IR Illuminator Deals [Valid for 24hrs]
9 posts / 0 new
thulfiqar
thulfiqar's picture
Last seen: 4 months 1 week ago
Hi ,
I found these deals on Aliexpress (Valid on 11.11)
1- Osram SFH 4715AS AS Conversion Kit 8$
2- OSRAM 4715AS LED Reflowed on 20mm or 17mm MCPCB 6.92$
3- Uniquefire UF-1505 + Osram 4715AS 19$
if you know more deals please post them Below
Edited by: thulfiqar on 11/10/2017 - 17:07
Lexel
Lexel's picture
Last seen: 16 hours 23 min ago
for reflector lights the 4716AS would make much more sense, as the 4715 focuses a lot light which never hits the reflector,
while the shallow dome of the 4716 is less than Cree LED domes
for good lumens when zoomed the 4715 is good, but for small hotspot and lux the 4716 is better
http://www.kaidomain.com/p/S026838.Osram-SFH-4716AS-IR850nm-Infrared-Red...
also be aware that if you use a DTP star it must be isolated from the battery minus, as the thermal center pad is battery plus
thulfiqar
thulfiqar's picture
Thanks for the info lexel
I just noticed a difference between OSRAM 4715AS and 4716AS
The 4716AS Has a lower radiant intensity “300 mW/sr at 1 A dc”
The Radiant intensity in 4715AS Led is “780 mW/sr at 1 A dc”
What does the Radiant intensity do ?
Lexel
Lexel's picture
radiance intensity is simply how focused the bare LED is
the 4715 focuses the light in a narrow cone of 60°
while the 4716 has a wide angle of 150°
mouser has higher bins of em as new products
http://www.mouser.de/ProductDetail/OSRAM-Opto-Semiconductors/SFH-4716AS-...
4715AS is the highest bin
http://www.mouser.de/ProductDetail/OSRAM-Opto-Semiconductors/SFH-4715AS-...
thulfiqar
thulfiqar's picture
When I reflow leds I usually don’t care about polarity .
Last week I got 2 DTP stars from Simon.
if I connect the red wire on the minus side of the DTP star , the Battery will catch fire?! Shocked
Didn’t know that , Thanks for the Heads up
Lexel
Lexel's picture
thulfiqar wrote:
When I reflow leds I usually don’t care about polarity . Last week I got 2 DTP stars from Simon. if I connect the red wire on the minus side of the DTP star , the Battery will catch fire?! Shocked Didn’t know that , Thanks for the Heads up
The polarity does not matter
The whole star has the positive voltage and with most hosts have the battery minus on the body you get a direct short
luminarium iaculator
luminarium iaculator's picture
Last seen: 3 hours 18 min ago
!{width:70%}http://www.metronixlaser.de/bilder/flashlight/IMG_2921.jpg!
This emitter(4715as) has really crazy throw comparing to any de domed and modded flashlight and all that at about 1,5A current draw… Isn’t that a dream for our classic white emitters?
Example: This emitter in a 50mm aspheric and in combination with average night vision(first gen) gives around 800-1000m of visible throw… It is not really comparable; but when I compare that to what can I actually see at night without night vision and with classic led light I would need at least 500 kcd to achieve same performance…
Modding is making something how you want it to be, not how it comes stock...
Old-Lumens
thulfiqar
thulfiqar's picture
Hi ,
Alen
Last seen: 10 min 18 sec ago
any experience with this seller?
are good 1505 with real Osram 4715AS?
