S2+
15 posts / 0 new
aL1
aL1's picture
Last seen: 6 months 1 week ago
S2+
I just got a Convoy S2+ with a biscotti driver, XPL HI, a lighted tailcap, and a clear rubber boot-
Lighted tailcap looks like it has two resistors marked 361-
Running a Samsung30Q button-top-
When I first got it and turned it on, it seemed to work fine, moon, medium, high, strobe, biking, battery-check, sos-
So I charge-up the 30Q, and the torch is whacked....I click and just low, I click, and nothing....then I noticed whenever I loosen the tailcap, then tighten it, it goes through the Group perfectly.
What is wrong with it?
EDIT: driver or switch
Edited by: aL1 on 09/12/2017 - 09:53
AlexGT
AlexGT's picture
Last seen: 1 min 24 sec ago
Have you checked that the switch retaining ring is tight and the driver retaining ring is tight too?
aL1
aL1's picture
The switch retaining ring is tight and the driver retaining ring is soldered-in-
Phlogiston
Last seen: 53 min 1 sec ago
It may be that the lit tailcap is interacting badly with the Biscotti driver. See here:
http://budgetlightforum.com/comment/1141878#comment-1141878
and here:
http://budgetlightforum.com/comment/1141883#comment-1141883
Do you have any S2+ lights with a normal, unlit tailcap? You could try the unlit tailcap and see whether it works that way.
aL1
aL1's picture
S2+ Video
L4M4
L4M4's picture
Last seen: 10 hours 38 min ago
Just bridge from the minus pole of the Battery directly to the flashlight case (Plier, Knife, Tweezers, cable) – you will see if the light lights up or not Wink
Phlogiston
Hmm, strange.
Is the pill screwed in tight? I know you said the driver is soldered in, but the pill itself screws in and can sometimes come loose.
Do you have a flat-top cell to try, in case the button top is too long or the spring is skittering off it?
aL1
aL1's picture
L4M4 wrote:
Just bridge from the minus pole of the Battery directly to the flashlight case (Plier, Knife, Tweezers, cable) - you will see if the light lights up or not ;)
I'll try that, thanks-
Phlogiston wrote:
Hmm, strange. Is the pill screwed in tight? I know you said the driver is soldered in, but the pill itself screws in and can sometimes come loose. Do you have a flat-top cell to try, in case the button top is too long or the spring is skittering off it?
Late now, tomorrow I'll put in a flat-top batt, thanks-
I'll update!
aL1
aL1's picture
Got it to light-up with a flat-top, good call Phlogiston, but it doesn't respond to any configuration settings, stays in one group only-
The flat AW worked, the flat HG2 was N/G-
This flashlight is not working-
Anyway, thanks everyone!
MascaratumB
MascaratumB's picture
Last seen: 5 hours 32 min ago
Some weeks ago I received a biscotti driver for a mod, from Simon and it had the same issue, it always turned ON on low and occasionally it switched to another mode/output, but it wasn’t possible to change it by pressing the tailswitch. Then I went to check the driver and a piece was missing. Maybe there is something missing there too…
DB Custom said: "Hide your billfold, cut up your credit cards... you're a perfect candidate for full blown flashaholism and will soon need dedicated flashlight cabinets. [...] Have fun! Modding is next... :P"
REVIEWS : Amutorch S3 - XPG3-S3 /  AM S3 vs Neal 219c  /  Amutorch AM30 - XHP70.2 / Nitefox UT20 / Sofirn SF14 & SP10A / Sofirn SP32A / Sofirn SP10B / Odepro KL52 / Acebeam H20 / SS AAA / Wuben TO10R / BlitzWolf BW-ET1 / Odepro B018 / DQG Slim Ti
Mods and tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7                         Convoy S2+ TIR Lenses on: XML2 / XPL-HI                             Others: Convoy S2+ Mini (Biscotti 3 & 1*7135)
Sofirn K6 Discussion: 1 / 2 / 3                                Triple TIR Lenses & XP-G2                                     MY GIVEAWAY = ACTIVE
aL1
aL1's picture
Maybe the problem!
MascaratumB
Glad it helped and I hope you solve the problem and put it back to work Thumbs Up
aL1
aL1's picture
I'll look at it, thanks!!
Lexel
Lexel's picture
Last seen: 9 hours 29 min ago
Looks like the 19uF capacitor is missing
390 ohms as tailcap LED resistor is quite low
aL1
aL1's picture
That is not a photo of my driver, but thanks anyway smile
