Problem With moded Convoy S2+
6 posts / 0 new
rizky_p
rizky_p's picture
Last seen: 1 day 12 hours ago
So i moded my Convoy S2+ with BLF A6 driver, it was okay for 5 days until i put a freshly charged battery and while on turbo it dimmed to moon mode which i found out later that all modes are now in moon mode even the strobes. Not sure what is damaged, does the XML2 got damaged from direct driving?
Update: yeah the XML2 is damaged replace it with another XML and it is fine.
The board is not DTP, so do i need DTP board or XML2 is not meant to be pushed that hard?
Edited by: rizky_p on 08/13/2017 - 00:50
Lexel
Lexel's picture
Last seen: 56 min 32 sec ago
if you got any decent cell you kill a XML2 on a non DTP star by overheating
the other option is by too high current on newer XML2s the bond wires blew at 5.5A, which leaves a moon mode by the gold debries in the dome sometimes
if you go for a new LED why not use XPL HI?
those have at least not the problem with bond wires blow
rizky_p
rizky_p's picture
Ollie wrote:
rizky_p, How hard were you pushing it? I fried one in a similar manner in a light I was building. For whatever reason, the thermal glue decided to break loose, and it got really dim. This was with a DTP, but the MCPCB turned blue, it got so hot. Ollie
the last time i check it was pushing around 5A i think a bit more.
The cell was Samsung 30Q fully charged, yeah i think i blew the bond wires as the emitter now it just emits faint glows. I was thinking of swapping to XPL but i like the flood pattern of the XML and i already have XPL light which is BLF A6. Well i might resort back to 8×7135 driver instead of direct driving it or use XPL as you said.
Thanks everyone.
rizky_p
rizky_p's picture
Yes i just ordered the XP-L HD and will swap it and direct driving it, seems a better way to repair it. I think direct driving is just to much for the XML. Lesson learnt. Facepalm
Ollie wrote:
rizky_p, The XP-L HD has an XM-L-type beam profile, The HI is tighter, with limited spill. Ollie
rizky_p
rizky_p's picture
The XPL in BLF A6 is direct driven and it is in similar configuration. As Lexel said the XPL doesn’t have problem with blown bond wire when pushed hard.
Ollie wrote:
rizky_p, The XP-L has a lower forward voltage than the XM-L. This could result in magic smoke if DDing. Ollie
rizky_p
rizky_p's picture
i replaced the XML with XPL and no problem with DD-ing after 3 weeks now.
