LED drivers and Accessories you want, but don’t exist
492 posts / 0 new
beam0
beam0's picture
TBone wrote:
beam0 wrote:
When the 17mm boost driver is ready, where can it be purchased with firmware already installed? (ready to use)
I guess Lexel will build them so it would be like here thanks didn’t know he sells them directly.
"Over 2000000 hours (about 200 years) standby time"  (DQG Tiny 4th)
"27,157 results for zoomable flashlight" (ebay)
Flashy Mike
Flashy Mike's picture
Last seen: 1 week 2 days ago
Flashy Mike wrote:
I’m designing a Q8/SRK board, so there is space for a 6×1 row of connector pads. Found some info about pogo pin board design and will try this also.
Done:
contactcr
Last seen: 1 hour 16 min ago
Flashy Mike wrote:
Done:
Awesome, so this allows you to change firmware without removing or soldering anything right?
Flashy Mike
Yes, very easy to operate and reliable. Using this for a couple of weeks, no failure up to now. Soldering the pogo pins was a challenge though.
Lexel
Lexel's picture
Last seen: 6 hours 19 min ago
BLF Q8 2S/2P and 4S combinated driver 10 or 20A regulated output
XPL, XHP35, XHP50
MF01/MT03 20A regulated 4S Input 2S Output 10 or 20A
Blazer296
Last seen: 5 hours 53 min ago
Is there a blf style buck driver (good, customizable UI ), that can do 2s input and have 8-11A output for 3v led?
The MTNmax buck stops at 5.5-6A.
With some of the newer leds they dont really stand out from the crowd till they hit 7+A.
Lexel
Lexel's picture
I have such a driver in 30mm based on BLF GT design, the boards arrived yesterday
shrinking it to 22mm wont be possible with the limited choice of the MOSFET
Schoki
Schoki's picture
Last seen: 8 hours 41 min ago
I have a small problem reading this OpAmp datasheet here: https://datasheets.maximintegrated.com/en/ds/MAX9617-MAX9620.pdf
To be precise it’s the “Output Voltage-Swing”.
There are multiple values given in the table with various resistor values, but when you scroll down to the graphs, there are two called:
1. OUTPUT-VOLTAGE SWING HIGH vs. TEMPERATURE
2. OUTPUT-VOLTAGE SWING LOW vs. TEMPERATURE
Now these values from the graphs are much lower than those from the table. For the “table values”, there is a resistor RL connected to the OpAmp, but I don’t know how it is connected.
Is RL connected between the output and VDD/2, to show how near the OpAmp can get to the rail with a load on it, and the graphs, when there’s no load?
Texas_Ace
Texas_Ace's picture
Last seen: 30 min 25 sec ago
I am far from an expert in data sheets but I have learned that the graphs generally do show better numbers then the official ratings. This is due to the built in error margin that the companies build in the way I understand it. Also most of the official ratings are max ratings, so what they guarantee the components will not go over.
Thus the real world specs can generally be a fair amount better in most cases and these are what you see in the graphs.
In “real” manufacturing they design off the max ratings and then just get a nice bonus if the parts preform better.
Also I noticed this at the top of the graphs page :
Quote:
VDD = +3.3V, VGND = 0V, outputs have RL = 100kI connected to VDD/2. TA = +25NC, unless otherwise specified.
So looks like it has some resistance connected in the graphs as well.
Schoki
Schoki's picture
But there is such a huge difference, 11-12mV compared to ~0.3mV
Texas_Ace
Texas_Ace's picture
Yeah, I am not sure this is the case, just my best guess. I have seen pretty big differences before and the ratings are listed as max ratings. But that is a bit extreme I admit.
The_Driver
The_Driver's picture
Last seen: 4 hours 33 min ago
The new 17mm high-power boost driver will open up some interesting possibilities for triple lights. It will be possible to use high-Vf LEDs like the Cree XP-G2 and Osram Black Flat in a triple configuration with a high current through each LED.
Texas_Ace
Texas_Ace's picture
The_Driver wrote:
The new 17mm high-power boost driver will open up some interesting possibilities for triple lights. It will be possible to use high-Vf LEds like the Cree XP-G2 and Osram Black Flat in a triple with a high current through each LED.
Yep, I plan to swap out the driver in my EDC with this one for just that reason. I still have a hard time finding a better tint then my mixed tint EDC. Although the 90CRI XHP50.2 I have been playing with looks promising, if I could find it in 4500k it would be perfect.
contactcr
Why is xpg2 so interesting when we have xpl hi, nichia, sst40, samsung, luxeon? What am i missing here?
Texas_Ace
Texas_Ace's picture
Not sure on the XP-G2 in a triple, I have xp-G3’s in my EDC right now as they provided the best high CRI tints I have found so far.
I have high hopes for the XHP50.2 though, early tests say it should be able to give around 1500 more lumens OTF compared to my existing setup and have technically higher CRI (mine is around 85cri right now).
If I could just find a 4500k 90CRI xhp50.2 it would be perfect based on tests with a 4000k and 5000k 90CRI xhp50.2.
The_Driver
It has a higher luminance at the same current. Instead of 7A you can drive it with 4A for the same throw.
The_Driver
t18d16
t18d16's picture
As LD-40 is discontinued, there is currently no buck driver for red leds running from a single li-ion cell. (In the hobbyist laser land, they have flexdrive for current upto 1A) It is really a shame since efficiency of red leds keeps improving and we still drive them with 7135s. I have plans for building XPEEPR (deep red, 51% wpe) triple using a Sofirn C8F and run it at 2-3A.
I have searched a lot on TI, Linear, Onsemi – the best chips are made only for CV type application (2.5V rail), LTC3561A and LTC3612 are very promising. To design a pcb from their app note is a huge challenge for me (could take a year), because I could not just copy the app note circuit, I also should use another fet and mcu to support momentary switch and modes!
EDIT: Maybe using an Ledengin lz-4 (4 deep red dies in series) in a Convoy L6 is a better way to go, but that’s too expensive.
Schoki
Schoki's picture
I plan to make a buck driver for an EDC build for myself (after I finished the 17mm boost circuit). I could make a 17mm version as well. It would be 1S only though.
Cula
Cula's picture
Last seen: 14 hours 18 min ago
Do you plan to make a boost driver for XHP35? If so, will it boost from 1S, 2S or both?
Schoki
Schoki's picture
Yes, and both Thumbs Up
Cula
Cula's picture
Very nice Beer . What max current do you expect?
Schoki
Schoki's picture
roughly 6A with 6V config, up to 3A with 12V config
Cula
Cula's picture
Waiting impatiently Wink ….
The_Driver
Will it have the custom firmwares normally used here?
Agro
Agro's picture
Last seen: 2 min 57 sec ago
Initially Bistro HD, as to others – there’s hope that at least some will be ported.
eas
eas's picture
Last seen: 1 week 20 hours ago
3A @12V and 1-2s will be a nice option to have. I like the H2-C based XHP35 HI light I built, but I’d really like to push it past 1.5A.
Niko
Last seen: 7 hours 31 min ago
Looking for Emisar D1 firmware, simple 3-4 modes, temperature controled
Schoki
Schoki's picture
Really good thread about loneoceans’ new driver: http://budgetlightforum.com/node/59137
This driver has many similarities compared to the driver I’m currently developing (with the help of some others).
The_Driver
I have another wish:
A compact boost driver for COB LEDs in the 30-40V range with all the usual features of flashlight drivers.
