LED drivers and Accessories you want, but don’t exist
495 posts / 0 new
Barkuti
Barkuti's picture
Last seen: 54 sec ago
The following is of course just an opinion. Take it, build upon it or leave it.
Lots of people here are keen with the MOSFET driver idea. Such idea is not a fit for everyone or any case. It is unregulated and overall limited, and requires careful assessment of all components as there's chance to make the emitter operate with too much current (past optimal zones) or even fry it. Of course I can understand the people here aims for hybrid drivers, but this would require for the driver to know when to switch operating modes… ( ͡° ͜ʖ ͡°)
As far as I understand the MOSFET thing is clearly superseded with a proper linear design, a MOSFET linear design like led4power designs or the LD-25 (reviews: there and here). I also gets rid of PWM annoyances.
A proper linear design uses a suitable MOSFET and a current sense element. Selecting a proper tiny value current sense element is key, notice how the latest LD-25 does with just 10mΩ. This is key for high power output. Since dissipated power at the sense element is P = I² × R even smaller values may be due.
Anyway, I'd say the best option is a buck boost design. If you really like to go nuts and “fry” your emitters, oversizing the components and removal of the whole constant current logic could be done for regulated drivers, and leave you selecting desired output voltages for the different modes through some way like adjusting current in LD-25s (a constant voltage supply).
Cheers Party
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Agro
Agro's picture
Last seen: 1 min 8 sec ago
Agro wrote:
Agro wrote:
I just stumbled upon a tool to program attiny1616 and other tinyAVR chips:
https://github.com/mraardvark/pyupdi
Here’s Arduino firmware that can turn it to avrdude-compatible ATTiny1616 programmer:
https://github.com/ElTangas/jtag2updi
It seems there’s some work on updi in avrdude:
https://github.com/facchinm/avrdude/search?p=1&q=updi&unscoped_q=updi
I see on avrdude that some people are using it though I fail to understand the details.
Barkuti
Barkuti's picture
Maybe missing PIC microcontrollers' love: programmers, people making ports of existing code for other chips and such.
Plenty of PIC micros in many drivers.
Regarding software names, calling software Anduril or Narsil just sounds @#$% to me. I prefer descriptive and senseful terminology, plus detailed version numbers.
MascaratumB
MascaratumB's picture
Last seen: 11 min 31 sec ago
Are there any 15mm drivers with Anduril installed?
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
Texas_Ace
Texas_Ace's picture
Last seen: 9 hours 13 min ago
There are some TA 15mm designs that could have anduril flashed to them.
Lexel most likely offers them pre-made as well.
MascaratumB
Hum, what do you mean by pre-made? Ready to install the FW? I don’t know how to install it and have no means install the FW.
Also, another question about those TA drivers: do they work without the 7135 chips in the bottom (spring side)?
I have some lights in which I could use 15mm drivers with only the spring (or no spring) on that side, as the chips would interfere with internal space/battery.
Thanks for the reply in advance!!
OL Contest 2019
GIVEAWAY: 1 / 2
Texas_Ace
Texas_Ace's picture
It should be able to work without the bottom side 7135’s but would need the right mode group selected to do it.
Lexel makes drivers that are ready to install in small quantities.
I generally don’t bother with making drivers to sell unless I can sell at least 25-50 of it, just not worth the setup time for less then that personally.
MascaratumB
Thanks for your reply TA! I get what you say, and I would need to check with Lexel if he could make those drivers as it would imply more work!
I also know that MTN has those flat sided drivers ready to install, but I didn’t see them with Narsil or Anduril, only the Ramping IOS from the D4 on them.
Thanks again! Thumbs Up
OL Contest 2019
GIVEAWAY: 1 / 2
gchart
gchart's picture
Last seen: 4 hours 34 min ago
I’ve been using the new TinyAVR Series-1 chips (412, 416, 817, etc) in some recent designs, including my "smart" tailcap.
They’re pretty neat, but the difficulty is that pretty much all flashlight firmware up to this point is for the 13A / 25 / 85 chips. I wrote a new barebones NarsilM-inspired firmware for the Series-1 chips earlier this week. And last night, I converted Tom_E’s RampingIOS to run on them (not fully tested yet though). I hope to be designing a single-sided 5A linear driver around these chips pretty soon for the Emisar series (with the D1S + Flat White in mind). I want to confirm another design is working properly first (a 17mm single-sided linear 3A driver). I really like the single-wire debugging and programming that the UPDI provides. And it makes the “programming key” pad footprint smaller and more manageable. They have a lot of good peripheral options, too: internal VRef and temp sensing (which the 85 does have), RTC, TWI/I2C, 16-bit clocks, flexible low-power options, QTouch, etc.
AVRDUDE has added support for UPDI, but not in the published compiled versions yet. So if you want UPDI, you have to compile it yourself. I also ordered the JTAG programmer that El Tangas is working with, but also haven’t tested that yet. For now (until I get fully up to speed) with the Series-1 chips, I’ve been using Atmel Studio 7 for flashing, done via a ATtiny416 Xplained Nano dev board set up for off-board programming.
joechina
Last seen: 22 hours 19 min ago
Barkuti wrote:
Maybe missing PIC microcontrollers’ love: programmers, people making ports of existing code for other chips and such.
Oh, it is descriptive.
Narsil was forged by elves and Andúril is reforged from Narsil.
Barkuti
Barkuti's picture
Excuse me but,
Lightbringer
Lightbringer's picture
Last seen: 4 hours 32 min ago
I don’t even wanna know…
KawiBoy1428
KawiBoy1428's picture
Last seen: 25 min 29 sec ago
Big Smile ……………………………………… Shocked ……………………………………… Facepalm
KB1428 “Live Life WOT
Tom E
Tom E's picture
Last seen: 6 days 9 hours ago
Come on, you guys know what the "E" stands for in my name? wink
MascaratumB
Tom E wrote:
Come on, you guys know what the “E” stands for in my name? wink
E for this? Big Smile
OL Contest 2019
GIVEAWAY: 1 / 2
JasonWW
JasonWW's picture
Last seen: 16 hours 56 min ago
Edison?
Click this to go to signature links.
Lightbringer
Eggplant?
BlueSwordM
BlueSwordM's picture
Last seen: 17 hours 35 min ago
Magic electronic Elf.
Smile
Magic Engineer Elf.
Barkuti
Barkuti's picture
Whaaat? Who has removed the picture link in my above post? There Gimli was, asking an important question concerning the above referenced cheap knives who wouldn't have lasted even 5 minutes in Knife or Death. Big Smile
If you wanna check it out, click/tap (not safe for work Wink warning).
P.S.: E for excursionist. Wink
BlueSwordM
Ok what the absolute madman is this pic…
You shouldn’t have said it’s NSFW. Now I can’t get that image out of my mind now.
Lightbringer
The Gods Of Good Taste? I’m still trying to unsee it… Sick
Agro
Agro's picture
Tales of Marvelous Emitters?
So E goes for Emitters.
Quadrupel
Quadrupel's picture
Last seen: 2 hours 16 min ago
I want 21mm, E-swich, efficient, stabilized, running Dark Horse (ZB replica) firmware on attiny85 driver, a replacement for H03 stock driver ;))
matula
matula's picture
Last seen: 1 week 4 days ago
sound activated flashlight, so I can strobe four thousand lumens at a car that doesn’t give me right of way when I have it, just by shouting at them.
I mean it does exist, just not compact and out of the box:
https://youtu.be/ZW1IIYxXMdE
JasonWW
JasonWW's picture
The Manker Godmes was a Bluetooth controlled flashlight that responded to sound, or at least blinked to music. Ahead of its time. No longer in production, though. I just thought I’d mention a cool light most folks don’t know about.
https://www.banggood.com/MANKER-GODMES-3Cree-XP-L-3000LM-Bluetooth-APP-Control-LED-Flashlight-p-967180.html?cur_warehouse=CN
Godmes
TheOnlyDocc
TheOnlyDocc's picture
One question. Do we have a driver available on BLF that would be able to drive 2× 3V or 6V leds (seperatly and/or together)?
Or 2x tripples with SST-20 leds (again seperate and/or together)?
Only gathering information at the moment.
New WildTrail (former LuckySun) D80v2 Sale has Started http://budgetlightforum.com/node/66255
contactcr
Last seen: 8 hours 44 min ago
The BLF lantern is two separate banks of 7135’s with a custom Anduril firmware that can do one channel or both channels combined to mix tint. I think Lexel even created a variation with a FET mode too but the current LT1 doesn’t have any FET.
TheOnlyDocc
So 2 channels but only with 7135 banks. The perfect driver for the thing i had i mind would have a 7135 chip for low on both leds and a fet for full power for both leds. So 4 channels in total. Would it be possible to do something like this with the attiny chips we usually use? Light would be a e-switch light (with lighted switch controlled by the mcu).
I am not sure if the attiny chips we usually use have enough output pinns for something like this
DavidEF
DavidEF's picture
Last seen: 11 hours 22 min ago
It’s technically possible with ATtiny85, but not very good. Since the ATtiny85 has only three hardware PWM outputs, the fourth output (or all of them) needs to be PWM’d by the firmware. Better chips are available, though. And some of the BLF members are working with some of those better chips. ToyKeeper has been working on a ATtiny1634. I can’t be sure, but it seems somebody said that the BLF LT1 uses that. It has more pins, more hardware PWM channels, and other features compared to ATtiny85.
- The YKK Philosophy
Agro
Agro's picture
DavidEF wrote:
ToyKeeper has been working on a ATtiny1634. (…) It has more pins, more hardware PWM channels, and other features compared to ATtiny85.
And is cheaper and takes less board space.
Pure upgrade though Narsil doesn’t support it yet.
