Led4power.com : LD-4 CC linear drivers, ILC-0/1 illuminated tailcaps, optics, MOSX, copper DTP MCPCBs...
1371 posts / 0 new
Niko
Last seen: 2 hours 10 min ago
How long do you plan to keep it closed?
Constantly closing stores to avoid paying taxes is a very bad attitude towards customers :/
led4power
led4power's picture
Last seen: 2 hours 48 min ago
"To avoid paying taxes"  statement is not true, I'm paying taxes either way, but I can't explain my local bureaucracy and laws in one sentence. Store will be closed probably for another two weeks until new generation of DTP PCBs arrive.
Superstocker
Superstocker's picture
Last seen: 2 hours 6 min ago
Looking forward to the reopening. Best of luck to you and your business!
will34
will34's picture
Last seen: 16 hours 16 min ago
Looking forward to the store resuming operations, I have 2 hosts in need of emitters and drivers.
luminarium iaculator
luminarium iaculator's picture
Last seen: 2 days 3 hours ago
led4power wrote:
“To avoid paying taxes”  statement is not true, I’m paying taxes either way, but I can’t explain my local bureaucracy and laws in one sentence. Store will be closed probably for another two weeks until new generation of DTP PCBs arrive.
And some nice dedicated Osram emitter series drivers?
led4power
led4power's picture
I'm working on new driver generation, but it will take some time.
EasyB
Last seen: 2 weeks 8 hours ago
With the LD-x4, when DD mode is enabled in the menu, does DD replace the constant current high mode? Like if I have a 6A driver and am using with a low Vf LED so DD is say 12A, does enabling DD mode mean I don’t have a 6A mode?
contactcr
Last seen: 2 hours 46 min ago
Yes it’s one or the other.
I think weird things would happen if you allow both so I see the point but a shortcut like 2 or 3 clicks for DD might be nice for next gen.
Since it’s possible for DD to be the same as CC high due to battery and LED combo it could have 2 identical modes in a row if it worked that way i guess.
led4power
led4power's picture
EasyB wrote:
With the LD-x4, when DD mode is enabled in the menu, does DD replace the constant current high mode? Like if I have a 6A driver and am using with a low Vf LED so DD is say 12A, does enabling DD mode mean I don't have a 6A mode?
Yes, if you enable DD, high mode becomes real direct drive, there is no current limit anymore.
EasyB
Thanks. I was thinking of a driver for the SBT90.2 in my convoy L2 which ideally would have a 6A ~1hr regulated mode plus DD turbo.
Scallywag
Scallywag's picture
Last seen: 2 days 18 hours ago
Best of luck with the reopening. I’m excited for you (and to see new products).
Old Lumens Contest 2020 - Hand-made light category
ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20 | Baton S1
Boruit D10 w/ Quadrupel Fet+1/Anduril | EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Olight S15 Ti | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special | Thrunite T10Tv2
Supfire M6 3xXHP50.2, Sofirn C8F, Unfinished: Sofirn SP70, IYP07/Tool AAA hot-rods, Jetbeam E3S
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
contactcr
With all these current limited LEDs we are really missing out on these drivers. I hope you are able to get the store figured out before too long as it really feels like prime time for linear drivers. Who knows next year we may be flush with buckboost drivers and some obscure 9V LEDs or something.
led4power
led4power's picture
Linear drivers will stay in flashlight world as long as source of light are LEDs, they are smaller, cheaper and have higher power density compared to switching drivers and that will not change. Also linear drivers can have wider dynamic range of currents without large penalty in efficiency,for ex. it's much less challenging to make linear driver with output adjustable from 0.1mA to 20Amps.
Another advantage is driver quiescent current while driver is active - it can be in xx uA range, which is almost impossible for switching drivers (mA range), so runtime on moonlight/very low modes can be significantly better with linear drivers.
While switching drivers in theory have higher efficiency, in practice (single cell - 3V LED) difference in average efficiency is 5-10% typically - not as high as many here claim. Reason for that is battery voltage drop, so linear drivers maybe start with ~75% efficiency when battery is full, but as battery voltage drops efficiency raises to ~100%, so average efficiency is somewhere in between, depending on which mode you use the most. If flashlight is mostly used in lowest and highest mode, there is almost no difference in efficiency because switching drivers efficiency is not that high either on those modes.
Switching drivers are only option when number of cells in series is not equal to number of LED "dies" in series.
contactcr
And this is why we <3 you. I have a 2 euro coupon on your books so I need a reason to waste like $50. See you soon
World needs Led For Power!
id30209
id30209's picture
Last seen: 1 hour 26 min ago
Neven, any update?
WTB Titanium 4sevens 2xAA tube
led4power
led4power's picture
Still closed,sorry.
dorpmuller
dorpmuller's picture
Last seen: 6 days 12 hours ago
led4power wrote:
Still closed,sorry.
Aw, crap... just came over here to get some parts...
"I am the flashlight king! I can light anything!"
square74
Last seen: 15 hours 42 min ago
Hello,
is there something new with the shop?
I´m looking for a driver for SBT 90.2 with some (more) amps.
Powered out of 4 or 8 parallel Cells.
Thanks a lot.
led4power
led4power's picture
Hi, it's still closed.
