Will these flat top batteries work in my HT35?
I ordered two-26650 KeepPower 5200mAh Protected High Discharge Flat Top batteries from Illumination Supply but now I am not sure that they will work in my two battery HT35.
I don’t own any other flat tops and while the HT35 has springs at both ends, will the batteries connect to each other?
If not, where can I find some top quality protected button tops cheap’est’?
I’m using those exact batteries. They fit fine.
Fantastic, so they have enough of a bulge or cap, that they make good contact with each other?
The ‘bulge’ is ~ 1mm (just under 1/16”). No issues using them in series.
Thanks, they were already in my mailbox and now I just put them in, and they work fine.
Hot diggity, this HT35 is a very impressive light.
