Led4power.com : LD-4 CC linear drivers, ILC-0/1 illuminated tailcaps, optics, MOSX, copper DTP MCPCBs...
1361 posts / 0 new
Eleziel
will34 wrote:
Is the LD A4 enough for the 3V XHP50.2 or should I go with the B4?
I haven’t had issues pushing 12A through the A4 in a small host.
led4power
led4power's picture
Last seen: 8 hours 51 min ago
5700K Luxeon V (I'll put it on web this weekend).
KevinZA1988
KevinZA1988's picture
Last seen: 1 week 13 hours ago
Neven, can you perhaps put up a picture to show the tint vs the 4000K Luxeon V?
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
Agro
Agro's picture
Last seen: 1 min 59 sec ago
If not for shipping, that clearance would feel like a gaw. I love your alu boards.
Caleb
Caleb's picture
Last seen: 1 week 4 days ago
Neven, do you offer 20mm drivers or 17mm to 20mm driver adapters?
Thanks,
Caleb
4492011
Last seen: 1 day 21 hours ago
Neven, any plans to be able to utilize an electronic side switch ?
led4power
led4power's picture
Caleb wrote:
Neven, do you offer 20mm drivers or 17mm to 20mm driver adapters? Thanks, Caleb
Not currently, I'll check with Simon if he could make some adapters.
led4power
led4power's picture
Yes, but I can't tell exactly when since I have some other custom projects to do.
KevinZA1988
Thanks,
Caleb
Kaidomain sells adapters.
Caleb
Caleb's picture
KevinZA1988 wrote:
Thanks,
Caleb
Thank you!
Eleziel
KevinZA1988 wrote:
Thanks,
Caleb
Those are too tall for at least the Convoy L2, i had to grind mine down to at least half for the retaining ring to fit over it.
contactcr
Last seen: 11 min 4 sec ago
I agree, they are way too thick
led4power
led4power's picture
I could possibly make small batch of 20mm LD-x4 pcbs, how much interest there would be and for which host they would be most used?
KevinZA1988
Convoy M21A & S21A
Eleziel
I’m not sure how much interest there would be but i’d definitely get a 12A B4HV.
I imagine the A4 7-9A would be popular. (luxeon V, SST-40)
Why is the difference for the for the 9A version 2A and the 12A version 4A? would it be possible to make a 5-8A version? that’d hit the sweet spot for XPL-HI, Luxeon V , SST-20, SST40, White flat 1 and 2 and others.
KevinZA1988
I would definitely go for a 4-6 A version for Luxeon V, and 7-9 A version for 3V XHP50.2.
I tend not to overdrive my LED’s too much to keep them in regulation for longer and better efficiency.
awsom50
led4power, do you know when osram white flat on 20mm board will be back in stock? Thanks!
led4power
led4power's picture
Next week at best, I maybe have 4-5pcs in reserve, how many do you need?
will34
will34's picture
Last seen: 5 hours 15 min ago
I have a BLF luckysun D80 that’s been waiting forever for a correct driver, the 20mm driver would be perfect.
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 9 min 13 sec ago
Hi Neven,
Is there any chance to offer Osram CSLPM1.TG (White Flat 2mm²) and CSLNM1.TG (White Flat 1mm²) on a 20mm quad MCPCB? I would be very interested into some DYI light comparable like Acebeam's TK16. Kirill (kiriba-ru) seems to be working on a quad pill for the S11 host.
Cheers,
Thomas
led4power
led4power's picture
 I have 20mm triple and quad 3030 on my "wish-to-do" list for a while, regular 3535 pcbs are just not good for that, even on single LED pcbs white flat slides to one side 50% of time during reflow.
will34
will34's picture
I got exited just imagining a quad white flat in the D4.
contactcr
I think it’s actually more impressive in a triple since they are driven harder or a quad with bigger optics and bigger battery like the D4S.
Inkidu
Last seen: 8 months 2 days ago
I’d buy two 20mm LD-B4
awsom50
I need 3 for now. I will buy some more stuff from the site, how do I add this to cart? Thanks!
led4power
led4power's picture
awsom50
One more qiestion: is there a difference between direct drive LD-A4 4-6 amp version versus DD on 7-9 amp version of the same driver? Is the FET the same?
What happens if for example I use battery that can give 5 amp max and I set it to 6 amps regulated?
Thanks!
led4power
led4power's picture
There is no difference between DD mode on 3-12Amp versions, it's "real" DD which means fet is fully turned on.
If battery can provide 5A max. and you have 6A max. mode, it will act like DD mode - driver will provide max. possible current.
led4power
led4power's picture
5700K Luxeon V added, all multiple LED MCPCBs have 4000K/5700K tint mixing option:
https://led4power.com/page/1/?s=l1v1&post_type=product
Also I added "Do not solder FET+NTC+connector" option for big (32mm and 34mm) mosX boards - for those who want to use those boards with any other driver except LD-B4.
led4power
led4power's picture
Osram KW CSLNM1.TG (1mm2 "white flat") is back in stock (same good bin 6N-ebxD46), with lower price:
https://led4power.com/?s=1mm2&post_type=product
