p60 (WF-504B) switchs
5 posts / 0 new
Manual Man
Last seen: 2 years 1 month ago
Hello guys... I am going to make a purchase from DX tomorrow morning (including a Trustfire X9 Smile) and was wondering which of the following switches would fit best in the Ultrafire WF-504B and which is the most durable. The only part of the torch I do not trust is the switch (current one is broken).
http://s.dealextreme.com/search/switch.html?category=917
Edit: if you know of anywhere else that sells good quality switches (at a reasonable price) or ones that are mod-able to make them reliable I would love to hear where. Cheers
Thanks for your time.
Edited by: Manual Man on 11/14/2011 - 04:46
fran82
Be carefull, if I am not wrong there are 2 different versions of the 504b (old and new) and I dont know if the swtich is identical on both.
Diassembly yours and look at it. Then, it should be one of the following:
These require soldering
http://www.dealextreme.com/p/clicky-switch-for-flashlights-17-8mm-5-pack...
These does not require soldering:
http://www.manafont.com/product_info.php/part-replacement-tailcap-switch...
http://www.manafont.com/product_info.php/ultrafire-replacemnet-tailcap-s...
This post/thread "may" contain referrals, a little contribution I "earn" in form of points ONLY if you buy the item. The purpose is to redeem items using the points and then making reviews of them in the forums to shar
Manual Man
Thanks for the reply... well after playing round with the switch a bit (while measuring it up) I found out it is not actually broken... seems there is just bad contact between the retaining ring and the switch. Go figuar
Your reply did in a way fix the problem though.. it made me measure up the switch. It would have sucked to order a switch only to find it did not fix the problem. Now all I have to do is figuar a way of keeping the retaining ring and switch in constant contact.
Cheers
fran82
You have been lucky!
Manual Man
I have indeed. All I had to do was sand down the isolator in the retaining ring and hay presto... works fine.
