Haikelite MT07S CREE XHP70.2 Flashlight--now released
Another new powerful flashlight from HaikeLite.
MT07S 5000 Lumens , 750meter throw, full current regulation with a lot of nice UI function
Specifications:
Emitter: CREE XHP70.2 NW 4800K
Meterial: Aluminum Alloy , HAIII Anodising
Battery: 4x18650 (Recommend Sanyo 18650 GA 3500mah 18650)
Reflector:SMO Aluminum Reflector
Lens: Double Side AR coating Glass Lens
Bezel: Stainless Steel
Waterproof: IPX8
Max Output: 5000 Lumens
Max runtime: moonlight 1 lumens—60 days
Digital Full Current Regulation
Anti-reverse protection
Anti-discharge protection
Demension: 175mm x 66mm x50mm
Netweight: 470 gram
Accessories: landyard,O rings,Tripod Mounting Screw
Brightness Modes:
Low: 150 Lumens
Medium I: 450 Lumens
Medium II: 1000 Lumens;
High: 2200 Lumens
Hidden Turbo:5000~5500 Lumens (double click at any time)
Double click again:Strobe
Hidden Moonlight:1 ~3 Lumens (In off status A long click for 2 seconds to access moonlight. )
Thermal control Remove / Activation:MT07S comes with thermal control by default. If you want to remove thermal step-down , turn the moonlight mode on first and press the switch for 3 seconds to remove thermal control function. When you see a signal flash, it means the thermal control function has been removed, and MT07S will have no step down any more.
The thermal control function will recover when you cut off the power supply.
User Interface:
single click on; single click off
Long click to change modes ; Double click to Turbo ; Double click again to Strobe ;
With last mode memory
In off status a long click for 2 seconds to access moonlight mode ; another long click for 3 seconds to remove thermal control. Cut off the battery power to recover thermal control.
Lockout Function:
A single click followed by long click to lockout the switch. Repeat to unlock.
Power indication light: (LED indicator under the metal switch button)
100~50 Blue led on
50~9 Blue led flashes
Blow 9% Red led flashes
Camera setting : Shutter- 1.3S ; Aperture F4; IOS 200
MT07S XHP70.2 NW 4800K ; SMO Reflector
MT07S CREE XHP70.2 NW SMO Reflector VS MT07 Buffalo XHP70 CW 6500K OP Reflector
Nice :+1:
Would love to see size comparison between MT07 and MT07s.
So, where can you get it?
“750meter throw” now you got my attention :smiley:
what about the price?
I wonder if there is going to be an MT03S as well… in 4S configuration instead of the current 2S2P.
The effect in dark seen close to a car headlight, how much is it ?
Double brighter than car light. MSAP is 65usd~69usd
MT03 is not going to make a smaller version, considering the huge heat from 10 000 lumens MT03 size is good for heat sinking
how about triple XHP35 HI?
What happened to the website? http://www.haikelite.top/
Domain expired.
Really excited to see this new version. Will there be a model with cool white led?
Could someone clear up the specs on this light? Is this light 4500, 5000, or 5500 lumens and is the max throw 500 or 750 meters? Thanks.
looks good!
what you mean ” no step down”, the light maintains the output even it reachs 100*C ?
CW 5000lumens; NW—4500lumens. KCD shows 550meters distance
If you shut down the thermal control, the output will maintains even it reachs 80 degree C.
i like your flashlights mostly (tested 3 of them)
but idea to put XHP with SMO is strange.
i mean XHP performs best with OP.
may be you guy thought about XPL-hi or L2 there? good old decisions for throwers.
anyway, i`m glad to see that you keep on doing new stuff.
It's XHP70.2, not XHP70. The XHP70.2 performs well with an SMO - if focused well, cant see the black hole, and throw is definitely better. In fact if you are interested in max throw, we've been using SMO's with the XHP70 in the past. Now pretty much we are all switching to the XHP70.2.
I’ve got some 70 vs 70.2 in an L6 with SMO comparison pictures here.
If you look at the darker shots you can see the improved beam pattern of the 70.2. The dark hole is much reduced. When viewed at normal brightness levels the 70.2 appears very smooth. I got 830 meters on my light and I know my numbers are a bit lower than average.
