BLF GT (preliminary) modding thread
341 posts / 0 new
pscal
Last seen: 2 days 11 hours ago
After some more focus tuning and final assembly, at 20 meters, my modded GT measured at 3,508,000 lux! Super!!
(Beamshots next!)
Texas_Ace
Texas_Ace's picture
Last seen: 16 hours 24 min ago
Not bad at all, makes me want to give it a try. With that new “flat black” that has a neutral thermal pad, it would be far easier now. Could even use the stock driver I think with a minor mod.
What driver are you using?
pscal
I’m using Lexel’s BLF GT Oslon driver set at 4.5 amp max. In the case of the GT, the neutral thermal pad is not a big advantage because the light body is not used for the return.
Modded GT
The Sceptre
In person, the beam from the GT appears to go farther. It’s quite impressive.
WillyD
pscal….very awesome mod! I love it! I was pretty happy with my GT until I read over your mods. Now I’m gonna end up cracking my open before long. Thanks a lot! Wink
Oh, I would love to see some beamshots of a water tower or building from some distance. Would be even better to compare with a stock GT.
pscal
Thanks! I no longer have a stock GT for comparison – best I can do is an MF04s. Getting beamshots is also challenging for me right now because I have a toddler and an infant that dominate the night hours. But, if I can get away, I’ll try to get some shots worthy of this GT.
Enderman
Enderman's picture
Last seen: 1 week 2 days ago
pscal’s aspheric builds are right up there with deft-x quality, but with 3x more lux, great job Big Smile
Kit Latura
Last seen: 16 hours 35 min ago
I haven’t seen another video about how to open the GT. So I hope you find it useful.
KawiBoy1428
KawiBoy1428's picture
Last seen: 4 hours 9 min ago
Lucky fellow. Usually the head breaks loose before the bezel, or did you have to reef (tighten the living hell out of) the head first Big Smile
I don’t bother with the bezel anymore, just removing the head get’s me to the area I need to make changes too. Less chance of crap falling into the reflector, specially from the loctite bits from the bezel, if I need to shim the reflector on the XHP35HI GT, then I just break the bezel loose, I don’t remove it, that way I can tighten the head with out all that added pressure on the lens.
KB1428 “Live Life WOT
Funtastic
Funtastic's picture
Last seen: 13 min 46 sec ago
Can someone point me to a thread on changing the XHP35 HI version to the XHP70.2? Would like to know the process for my BLF GT
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
JasonWW
JasonWW's picture
Last seen: 8 hours 12 min ago
Have you ever changed a driver or led? That’s all you basically do.
Check VOB’s video here.
