Led4power.com : LD-4 CC linear drivers, ILC-0/1 illuminated tailcaps, optics, MOSX, copper DTP MCPCBs...
1170 posts / 0 new
Yokiamy
Yokiamy's picture
Last seen: 1 hour 1 min ago
led4power wrote:
Osram KW CSLNM1.TG (1mm2 “white flat”) is back in stock (same good bin 6N-ebxD46), with lower price:
https://led4power.com/?s=1mm2&post_type=product
Wow, very interesting and low priced!
might have to buy some soon.
The white flat is just a 3V LED isn’t it?
WTS BLF GT
led4power
led4power's picture
Last seen: 3 hours 11 min ago
Yes, 3V single die.
KevinZA1988
KevinZA1988's picture
Last seen: 31 min 4 sec ago
Hi Neven,
Would it be possible to release drivers in the future with other firmwares such as Crescendo or Bistro? Maybe charge an extra fee for that??
I have tried both, and especially Crescendo would be awesome on your drivers.
BLF Q8, BLF A6, BLF FW3A, BLF FW3C, Convoy L2, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
led4power
led4power's picture
Those firmwares are made for DD drivers and are not compatible in any way with my drivers, and vice versa. Future compatibility is also not possible, drivers which use them don't have (IHMO) basic hardware requirements like current regulation and external temp. sensor support.
treellama
Last seen: 1 hour 10 min ago
Are your drivers open source?
led4power
led4power's picture
No.
KawiBoy1428
KawiBoy1428's picture
Last seen: 44 min 14 sec ago
Big Smile Hahaa NO. with a period! Beer
KB1428 “Live Life WOT
treellama
Haha couldn’t hurt to ask Smile
raccoon city
raccoon city's picture
Last seen: 2 hours 16 min ago
Post #1000!
(at the moment)
1000th_post
Ryzbor
Ryzbor's picture
Last seen: 1 hour 33 min ago
led4power wrote:
Those firmwares are made for DD drivers and are not compatible in any way with my drivers, and vice versa. Future compatibility is also not possible, drivers which use them don’t have (IHMO) basic hardware requirements like current regulation and external temp. sensor support.
Any way of mode ascending, either by double click or TK style long click would be very welcome.
good tint: Nichia E21A 2000K-7500K except d240 bin, Nichia 219B sw40/sw45, 219C sw303, Cree XPL-HI A/D bins, XHP70.2 5A, Samsung shaved LH351D's, SST-20 FD2, FA3, HA3, .
led4power
led4power's picture
That and much more will be available on next driver generation.
led4power
led4power's picture
Osram 4040 1mm2 LED CULNM1.TG added,limited qty available:
CULNM1.TG
4492011
Last seen: 3 days 21 hours ago
Electronic Side switch availability I hope ?
led4power
led4power's picture
Of course.
KevinZA1988
Looking forward to the next generation drivers then.
Are you still planning on making 20mm drivers? I am concerned about the heat transfer from the Mosfet on the LD-A4 driver when using adaptor rings even though I fill the driver cavity with silicone cubes. I use my throwers with two modes only, moonlight and max safe regulated current. This means the mosfet won’t run too hot in high mode because of the difference between Vbatt and Vf at those high currents, right? I am referring to the CSLNM1.TG and when I install the new CULNM1.TG.
KevinZA1988
led4power wrote:
Of course.
I can see this making it’s way into my Emisar D4 somehow…. I don’t even use my D4 because of the driver. I wan’t a proper cc driver in it! Party
madsnake
madsnake's picture
Mark Piezó wrote:
everybody wrote:
Nope!
Silly
Speak for yourself Wink
CRX
CRX's picture
Last seen: 14 min 57 sec ago
Did you answer his questions tho? LOL
Trashy Facepalm
Chatika vas Paus
Last seen: 1 hour 6 sec ago
lol Big Smile
madsnake
madsnake's picture
Well… Smile
Ryzbor
Ryzbor's picture
Glad to hear that. I’ll have to be patient then Smile
One teeny tiny suggestion: consider sourcing Cree 660nm Photo Red XP-E2’s or even better, the newer red XP-G3’s.
It’s a big niche on the market, finding them in single quantities for a reasonable price is impossible, and Kaidomain and others only have 620nm “orange” red XP-E2’s.
I personally wouldn’t mind paying a bit more to get a Photo Red led in small quantities. Or maybe the Photo Red SST-10’s are worth consideration if they can withstand 2.5A as the XP-E2 can.
led4power
led4power's picture
KevinZA1988 wrote:
Looking forward to the next generation drivers then. Are you still planning on making 20mm drivers? I am concerned about the heat transfer from the Mosfet on the LD-A4 driver when using adaptor rings even though I fill the driver cavity with silicone cubes. I use my throwers with two modes only, moonlight and max safe regulated current. This means the mosfet won't run too hot in high mode because of the difference between Vbatt and Vf at those high currents, right? I am referring to the CSLNM1.TG and when I install the new CULNM1.TG.
I will design 20mm driver version this weekend and send it to fab.
led4power
led4power's picture
Ryzbor wrote:
Glad to hear that. I'll have to be patient then Smile One teeny tiny suggestion: consider sourcing Cree 660nm Photo Red XP-E2's or even better, the newer red XP-G3's. It's a big niche on the market, finding them in single quantities for a reasonable price is impossible, and Kaidomain and others only have 620nm "orange" red XP-E2's. I personally wouldn't mind paying a bit more to get a Photo Red led in small quantities. Or maybe the Photo Red SST-10's are worth consideration if they can withstand 2.5A as the XP-E2 can.
I will check that deep red XP-G3, it looks interesting because die looks like it's 2mm2 and I also prefer deep/true red over orange-ish 620nm red LEDs.
Also the other very singificant advantage over 620nm red LEDs is that light output does not drop as nearly as much at high temperatures:
Mike C
Mike C's picture
Last seen: 2 weeks 6 days ago
led4power wrote:
Poor guy even opened led4power@tutanota.com mail with insulting content of 10-year old this morning
All because I was apparently way too slow with answering to his questions over PM (he sent me 11 messages within 24hrs):
Man, some “customers” sure aren’t worth the hassle. You can be glad he blocked himself before you actually sold something to him.
SKV89
Last seen: 1 hour 28 min ago
led4power, you must remember manufacturers and sellers are not allowed to take vacation, hang out with friends, or sleep and must answer all customer questions within 3 hours. This is the BLF seller’s rule Big Smile
contactcr
Last seen: 41 sec ago
Maybe they are trying to use LED4Power’s drivers to rebuild Notre Dame
Marc E
Last seen: 10 hours 49 min ago
That would be an interesting post in the ‘What did you mod today’ thread.
contactcr
Mark Piezó wrote:
You are all third-class people: Croats, Australians, Germans, Russians, Americans.
This is quite a defense.
Seems a coincidence that when he did not reply for less than 1 day on question unrelated to his components that you turned into a third class person like us and blocked him? Suspicious indeed.
Chatika vas Paus
Mark Piezó wrote:
None of you supported me and all at once believed this rogue without any proof.
Well. Neven is here much longer and most of us know him well so we have a reason to believe more him than a new user.
Just my opinion.
vinte77
Last seen: 2 min 16 sec ago
You guys missed his (Mark Piezo’s) response to the butt hurt comment yesterday about duck and mouth, which was taken down right away.
