to get these things from the US to Germany (shipping and hassle with customs).
F.i.l.a.s
F.i.l.a.s's picture
Last seen: 1 day 6 hours ago
Contact to your neighbour Lexel Wink
The_Driver
The_Driver's picture
Last seen: 4 days 9 hours ago
The best would be a buck driver (2.9V – 8.4V), e.g. in a Convoy L2 (short and long tube) running at full power over the entire voltage curve.
This type of driver is rare as a spare part. It’s probably easier if you just buy a used 2S light with buck driver (maybe a Fenix tk-35) and switch out the sense resistor to get a higher current.
For continuous operation I would go with 4A. I had problems after a while when driving a Black Flat at 4.5A for longer periods of time in a large host with very solid heatsinking.
The FX-35 driver in the Convoy L6 is a 5A 2S buck driver that’s also very, very cheap. I don’t know how well it works with 3V LEDs though. Normally it shouldn’t be a problem. It can be bought as a spare part from Convoy.
Jerommel
Jerommel's picture
Look in the Convoy store on AliExpress.
There is a 3 mode buck driver there, and could well be resistor modded without heat problems to 4 – 4.5 Amperes.
It is a double PCB diver, but no parts on the bottom PCB.
I think it’s around $ 6.
Lux-Perpetua
Danke @ The_Driver!  Beer
Bedankt @ Jerommel! Beer
DB Custom
DB Custom's picture
Last seen: 18 hours 43 min ago
Complex little driver! I just put a 6A LD-A4 in an Eagle Eye X6 host that came in today. I soldered two 20mm copper boards together for height, used a 35mm TIR with a deep narrow “cup” over an XP-L HI and connected these with 20 Ga Turnigy leads. Set up for 5A, with 4 levels and moon mode engaged it works pretty nicely.
The large TIR will show it as unique, the LD-A4 guarantee’s it. Wink
Ryley
Ryley's picture
Last seen: 2 months 4 days ago
Where did you buy the TIR for X6? can you give the link please? Thanks Dale.
DB Custom
DB Custom's picture
I honestly have no idea. It was in my kit, appears to be new, was in the black plastic holder and I had to remove it to fit into the bezel of the X6 which was a little tricky. Works pretty neat…
MRsDNF
MRsDNF's picture
Last seen: 36 min 12 sec ago
Was it from Justin?
DB Custom
DB Custom's picture
I have bins and bins of bits from Justin, as much or more than what I already had of my own. His stuff and my stuff together makes for a LOT of stuff! I can’t remember my own purchases, still finding things in his stuff that I didn’t know I had.
Y’all just can’t know, it’s like he’s here with me all the time. Sad
Bittersweet, at times. Uplifting in other moments. And so it goes…
Ryley
Ryley's picture
Hahaahaaa thanks anyway Dale. Wonder if it’s one of the Kathod optics or not…
eas
eas's picture
Last seen: 9 months 4 days ago
Straight, no spacer?
MRsDNF
MRsDNF's picture
Its taken me awhile to remember where I used a similar optic. Justin sent me the optic. Cant remember the diameter but thought you may have used one in your mod.
http://budgetlightforum.com/node/30545
Hoop
Hoop's picture
Last seen: 1 day 23 hours ago
I think that optic might be Ledil Iris, if it’s ~38mm. Doesn’t look like Khatod PL1672.
Edit: measured actual Ledil Iris optic at 35.0mm. 38mm includes the holder diameter.
djozz
djozz's picture
Last seen: 1 hour 10 min ago
I received the KW CSLNM1.TG leds today. I will do an output test one of these days (if maukka or Koef3 do not beat me to that Smile ), but for now I measured tint at 0 degrees, 30 degrees, 60 degrees.
0 degrees: 6100K on top of BBL, CRI 68
30degrees: 5800K creeping up above BBL, CRI 67
60degrees: 5300K going further up, CRI 65
(note to self: clean stereo microscope internal optics)
DavidEF
DavidEF's picture
Last seen: 1 day 8 hours ago
WAIT! Dots? Are these some kinda micro-COB emitters or something? Won’t those tiny dark spots make it challenging to get max luminance in a thrower?
- The YKK Philosophy
Enderman
Enderman's picture
Last seen: 1 week 1 day ago
Same as the black flat, not any significant variation when on high power.
Completely invisible after all the imperfections on optics.
DavidEF
DavidEF's picture
Thanks Enderman!
Enderman
Enderman's picture
You’re welcome Smile
The “white flat” looks so pretty Smile
Ryley
Ryley's picture
Thanks Hoop, nice info.
-X3-
-X3-'s picture
Can’t wait to get mines !
led4power
led4power's picture
I forgot to put my old test results:
I calculated/estimated lumens from my lux numbers and datasheet bin specification.
Yellow marked lumens calculation are based on old black flat measurements at 1A as reference (made by koef3 I think), non-marked lumens are based on ~middle of bin lumen number at 1A from datasheet (330lm, actual middle is 335lm).
Agro
Agro's picture
Using yellow for calculations….
If this emitter really has 1.0609 mm² and 952 lm we’re at 285 cd/mm².
Note that according to package drawing in the datasheet this LED is 1.0609 mm² minus rounded corners.
Also note that the Blackie HWQP while nominally 1.0609 mm² minus cut corner was measured at 1.12 mm².
I tried to measure the size based on djozz photo, but haven’t really arrived at satisfactory numbers…
Assuming that it actually is 1.0609 mm² it is much more efficient than the previous generation (in terms on intensity vs. efficacy). I’m really anxious to see a Koef3 test where I can compare it with the competitors directly…
Agro
Agro's picture
That’s what I’m seeing, note that I’m far from fully trusting the chart.
Interesting point:
I still think there’s something that we don’t understand about Synios. If we add it to the chart with intensity that can be calculated for a Lambertian 0.503 mm² emitter, it looks like this:
Likely coincidence though.
