Mtnelectronics 17mm bistro driver with thermal step down control, seven spaced modes from moonlight to blindingly bright turbo direct drive.
Mtnelectronics XPL V6 3D LEDs (brightest bin possible and gorgeous 5000k neutral tint).
Copper MCPCB
Carclo narrow spot optics, 10507
Kiriba-ru BLF member modified copper spacer inside
Bypassed springs.
1K Bleeder resistor soldered to driver if new owner chooses to use lighted tail cap.
This light has all the good specs! If it is build up well I think the price is right. One question: how did you fit the XP-L leds under the Carclo optics? It does not fit without doing something.
(And one remark: if one thinks of making a lighted tailcap on this light, bistro drivers combined with high current triples are really finicky about that, you may end up with high resistors and dim tail leds.)
They fit if you ram them inside, i have triple with xpl v6 3d and it works fine, no damaged leds or anything just don’t try to remove the optic afterwards it might pull the domes off.
