Led4power.com : LD-4 CC linear drivers, ILC-0/1 illuminated tailcaps, optics, MOSX, copper DTP MCPCBs...
1289 posts / 0 new
The_Driver
The_Driver's picture
Last seen: 2 days 53 min ago
DTP is a tiny bit better (I calculated how much brighter each LED got in percent), but in reality they are the same with this type of LED.
led4power
led4power's picture
Last seen: 1 hour 50 min ago
At higher amps (5+A) ouput quickly starts to drop on both pcbs because heatsinks are not fan cooled,so measurements are not very precise compared to lower amps. I will add fans for other LED tests.
I'm actually little bit surprised how close is mosX to DTP for XP package (even when calculations say the same) since this is package with smallest thermal pad,except osram oslons (but they are almost identical).
I will also test XHP35 HD in a few days, this LED has extreme power density when it comes to Watts/mm2 of thermal pad, but for this LED I actually expect some anomalous results (in a good way for mosX),we'll see what would happen.
Agro
Agro's picture
Last seen: 22 sec ago
How about testing fanless until the output starts to drop and then turning the fan on? I think fanless is more representative of what we see in flashlights.
led4power
led4power's picture
I did some calculations and XP-L did show some anomalies, on mosX at 6A output should drop close to 5% compared to DTP, but it dropped ~1.5%, I expect similar anomaly for XHP35,at least at similar power levels.
BTW, I don't have integrating sphere, I'm just measuring lux at some (constant) distance from LEDs, for identical type of LED relative output measurement should be correct.
led4power
led4power's picture
Finally added LD-B4HV
This is 2S/4S variant of LD-B4, please read description in listing for more information.
Two through hole pads at 10-11 o'clock are currently not in use (predicted for future e-switch use).
contactcr
Last seen: 1 hour 14 min ago
Sounds like a nice option to replace typical Zener modded drivers.
led4power
led4power's picture
Added HWB800 42x1,8mm IR filter (blocks visible light,passes IR):    HWB800 C8 filter
will34
will34's picture
Maybe a stupid question, but does the LD-B4 come with the PCB housing the external mosfet?
Or do I need to buy the MOSLED MCPCB, and reflow my own?
I plan to run 4× 219C parallel@6A, but not in quad format but in separated boards.
led4power
led4power's picture
LD-B4 doesn't have mosfet on its own board, mosfet should be on mcpcb. Because you want to use 4x 219c on separated boards, you should connect these 4 leds in parallel like with normal drivers and connect cathodes to mosfet drain that is mounted separated mcpcb. I there enough space for one 20mm mosled pcb (with mosfet only on that pcb) in your flashlight? LEDs can be on standard copper dtp.
led4power
led4power's picture
Example of LD-B4HV build with Convoy C8 and XHP50.2 powered by 2x18350 aspire cells: C8 XHP50.2
Brightness is good, around 3300-3500lm, but tint is so terrible that it "kills" high lumen feel.
Also,beam is pretty wide, this LED is definitely too big for C8 size, undomed version would be just the right size with good amount of throw and brightness.
led4power
led4power's picture
Just arrived:
will34
will34's picture
led4power wrote:
LD-B4 doesn’t have mosfet on its own board, mosfet should be on mcpcb. Because you want to use 4× 219c on separated boards, you should connect these 4 leds in parallel like with normal drivers and connect cathodes to mosfet drain that is mounted separated mcpcb. I there enough space for one 20mm mosled pcb (with mosfet only on that pcb) in your flashlight? LEDs can be on standard copper dtp.
Yes there is room for the extra MCPCB, but what I needed to know if the LD-B4 includes the MOSLED mounted on the MCPCB or do I have to buy it separately?
led4power
led4power's picture
LD-B4 doesn't include MOSFET, if there is enough space, you should order 4 bare xp boards for LEDs and one mosX board with MOSFET and NTC added, and LD-B4 of course.
will34
will34's picture
led4power wrote:
LD-B4 doesn’t include MOSFET, if there is enough space, you should order 4 bare xp boards for LEDs and one mosX board with MOSFET and NTC added, and LD-B4 of course.
Thanks, somehow I missed the “Add ntc+mosfet” option. My LEDs are already mounted on noctigons, but I might reflow one into the mosX to save space.
alberto7
Last seen: 1 week 2 days ago
Any plans of get a MOSLED ( mosX ) 4XP 3535 ?
led4power
led4power's picture
I have regular mosled (black), they have decent performance at 2-3A per LED,I don't have plans for mosX version.
tekwyzrd
tekwyzrd's picture
Last seen: 1 month 2 days ago
Ordered a LD-A4 early saturday to replace the flakey driver in my Astrolux S41 4x nichia. Looking forward to seeing how it performs. Opted for the 12A in case it ends up in a bigger host but plan to use it at 8A max if it finds its way into the S41. The S41 is currently a ‘shelf princess’ – it looks good with the baked brown and copper – but the driver and its click timing is a pita. I considered another H17F (which I am very satisfied with in my desert tan Convoy S2+, my current most-used light) or possibly a TA driver from Lexel (very happy with the 2s srk in my Chimera – amazing runtimes and often used as a nightstand light) but decided to give the LD-A4 a try.
Nothing travels faster than the speed of light with the possible exception of bad news, which obeys its own special laws. – Douglas Adams
led4power
led4power's picture
Posted new pcbs on web:
Bare 16mm and 20mm DTP PCBs:
16mm DTP 1,07€
20mm mosDTP 1,97€
They are compatible with Luxeon V (L1V1), Luxeon M, Luxeon MX, Luxeon MZ.
With installed LED:
Luxeon V on 16mm DTP
Luxeon V on 20mm DTP
Luxeon V on 20mm DTP (with MOSFET+NTC)
20mm DTP ("mosDTP") is not ordinary DTP pcb, this is hybrid version with both DTP pad for LED cooling, but also with 160um layer of Polytronics 12W/mK dielectric material, which makes it very expensive and kind of holy grail for MOSLED method builds.
Actually factory did not make that kind of pcb ever before, so it was questionable if it's even possible. Even with one of the best dielectrics available, thermal conductivity is not close to mosX, so mosfet max. power dissipation is lower, calculations show around 7Watts @60C and 10Watts @25C, this still should be enough for all builds. I'll do some tests to see how PCBs perform.
Edit: Dielectric material is extremely thermally conductive, much better than expected, tests indeed show ~12W/mK, at 10Watts of power dissipation in MOSFET, temperature rise is only~32C, so it can handle practically and known LED setup, dissipation is mosfet limited, not board limited.
Except Luxeon V, main reason I made these boards is Luxeon MZ, domeless quad-die 3V LED, which should do 3000-3500 lumens on single cell with good bin.
alberto7
led4power wrote:
I have regular mosled (black), they have decent performance at 2-3A per LED,I don’t have plans for mosX version.
Ok, thanks.
led4power
led4power's picture
Convoy M1 with Luxeon MZ 3V 5700K 90CRI led on mosDTP powered by 12Amp LD-B4:
Ceiling lumen show around 2200lm LED lumens which matches Koef3 test. Tint is very unusual because of combination of high CRI and hight CCT. Beam uniformity is best I've seen, just pure white light without color deviations. It looks like there is small donut hole in center of beam, but it's not very noticeable,in any case much less annoying than CREE XHP50.2 purple spot and greeny/yellow corona.
Test at 100mA:
i42dk
i42dk's picture
Last seen: 1 day 10 hours ago
Mini review of the LD-A4 3Amp + ILC-0
I wanted a nightstand light for a while now, with a illuminated tailcap. But havent got the skill/patience to add a bleed resistor to a driver.
So when i noticed the LD-A4 that had it built in, i ordered it immediately. And the ILC-0 (Default LEDs Current).
Also ordered a red Convoy S2+ because i like the look, and the metal switch.
The light is going to be a nightstand light, so it’s never going to see hard use, so the IPx rating was never an issue. I also got the 60* TIR lens from the convoy store to get a wide beam, as it’s being used indoors, on very short distances. Often in complete darkness, so no hotspots Smile
The internals came way before the host, so i mounted them in a BLF A6 host temporarily. To tryout the driver, settings n such.
I did run into the black gasket on the metal switch -issue. So until a clear gasket arrives in the mail, the light has a clear rubber button installed.
Also had to grind down the inner side of the driver retaining ring, as it was touching the LED +/- solder.
The ILC-0 (Default LEDs Current): is perfect for a nightstand light, it’s very very subtle, just the right amount of light.
The LD-A4: Very impressed. Genius menu/submenu setup. Very intuitive. The emitter is a Nichia 219C 4000K. So I like that i can choose between “Constant current and Direct drive on high mode” in the menu.
And the other options, very much can be changed in the menus.
The ONLY complaint i have against this driver, is the moonlight mode. There are three current settings for moonlight; 2.5mA, 5.0mA and 7.5mA. I wish a lower option was possible, as 2.5mA (in my eyes) is still too bright.
Other than that, this is by far my favorite 17mm driver Love
IMG Album: https://imgur.com/a/ndt1F
doubleone44
doubleone44's picture
Last seen: 8 months 4 weeks ago
Will you be selling the luxeon MZ? It looks great with the 90 CRI options available but can’t find it anywhere…
djozz
djozz's picture
Last seen: 48 min 1 sec ago
It is at Mouser and Digikey, but 90CRI and 3V just comes in 5700K.
alberto7
Anyone put the new springs “phosphor bronze 12×9×1mm” in both sides, in the driver and in tailcap? In other words, the usual host like Convoys will work ok with 2x of this springs or the cell(unprotected) will too tight?
I have 2 of this springs and in the “max compresion form” still not flat, in other words, not nearly as flat as steel springs or phosphor bronze springs (fasttech)
I hope you understand me, its difficult to explain this with a limited english like mine.
doubleone44
For me they worked but felt just a little too tight. I cut the down with some pliers and they work perfectly Smile
g_damian
g_damian's picture
Last seen: 3 hours 7 sec ago
I have 2x bronze springs in S2+. With 18650 tube they were very tight, but still acceptable with unprotected cell. With 18350 tube they were too tight, I have cut down one of them by half.
led4power
led4power's picture
i42dk wrote:
Mini review of the LD-A4 3Amp + ILC-0 I wanted a nightstand light for a while now, with a illuminated tailcap. But havent got the skill/patience to add a bleed resistor to a driver. So when i noticed the LD-A4 that had it built in, i ordered it immediately. And the ILC-0 (Default LEDs Current). Also ordered a red Convoy S2+ because i like the look, and the metal switch. The light is going to be a nightstand light, so it's never going to see hard use, so the IPx rating was never an issue. I also got the 60* TIR lens from the convoy store to get a wide beam, as it's being used indoors, on very short distances. Often in complete darkness, so no hotspots Smile The internals came way before the host, so i mounted them in a BLF A6 host temporarily. To tryout the driver, settings n such. I did run into the black gasket on the metal switch -issue. So until a clear gasket arrives in the mail, the light has a clear rubber button installed. Also had to grind down the inner side of the driver retaining ring, as it was touching the LED +/- solder. The ILC-0 (Default LEDs Current): is perfect for a nightstand light, it's very very subtle, just the right amount of light. The LD-A4: Very impressed. Genius menu/submenu setup. Very intuitive. The emitter is a Nichia 219C 4000K. So I like that i can choose between "Constant current and Direct drive on high mode" in the menu. And the other options, very much can be changed in the menus. The ONLY complaint i have against this driver, is the moonlight mode. There are three current settings for moonlight; 2.5mA, 5.0mA and 7.5mA. I wish a lower option was possible, as 2.5mA (in my eyes) is still too bright. Other than that, this is by far my favorite 17mm driver Love
Thank you for review! Lower current moonlight modes are possible, moonlight is dependent on two small (0402) resistors, so without hot-air and steady hand it's hard to do for most people, but if you want custom low current moonlight, please leave a note during future orders,and I will change resistors.
led4power
led4power's picture
doubleone44 wrote:
Will you be selling the luxeon MZ? It looks great with the 90 CRI options available but can't find it anywhere...
Digikey and Mouser have 90CRI 3V version, so I don't have plans for that LED, unless interest is big enough.I'm still considering 5000K 70CRI variant which should be available in T flux bin, but only if there is also enough interest.
i42dk
i42dk's picture
led4power wrote:
Lower current moonlight modes are possible, moonlight is dependent on two small (0402) resistors, so without hot-air and steady hand it’s hard to do for most people, but if you want custom low current moonlight, please leave a note during future orders,and I will change resistors.
Well well well, you have yourself another order coming soon Big Smile
So what mA should the target be? Perhaps someone else can chime in.
My benchmark is the ReyLight Pineapple’s moonlight mode, or the BLF Q8 Narsil moonlight level 2/7
alberto7
Thanks for the feedback!
What about 32mm 3× 3535 Mosled board with Fet and temp conexion? I think it will be popular for x6,c8 and others builds. I will I would buy a couple of pieces, for sure.
