Led4power.com : LD-4 CC linear drivers, ILC-0/1 illuminated tailcaps, optics, MOSX, copper DTP MCPCBs...
1265 posts / 0 new
luminarium iaculator
luminarium iaculator's picture
Last seen: 2 hours 54 min ago
Enderman wrote:
Shocked amazing. ahaha look at that poor xp-e2 Silly
Yes XP-E2
But old XP-G2 S4 2B also deserves to be in that graph cause it has just slightly lower lux performance(and sometimes certain g2s42b can have even better performance than certain black flat).
ZozzV6
ZozzV6's picture
Last seen: 1 day 37 min ago
+1 for white flat. Black flat is well known for thrower led and it is easier to get what it is and also remember the name.
Another thing:
Measured the GT mini current and lumens with sanyo GA cell.
It has 792 lumens and it draws 5,5A
led4power
led4power's picture
Last seen: 6 hours 25 min ago
The_Driver wrote:
led4power wrote:
vinte77 wrote:
Any progress on any of the new items that you are planning to release?
Limited qty of subZero switches should be available in 2-3days,spacers too, full kits 2-3days after those.
Still hoping ;)
Sorry about those promisesundecided but new osram leds came to me and I had to process bunch of orders etc., always something unexpected appears and limits my time for other stuff.
I will not predict release dates anymore, products will just appear on web,maybe that's better.
MascaratumB
MascaratumB's picture
Last seen: 4 min 10 sec ago
I’m sorry if this was asked before, but can the 17mm LD-4 drivers be sanded/filled to 15mm diameter and work properly?
I would ask this on PM but seeing so much work and so few time I’ll ask to you, fellow members Innocent
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
The_Driver
The_Driver's picture
Last seen: 30 min 15 sec ago
led4power wrote:
The_Driver wrote:
Still hoping Wink
I will not predict release dates anymore, products will just appear on web,maybe that’s better.
Please do it soon. I have been waiting since you announced the Luxeon MZ LEDs months ago. There is nothing that’s compareable to your “complete system”.
contactcr
Last seen: 1 hour 13 min ago
I am also waiting to make a combined order w/ X6 spacer + other things
led4power
led4power's picture
MascaratumB wrote:
I'm sorry if this was asked before, but can the 17mm LD-4 drivers be sanded/filled to 15mm diameter and work properly? I would ask this on PM but seeing so much work and so few time I'll ask to you, fellow members O:)
GND ring is ~1mm wide so sanding driver down to 15mm is probably too much, 16mm would be ok.
djozz
djozz's picture
Last seen: 2 min 31 sec ago
Some more checks on the BLF D80 with KW CSLNM1-TG led. (Should this led get a dedicated thread btw?)
First, I was not happy with the quite random centering that twisting a 3535 centerpiece provides, so I modded the centerpiece: with a scalpel I cut new corners 45 degrees from the original corners, fixing the 3030-sized led much better. So the flashlight has two centerpieces, one locked around the other, both sanded very thin at the underside for exact focus, now also exact centered.
With the led perfectly centered in 3 dimensions the beam was superb.
Now I measured throw again, first on the almost full 30Q (4.08V): 140 kcd (as I measured before), then let the light run for half an hour (it got hot, I estimate 70 degrees! A biscotti driver has no thermal stepdown, and a 3.9 amp flashlight produces some 15W of heat), the battery was now 3.59 V, so wel over half empty. Measured throw again and still got 125 kcd.
I did the same test with the same battery on a C8 with dedomed XP-G2 S4 2B. Started at 4.08 V with 141 kcd, and with the cell at 3.59 V I measured 90 kcd.
So the low voltage combined with the much needed current regulation of the biscotti driver makes the output and throw of a flashlight with the new Osram led more constant than a light with a direct driven S4 2B.
Plus the current is a bit lower for the same throw.
DB Custom
DB Custom's picture
Last seen: 13 hours 45 min ago
Nicely done Jos! Good thinking outside the box with the dual centering rings, very imaginative!
djozz
djozz's picture
Thanks Dale, I’m very happy with how I got it done. But how I would like some fitting centerpieces for this led!, would make life quite a bit easier.
MascaratumB
led4power wrote:
MascaratumB wrote:
I’m sorry if this was asked before, but can the 17mm LD-4 drivers be sanded/filled to 15mm diameter and work properly? I would ask this on PM but seeing so much work and so few time I’ll ask to you, fellow members Innocent
Thanks for the answer mate Wink Maybe I should thing reversely, then, sanding the driver till the 16mm and the extra by sanding the flashlight hole!! Thanks again!! Thumbs Up
OL Contest 2019
GIVEAWAY: 1 / 2
MRsDNF
MRsDNF's picture
Last seen: 7 hours 21 min ago
Nice work djozz. I’d have no hope of achieving a result like yours. Thumbs Up
Athlon2350
Last seen: 14 hours 50 min ago
Hi
LD-B4HV (2s – 8.4v) can use with triple XP-G2 connected in series ?
I did that here: http://budgetlightforum.com/node/63255
Now I must gather all relevant data and builds into first post of that thread.
led4power
led4power's picture
Athlon2350 wrote:
Hi LD-B4HV (2s - 8.4v) can use with triple XP-G2 connected in series ?
No, 3 LEDs in series would have 9-12V forward voltage, 2S cells on the other side have 8.4V max.
MascaratumB
Order placed, PM sent Wink
OL Contest 2019
GIVEAWAY: 1 / 2
contactcr
Have you ever considered making 20-22mm drivers or at least stocking 17->20 and 17->22 quality spacers?
Chatika vas Paus
Last seen: 26 min ago
You can buy it on KD
17>20 2pcs
17>20 5pcs
20>22 2pcs
contactcr
I have a 17 to 20 but who wants to use 2 spacers to go from 17 to 22. Thanks for the 20 to 22 though havent seen that
MascaratumB
contactcr wrote:
Have you ever considered making 20-22mm drivers […]
It would be handy, I would get one to mod my Amutorch VG10 Wink
OL Contest 2019
GIVEAWAY: 1 / 2
led4power
led4power's picture
I plan to have all sizes for new driver iteration, so until then LD-x4 will stay 17mm only, sorry.
Agro
Agro's picture
Last seen: 48 min 55 sec ago
Trying to set the max power of my LD-A4. 10+ clicks enters main menu, OK, 5 fast clicks blinks and power goes down. 1 click enters current adjustment, OK, 1 blink and current goes down again. I click 7 times for 4.75A. I get 15 blinks in response. What’s up?
BTW 30 seconds of idle time was WAY too fast for me, I needed over a minute just to read the relevant section.
zeroflow
Last seen: 3 weeks 5 days ago
That’s right
Agro wrote:
5 fast clicks and power goes down.
Correct, now you are in the setting you chose
Wrong, in the “low light” setting, 1 click = return, >= 2 clicks: Setting
You now left the setting and went back into the menu
That should not happen as you left the setting and now are in the general menu
That’s wrong, you now should be in setting 7 (whatever that is)
You can always enter again.
But in that case, read first, note the settings you want and then start configuring…
Agro
Agro's picture
Facepalm
I meant 5 fast blinks, not clicks.
Making notes, that’s a good idea. Still, I believe that making the duration much longer would make the adjustment easier.
SKV89
Last seen: 7 hours 26 min ago
LED4POWER, can you tell me tint bin of the LH351D 4000k 90CRI you are selling? It says SPHWHTL3DA0GF4T0Q6, which means tint bin is T0 but there is no T0 tint bin.
Oh NVM, I see description says T6.
SKV89
emarkd wrote:
Emitters are 219b sw40 r9080s from Clemence….. This thing gets crazy hot, fast, at 12 amps cc.
Isn’t 12amps too much for a triple 219B? Did it run fine? How many lumens were you making?
MascaratumB
Forgot to let my feedback on the things received! All good and some are already in use Wink
BTW, it took me a while to figure out how to operate the driver configuration, but then it was all full speed ahead!
I’ll be getting some more soon and other stuff as well!
Thanks for you work Thumbs Up
OL Contest 2019
GIVEAWAY: 1 / 2
contactcr
Ordered 10x Luxeon V2 4000K 70CRI from DigiKey, excited to try these out. I think the 5000K versions will begin showing up in less than a month it seems. I’m sure LED4Power is already on top of this Smile
The original 4040 Luxeon V has one of the most evenly tinted beams of any LED I have seen so if this is remotely similar it will easily become my go to 70 CRI LED choice for 3535 footprint.
contactcr
I am not too smart.
6×0.5mm Gold Plated Brass Button Contact
This means 6mm not 6 contacts. Public service announcement. Smile
shirnask
shirnask's picture
Last seen: 11 min 35 sec ago
contactcr wrote:
I am not too smart.
Don’t feel bad, I made the same mistake because I added this item at the last minute and did not pay enough attention Facepalm
