Led4power.com : LD-4 CC linear drivers, ILC-0/1 illuminated tailcaps, optics, MOSX, copper DTP MCPCBs...
1289 posts / 0 new
highzlik
Last seen: 11 hours 56 min ago
Ok try to do some pictures tomorrow but I think, nothing is visibly wrong (other than my poor soldering ;-)). Even no “ magic smell”. I wonder if it could be too much heat during soldering the spring?
Smoothynobutt
I have a convoy S2+ that I was trying to put one of the RGB tail caps in. I have 3 of them and I tried the switch in all of them. And the convoy with the H17F Dr Jones driver is the only light that it sort of works in. Except the RGB doesn’t stay on. It flickers for a second and then stays off. It didn’t work at all in the other 2 convoy’s.
Sup
led4power
led4power's picture
Last seen: 4 hours 23 min ago
I know ILC-0 RGB works with LD-x4 driver, I can't guarantee for other drivers, especially since they usually even don't have proper bleeder (RGB is power hungry compared to single colors).
Smoothynobutt
led4power wrote:
I know ILC-0 RGB works with LD-x4 driver, I can’t guarantee for other drivers, especially since they usually even don’t have proper bleeder (RGB is power hungry compared to single colors).
That’s ok, not a big deal. I’ll just a build with that driver! Soon as I figure which one to build…
Sup
Skylight
Skylight's picture
Last seen: 7 min 15 sec ago
When will the Luxeon V 4000K be in stock again?
My 7th Old lumens contest build: Matainvoy ML18S
My reviews: Sofirn SP31 V2.0Nightwatch NI40 StalkerSofirn C8F 21700Brinyte WT01 Apollo
led4power
led4power's picture
I'm not sure. There is also 3000K "available" (3month lead time) and price is higher, but it looks interesting. If there is enough interest I would try to get 3000K first (mixing with 5700K in quads/hex would give very nice ~4300K tint,maybe even/probably under BBL).
KevinZA1988
KevinZA1988's picture
Last seen: 1 week 6 days ago
What’s the CRI on the 3000K Luxeon V you are looking at?
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
led4power
led4power's picture
70CRI, but if tint is anything like 4000K (and I believe it is even better/closer to BBL since low CCT LEDs tend to be closer to BBL in general), it would still look great with crazy output.
KevinZA1988
That is good news. The 4000K Luxeon V has one of my favorite Non-90CRI LED tints. Hope you can get a few for us warm tint fans!
Ryley
Ryley's picture
Last seen: 1 week 3 days ago
+1 for 4000K Luxeon V
MascaratumB
MascaratumB's picture
Last seen: 1 hour 16 min ago
Luxeon V2 5000K >>> Luxeon V 4000K >>> Luxeon V2 3000K
You gotta love these leds Big Smile
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
Skylight
Skylight's picture
Thank you for the answer, led4power. Smile
I’m sure tint mixing with 3000K and 5700K would look great. Recently I did a lot of tint mixing in multiple led flashlights. But the 4000K Luxeon V would still be needed for single led flashlights.
Valor
Last seen: 1 week 4 days ago
Neven,
I’m thinking about modding a C8 with one of my UV leds. They run upto 3A @ 4.8V.
Would an LD-A4 be a good fit for running the emitter at full power from a single decent 18650?
JaredM
JaredM's picture
Last seen: 2 hours 44 min ago
Wow. Those tints do look great. Hmmm..
led4power
led4power's picture
Valor wrote:
Neven, I'm thinking about modding a C8 with one of my UV leds. They run upto 3A @ 4.8V. Would an LD-A4 be a good fit for running the emitter at full power from a single decent 18650?
UV LEDs generally (especially <385nm) have very high Vf so linear drivers are not good fit for that purpose.
Valor
led4power wrote:
Valor wrote:
Neven, I’m thinking about modding a C8 with one of my UV leds. They run upto 3A @ 4.8V. Would an LD-A4 be a good fit for running the emitter at full power from a single decent 18650?
Thanks. I’ve apparently missed that this driver was a linear driver. Revisiting the product page and the PDF i can clearly see it now. Even the name suggested that Big Smile
I guess I will have to find a boost driver.
led4power
led4power's picture
Boost is not good too,you'll need buck-boost since LED voltage can be lower than full battery (4.2V). Other option is to use two cells in series (18350/CR123) + linear or buck driver.
Valor
led4power wrote:
Boost is not good too,you’ll need buck-boost since LED voltage can be lower than full battery (4.2V). Other option is to use two cells in series (18350/CR123) + linear or buck driver.
Thanks alot. I don’t want to hijack your thread, but can you point me towards some good drivers? A single mode full power boost driver would be okay
led4power
led4power's picture
It's best for you to open new thread, some BLF members are better informed regarding Chinese boost drivers.
MascaratumB
They are indeed!
The ones I like the most are the 4000K Luxeon and the 3000K Luxeon V2. Actually I am thinking about getting a triple of 3000K of these Wink
It is a very pleasant beam and tint! I guess Luxeons will be, after all, my favourite Leds Blushing
OL Contest 2019
GIVEAWAY: 1 / 2
led4power
led4power's picture
Osram CSLPM1.TG (aka white flat 2) is now available in higher 6P flux bin, that should be about 10% brightness increase compared to 5P (according to datasheet and previous measurements - about 1800lm @ 7.5Amp):
https://led4power.com/?s=cslpm1&post_type=product
16mm DTP boards are out of stock, new batch of gen2 boards are expected by the end of March ( about 1.5 month later than planned because of virus thing).
id30209
id30209's picture
Last seen: 8 min 38 sec ago
Neven what about CULNM1.TG restocking?
WTB  Jetbeam TCR1  &  Titanium 47 2xAA Quark
4492011
Last seen: 1 day 4 hours ago
Where can i find gaskets for the 4040 CULNM1.TG ?
led4power
led4power's picture
 I'm not sure about CULNM1.TG restocking, I will try to source some.
There are no gaskets currently available for 4040.
djozz
djozz's picture
Last seen: 4 min 21 sec ago
And ask for the culpm1 as well? Innocent
led4power
led4power's picture
I'll try.
led4power
led4power's picture
Luxeon V 4000K is in stock again, CAT code is V13F (same Vf bin as 5700K so they can be mixed), mixing 4000K+5700K is added as option for all 4x and 6x boards:
https://led4power.com/product-category/leds1/lumiledsluxeon/luxeon-v/
Skylight
Skylight's picture
Perfect, thank you. Thumbs Up Cool
