Led4power.com : LD-4 CC linear drivers, ILC-0/1 illuminated tailcaps, optics, MOSX, copper DTP MCPCBs...
1199 posts / 0 new
XXX-Man
XXX-Man's picture
Last seen: 1 min 57 sec ago
emarkd
This is OMTEN switch.
"With the first link, the chain is forged. The first speech censured...the first thought forbidden...the first freedom denied – chains us all, irrevocably."
My reviews:
Sofirn SF36 /// Thorfire VG10S /// Sofirn C8F /// Zanflare F1
led4power
led4power's picture
Last seen: 4 hours 6 min ago
Correct, it's Omten 1288.
g_damian
g_damian's picture
Last seen: 1 hour 43 min ago
It’s too high to fit into E2L.
led4power wrote:
I don’t have E2L, but I have Jaxman U1 and tailcap parts are identical to Convoy S2+, so ILC-1 fits (just tried). If E2L also has 18mm washer and 16mm PCB then it would fit.
1C3
Last seen: 1 day 8 hours ago
I just tried it in my E2L host (haven’t assembled the light yet because I’m waiting for other parts) and it does fit, though the retaining ring sits a bit too high (something easily solved by sanding it a bit). Perhaps you left the washer in? I think you are supposed to remove it when using ILC-1.
g_damian
g_damian's picture
yes, I removed the original washer. But could not screw retaining ring. To be honest I tried only once. Probably ILC-0 would be a better solution for E2L.
led4power
led4power's picture
On Convoy lights, because original switch PCB diameter is ~16.5mm and ILC-1 is 18mm, "effective" height of ILC-1 is ~1-1.5mm higher, but it still fits without problem.
ILC-0 has 16.5mm diameter so it would fit like original switch PCB.
alberto7
Last seen: 4 days 12 hours ago
Hi, any plans of make 20mm version of this “L4P 4040 DTP 16mm for Luxeon V” ?
Also, any plans of make XP version of the dtp copper board (with 0402 NTC footprint on board)?
Thanks Wink
vwpieces
vwpieces's picture
Last seen: 1 week 3 days ago
Last 4 lights I worked on had 14mm emitter MCPCB.
no one has ever made a 14mm DTP XP. And the 14mm XM Tpad are getting really hard to find.
I have to request these. I would buy 20 of each to start.
I could start a feeler thread if you would like to test interest.
djozz
djozz's picture
Last seen: 1 hour 7 min ago
It is still quite a financial risk having ledboards made, the MRQ is usually in the hundreds so you must have reasonable confidence that you get that many sold. I have no idea what the size is of l4p’s flashlight undertaking (not huge I guess) but I’m already (pleasantly) surprised that he had a 16mm 4040 board made.
led4power
led4power's picture
Speaking of 16mm 4040 DTP, they are out of stock now; I have plans for 20mm version and few other pcbs, but as djozz said, start cost is high and you don't know how well they will sell.
alberto7
Hi, there is any option for use the Luxeon V with the ld-a4 driver in convoy s3 host?
for example the vf of the Luxeon V at 6A is aprox 3,35v so… (4,2-3,35) *6 = 5,1w.
So, its out of the maximun that driver can support (acording to datasheet).
i see the aluminium piece for the s2+ but i don´t like that the s2+ has pill and a very wide retaining ring (that would be problematic with this driver).
emarkd wrote:
So.. any options for built a luxeon V flashlight with this driver in safe limits?
Put a cube will be enought?
I think that runing DD will works (not driver heat) but thats probably produce 8-9 amps and thats too much heat for the small host.. so its desirable to limit to 6 or lower amps in my opinion.
Thanks Wink
g_damian
g_damian's picture
Finally finished (no tailcap mod yet): Jaxman E2L + LD-B4 + Nichia 219C sm503. More details here.
g_damian wrote:
Thanks. So I’m thinking about NOCTIGON 3XP MCPCB & Nichia NVSW219CT R8000 D260 + LD-A4 + ILC-1 + E2L.
What do you think? Will it be good match? What amp version should I choose? 6A for 3 LEDs = ~600lm per LED. 12A for 3 LEDs = ~1000lm per LED (I’d prefer 12A because I could configure it at 8A and it seems to be ideal). Is LD-A4 enough or should I consider B-version?
kiriba-ru
kiriba-ru's picture
Last seen: 7 hours 12 min ago
I have thin retaining rings compatible with S2/S2+ etc.
2017_10_09_21_02_48 2017_10_09_21_06_11
led4power
led4power's picture
alberto7 wrote:
So.. any options for built a luxeon V flashlight with this driver in safe limits? Put a cube will be enought? I think that runing DD will works (not driver heat) but thats probably produce 8-9 amps and thats too much heat for the small host.. so its desirable to limit to 6 or lower amps in my opinion. Thanks ;)
Best solution would be thermal kit similar to S2+ thermal kit,or at least approximation.
Silicone cubes may work if you don't bypass springs and use 10Amp discharge batteries.
alberto7
Very nice to see that Wink I will buy 2 pieces for use with LD-A4 thermal enhancement kit for Convoy S2+ and the Luxeon V.
Do you have any picture?
The rings is equal but less wide?
led4power wrote:
Best solution would be thermal kit similar to S2+ thermal kit,or at least approximation. Silicone cubes may work if you don’t bypass springs and use 10Amp discharge batteries.
Yes, thermal kit would be the best, thats for sure. If the thin retaining of kiriba-ru works well i will go for the s2+ with the thermal kit.
BTW thermal adhesive (artic alumina) works for glue the aluminum to pill ? or this change the measures?
kiriba-ru
kiriba-ru's picture
You dont see attached images in my previous post?
led4power
led4power's picture
Thermal sheets are not adhesive, their purpose is to fill small air gaps between contact surfaces.
Total thickness is such that everything fits tightly into host for best thermal transfer.
alberto7
yes, i see the images. I think that the images was of other diametter.
Its the same ring as the s2+?
I understand you. I think that i formulated the wrong question Facepalm
My question is if i can use thermal adhesive (Arctic Alumina™ Thermal Adhesive) instead of the sheet?
hahaha my english It’s not too good
kiriba-ru
kiriba-ru's picture
This is regular 18mm rings that can fit convoy S series.
alberto7
ok, thanks for the aclaration.
Look a bit tall, so i don´t know if will work good. In the images looks like at least 2x tall of the regular ring but I may be wrong.
Do you have any info for that?
kiriba-ru
kiriba-ru's picture
Inner hole is 16mm.
As you can understand there is not enough place to make holes (similar to the stock ring) for unscrewing, so they are changed with milled cuts.
Also, stock ring height is not enough for such cuts, thats why custom rings are taller.
Ring height is 3mm.
Ring OD is less than 18mm. So it can easily enter any 18650 battery tube.
The only issue (contacting cell outer heatshrink/isolator) may be met if you dont use positive (driver) spring.
alberto7
Hi,
great explanation, i undertand you. So, if i undertand correct there is no problem at all because the driver ring don´t touch with the 18650 tube, so the flahslight screw in normally.
led4power
led4power's picture
Time for some gift coupons:
first two BLF members who correctly answer to question: how many LEDs and which size there are on ILC-0,  will receive 6€ led4power store coupon valid for ILC-0 or ILC-1 purchase (valid for 14days).
djozz
djozz's picture
Generous! I think I know that, but since I can make my own illuminated tailboards I want someone else to win this Smile
Sirius9
Sirius9's picture
Last seen: 2 days 14 min ago
4 leds,
size 0603 Beer
djozz
djozz's picture
smaller I think
alberto7
1—- 4 leds
2—- size 0603 Wink
led4power
led4power's picture
Ok, that was easy,next time questions will be a little bit harder:)
Correct answer is 4 LEDs, 0603 size, so Sirius9 and alberto7 won 6€ coupon for Illuminated switches product category - congrats!
Please register on led4power.com if you don't have account, and send me your usermane/mail on PM.
alberto7
I already send the PM
Thank you for doing this Smile
Sirius9
Sirius9's picture
Thanks led4power, this are realy next level lighted switches Big Smile
