Disassembly of 9V primary batteries
16 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 hours 45 min ago
DSC_7824
How is a 9V primary (alkaline or zinc-carbon) battery build? It must be 6 1.5V cells in series, but how is this done? I will check some different 9V batteries and see if they uses the same method.
This article got considerable longer than expected and I have only added comments to some of the batteries.
How is a battery build
First a bit theory:
Alkaline is build from:
  • Negative electrode: zinc (Usual a paste, because it is mixed with potassium hydroxide)
  • Positive electrode: manganese oxide
  • Between separator
AlkalineFlat
Zinc-Carbon (or zinc-chloride) is build from:
  • Negative electrode: zinc (Usual a plate)
  • Positive electrode: carbon + manganese oxide
  • Between (electrolyte): Separator with ammonium chloride
CarbonZincFlat
In both types of cells there must be a separator between the positive and negative electrode. This separator must allow the chemical reaction to take place, but block any current (Or the battery would short itself). This is usual two layers of fabric soaked in the electrolyte.
In a 9V battery the cells must also be chemically isolated from each other and connected electrically in series.
Alkaline is usual marked 6LR61 (round cells) or 6LF22 (flat cells) and zinc-carbon is marked 6F22
I assume batteries called “Heavy Duty” or “Super Heavy Duty” is zinc-carbon.
9VBatteryList
This list shows all the batteries I have looked inside.
Aerocell Alkaline
DSC_8312
There is no information where this cell is made, but a guess would be Malaysia.
DSC_9650
DSC_9653
DSC_9652DSC_9654
DSC_9655DSC_9656
A good view on the construction of a cell
Aro Alkaline (Malaysia?)
DSC_7993
This battery is not marked with any country.
DSC_8017
This construction is used on many quality batteries.
DSC_8018
DSC_8019DSC_8020
This battery has a US patent inside.
Budget Alkaline
DSC_8335
DSC_8339
DSC_9617
DSC_9618
DSC_9620
DSC_9621
DSC_9622
DSC_9632
DSC_9690
DSC_9634DSC_9691DSC_9631
DSC_9625
DSC_9629DSC_9630
Duracell Duralock
DSC_9692
DSC_9699
DSC_9700
DSC_9701
DSC_9702DSC_9703
DSC_9705
DSC_9706
DSC_9709
DSC_9707DSC_9711DSC_9713
DSC_9708
DSC_9712
DSC_9714DSC_9715
Duracell Industrial Alkaline (Malaysia)
DSC_8321
DSC_9672
DSC_9674
DSC_9673DSC_9675
DSC_9676
Duracell Procell Alkaline (Belgium)
DSC_7961
This must be one of the better Duracell alkaline batteries.
DSC_7958
It is not too old yet.
DSC_7962
Six cells and with a nice holders for the cells.
DSC_7963
I wonder if the dirty looks is from usage (Can it get around the metal can?) or from the factory.
DSC_7964
Oops, this battery do not look very good, it has leaked. At least it has stayed inside the battery.
DSC_7965DSC_7966
The top do also use welded strips for connection.
DSC_7967
As always the cells are in series.
DSC_7968
DSC_7972
The leak must have moved under the plastic for the cell to looks this way.
DSC_7969
The printing on the cell is rather difficult to read.
DSC_7971DSC_7970DSC_7973
The marks on top and bottom is from the welded strips.
DSC_7974
DSC_7975
The negative center pole looks like a nail. As usual it goes into some zinc paste with a bag around it.
Energizer Alkaline (USA)
DSC_7915
One of the big battery brands, how do they make the battery?
DSC_7903
They make it in USA and this battery is fairly old.
DSC_7916
When the metal is removed everything fall apart, all the connections are by pressure only.
The clear part at the bottom is some “soft” stuff to apply pressure.
DSC_7917DSC_7918
Both top and bottom are some paper with metal foil on it.
DSC_7919DSC_7920
Top is paper with foil around a piece of cardboard.
DSC_7921
DSC_7924
The cell looks nice for its age (no leaking), as usual (inside 9V cells) the can is plus and the top is minus.
DSC_7922DSC_7923DSC_7925
Notice that half of the can covers the insert with the top, this looks like a way to easier put it together.
DSC_7926
The top is a nail into the center of the battery.
DSC_7927
Where there is zinc (Rather green due to age) and a bag around it with the outside filled with carbon.
Energizer Alkaline 0914 Alkaline (Assembled in USA)
DSC_8349
DSC_9677
DSC_9679
DSC_9678
DSC_9680
DSC_9683
DSC_9684
DSC_9686
DSC_9681DSC_9685
DSC_9682
DSC_9687
DSC_9688DSC_9689
First Price Alkaline
DSC_9580
DSC_9588
Under the metal foil is a metal can.
DSC_9589
DSC_9590
At the bottom is an extra layer of some soft stuff.
DSC_9591
The battery had a protection strip across the terminals when new, this strip starts inside the can.
DSC_9592DSC_9594
The top connnections are isolated with some paper.
DSC_9593
DSC_9595
DSC_9598
DSC_9596DSC_9599
DSC_9597
DSC_9600
DSC_9601DSC_9602
Fujitsu G Alkaline (Malaysia)
DSC_7662
DSC_7663
DSC_7664DSC_7665
DSC_8047DSC_8048
It does not look like there is a patent on this battery.
Golden Power Heavy Duty Zinc-Carbon (China)
DSC_8314
DSC_8318
DSC_9643
DSC_9644
As usual connection is done by pressure.
DSC_9645
It looks like this battery has started to leak.
DSC_9646DSC_9647
The plus side is marked red, the minus blue.
DSC_9648
DSC_9649
The minus side is carbon and it is soft, on the plus side is some sort of rubbery chemical isolation on top of the Zinc plate.
GP Alkaline (Malaysia)
DSC_7828
A Chinese brand, but made in Malaysia?
DSC_7831
It looks exactly the same as other Malaysia made batteries.
DSC_7832DSC_7833
DSC_8041
GP Supercell zinc-carbon (China)
DSC_8313
DSC_8309
DSC_8311
This is one of the few cells with metal bottom.
DSC_9635
DSC_9636
Connections to the battery pack are only by pressure.
DSC_9637
DSC_9638
DSC_9639
The positive side is marked with orange color.
DSC_9640
DSC_9641
The cells are wrapped in two layer plastic, the inner layer is for each cell and on top of that an outer layer that keeps the pile together.
DSC_9642
The 6 cells.
Ikea Alkaline (China)
DSC_7638
The Ikea battery is different, it do not have a metal wrapper, but a plastic/metal foil wrapper.
DSC_7639
Here is the plastic box with the battery and the wrapper.
DSC_7640
Both connections are at the top.
DSC_7641DSC_7642
Because it is 6 small cells in series.
DSC_7643DSC_7644
DSC_7645
DSC_7646
They are about the size of AAAA cells, but watch out for polarity!
The can is plus and the top is minus.
DSC_7647DSC_7648
DSC_7649DSC_7650
DSC_7651DSC_7652
Kameda Alkaline
DSC_8008
DSC_8022
It is a plastic box with a thin metal foil for branding.
DSC_8023DSC_8024
Inside the box is 6 small alkaline cells.
DSC_8025
All in series.
DSC_8026
DSC_8027
DSC_8030
The film covering the batteries is isolating and rather sticky (It was difficult to remove).
DSC_8028DSC_8033DSC_8031
DSC_8034
The cells have vent holes, but there is a seal on the inside.
DSC_8032
MarQuant Alkaline
DSC_8328
DSC_8332
No country only a reference to a Nordic web shop.
DSC_9603
A plastic body with metal foil around it.
DSC_9604
The usual strips connection the cells to the terminals.
DSC_9606
DSC_9605
The plastic body is molded to keep the cells in place, this is done on all plastic cans.
DSC_9607
DSC_9610
DSC_9615DSC_9611
DSC_9609
DSC_9612
DSC_9613DSC_9616
Panasonic Pro Power Alkaline (Malaysia)
DSC_7653
Another brand with metal wrapper.
DSC_7654
It looks like the typical Malaysia construction.
DSC_7655DSC_7656
No patent in this battery.
DSC_7657DSC_7658
A few more details from the connection.
DSC_7659
DSC_7660
DSC_7661
Philips Extremelife Alkaline (China)
DSC_8342
DSC_9657DSC_9658
When I got the wrapper partially loose the batteries starting falling out, looks like the battery has leaked, but being a 9V it usual stays inside the battery.
DSC_9659
DSC_9660DSC_9661
DSC_9662
DSC_9671
DSC_9667
DSC_9664DSC_9666
DSC_9663
DSC_9668DSC_9669
DSC_9670
Philips Power Alkaline (China)
DSC_7982
Philips has more than one type of 9V batteries.
DSC_7979
This one is from China.
DSC_7985
It is 6 cells in a plastic box with a thin metal film wrapper.
DSC_7987
DSC_7990
An unmarked cell and as usual with plus on can.
DSC_7988DSC_7989DSC_7991
DSC_7992
Construction as usual with a pouch containing zinc and manganese oxide around it.
Powermaker Alkaline
DSC_8013
DSC_8035
DSC_8036
DSC_8038
DSC_8037
DSC_8040
Sanyo Alkaline (Malaysia)
DSC_7623
Lets start with this.
DSC_7624
It has a metal wrap around with a plastic bottom. Inside is a block that must be the 6 cells.
DSC_7625DSC_7626
The contacts at the top of the battery is connected to the top and bottom of the block.
The connections is to connection plates, these plates are then connected to the cells through some small holes.
DSC_8045DSC_8046
The top is marked with US patent 5691079
DSC_7627DSC_7628
There is different types of metal at the top and bottom.
DSC_7629
And the holes have a small O-ring to keep them sealed.
DSC_7631
Here are the 6 cells, stacked on top on each other in a plastic block.
DSC_7632DSC_7633
Here I have opened on cell, what is all the stuff in it?
DSC_7634
This looks like a block of carbon with a metal clamp for connection to it and a rivet for connection to the next cell.
DSC_7635
The carbon and the separators.
DSC_7637
The zinc is a paste and it is fairly black.
Sharpstar zinc-carbon (China)
DSC_7885
A unknown brand from China
DSC_7882
The manufacturer is printed on the battery.
DSC_7886
The name on the battery is just a thin plastic wraparound, hidden the metal.
DSC_7887
Removing the metal shows 6 stacked cells.
DSC_7888
DSC_7889
They are held together with plastic film.
DSC_7890
The connection to the cells are not soldered.
DSC_7894
There is some sharp points that is supposed to do the connection.
DSC_7891DSC_7893
On the plus side and on the minus side.
DSC_7896
After removing a layer of plastic the cells are mostly loose.
DSC_7897
Here are all 6 cells, the top and bottom cell has metal reinforcement. The other is either carbon or zinc.
DSC_7900DSC_7901
It is easier to see if I scratch a bit on the surface. It looks like the zinc has black layer, it must something to avoid making a cell with the carbon, but allow current to pass.
DSC_7898
Removing the last layer of plastic and the carbon breaks up.
DSC_7899
Here is everything: zinc plate, two layers of separator and carbon.
DSC_7902
Both the top and the bottom have a metal plate, it is obvious that something is needed over the carbon, but the metal plate at the zinc electrode, is that the zinc plate or an extra plate?
As can be seen here the is some conductive “rubber” between the zinc and an extra metal place.
Thumbcells zinc-carbon (China)
DSC_7912
Never heard of this brand before.
DSC_7911
But it is a company name.
DSC_7928
This looks like something I have seen in other cells.
DSC_7929
No welded connections, just a crown pressing down on the cell.
DSC_7930DSC_7931
That is the same for both plus and minus.
DSC_7932
DSC_7933
The cells, the smooths surface is zinc, the other carbon.
DSC_7934
A bit scratching shows it clearly.
DSC_7936DSC_7937
Top and bottom both have protective plates.
UNI-T zinc-carbon
DSC_7944
UNI-T is a Chinese instrument manufacturer, I doubt they make batteries. I expect they have bought this from another manufacturer and probably a Chinese one.
DSC_7945
This looks fairly standard for zinc-carbon.
DSC_7948
The connection with two crowns to press against the end of the battery.
DSC_7946DSC_7947
Red is plus and blue is minus
DSC_7949
DSC_7950
The 6 cells.
DSC_7951DSC_7952
At the red end is carbon, there is an chemical isolation layer between the plate and the manganese oxide.
DSC_7953DSC_7954
At the blue end is zinc, there is ah chemical isolation layer between the plate and the zinc.
Varta Industrial Alkaline (China)
DSC_7834
DSC_7839
DSC_7840
DSC_7841
DSC_7842
DSC_7846DSC_7847
The can is positive and the top is negative on this cell.
DSC_7844
DSC_7845
DSC_7849
The size is about AAAA, but due to the reverse polarity it is not a direct replacement.
DSC_7850
DSC_7851
The nail is the negative electrode.
DSC_7852DSC_7853
There is some plastic isolation between the negative (center) and the positive (can).
All the black stuff inside the can is manganese oxide.
DSC_7854
Between the negative and positive electrode material is a separator, it looks like a small bag. I have pulled it out here.
DSC_7855DSC_7857
Cutting the bag open shows that it is filled with Zinc powder for the negative electrode.
Conclusion
As can be seen there are 3 types of 9V batteries:
1) Zinc-Carbon with flat cells
2) Alkaline with flat cells
3) Alkaline with round cells.
The production of 1) is fairly standard and is always made in Chine, 2) is always made in Malaysia.
With the round cells there is much more variation, both in construction and where they are made/assembled.
As can be seen from some of the batteries 9V can leak like other batteries, but usual it stays inside the outer box.
Notes
US patent 5691079: This patent describes the tray shape used in the Malaysia manufactured batteries. It was applied for in 1995 and granted in 1997 and it is from a Danish company.
To get as many different batteries as possible I asked a some friends if they had any used 9V batteries, they had!
Review of 9V batteries, both primary and rechargeable
Disassembly of 9V LiIon batteries
Tumbleweed48
Last seen: 4 hours 22 min ago
Those six small cells are actually “AAAA”.
I once had a couple of penlight flashlights that used them, but the little cells were ridiculously expensive. I got in the habit of dismantling a fresh 9 v. cell to get six for less than the usual price of two, but you have to be careful about identifying + and -. I seem to recall that polarity was opposite to what the cells looked like.
HKJ
HKJ's picture
I am not sure they are AAAA, but they are very close to that size. On alkaline batteries the can is positive, on consumer batteries they are packed to the match the old zinc-carbon cells.
RollerBoySE
RollerBoySE's picture
Last seen: 17 hours 28 min ago
Very interesting, thanks HKJ!
Aren’t there 9V lithium primaries too?
HKJ
HKJ's picture
Yes, there are, but I did not get any of them.
MRsDNF
MRsDNF's picture
Last seen: 9 hours 26 min ago
Thanks for the effort HKJ. Lots of interesting info. Beer
My current and or voltage measurements are only relevent to anything that I measure.
Budget light hobby proudly sponsored by my Mastercard and unknowingly paid for by a hard working wife.
djozz said "it came with chinese lettering that is chinese to me".
zelee
zelee's picture
Last seen: 1 day 8 hours ago
i never knew there was several tiny batteries in a 9V battery, i though they were filled a whole like a normal AA and AAA
Don’t mistake my kindness for weakness.
I am kind to everyone, but when someone is unkind to me, weak is not what you are going to remember about me.
Ronin42
Ronin42's picture
Last seen: 1 day 19 hours ago
I am using two of the Soshine 650mah 9v rechargeable and so far i like them.
Tired of my flash meters always being dead (parasitic drain).
And what the are these?
ER9V 1200mAh Lithium Thionyl Chloride(Li SOCL2) Battery
PKCELL Li-SOCL2
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
raccoon city
raccoon city's picture
Last seen: 6 min 37 sec ago
Amazing photos and sweet information, HKJ!
KelG
Last seen: 2 weeks 4 days ago
Aro is a brand of Makro Netherlands.
Check the bar code on the batteries. If the number starts with 955, then it’s from Malaysia
Cheers
Kel
BLF = Buy Lotsa FlashlitesLaughing
Martini
Martini's picture
Last seen: 1 week 3 days ago
For years I carried a Streamlight Stylus that used three AAAA cells, and I also used to gut 9 volters to scavenge the innards to power my sick obsessive desire to see things at night.
scdaf wrote:
It’s important to have your restraints within walking distance, lest someone needs restraining. Wink
hIKARInoob
hIKARInoob's picture
Last seen: 1 min 1 sec ago
So if this 9V block is 6 × 1.5V, does this also mean that a 9V block is six times more likely to leak than a standard 1.5V battery? It should be right?
Ronin42
Ronin42's picture
Yes and no.
the P (of a leak) is 6x
but the P(of leaking is different) If the leak of a single cell is contained, then did the 9v leak?
I guess technically the P(of a 9v leaking) is the P(of all combinations of individual cells) in summation actually escaping from the 9v container.
patmurris
patmurris's picture
Last seen: 4 hours 26 min ago
Fascinating tearing off as usual. Thanks HKJ!
I new the big flat 4.5V had 3 AA serial (because i dismantled quite a few when i was a kid…) but never even though about how those compact 9V batteries where made! Have never seen a AAAA cell either…
Now i want a AAAA light! Facepalm
What about performance and reliability of those 9V? Some of the chinese ‘stacked’ cells look quite messy… like they are wrapped by hand (or foot?)… Flat Stare
snakebite
snakebite's picture
Last seen: 5 days 6 hours ago
i have torn some apart.the case has 3 pockets with a stacked plate cell in each.
like a lead acid car battery in miniature.
things get interesting if you open them and drop a torn up cell in water…
fire
liquidretro
Last seen: 4 days 18 hours ago
As always there are very informative and interesting to look at.
