I have taken a lot of lights apart, usually trying to fix them.
I’ve wondered if anodizing is conductive or not.
In the negative current path (using the body of the light), some lights seem to use the body threads, others use the end of the tubes, with the anodizing removed (on purpose or not, i don’t know) and touching a gold circuit board contact.
Are there types or thicknesses that define conductivity, or is it just always the same, and if so, what? Conductor or insulator?
No, sometimes it is used as dielectric layer in multi-coated electric (and military) cases.
Electric conductivity cant be tested with you real conditions. Tests are made with high voltage AC while you are going to use low voltage DC. If you are sure with mechanical quality of this anodizing, test it once with DMM and believe that it wont conduct electricity.
Agreed, not conductive. I bought a Convoy M2 host and after I put everything together, it would not turn on. At first I was worried I screwed something up, like mixing up the positive and negative wires. But then I noticed that about a quarter of the end of the battery tube had anodizing on it. It didn’t seem like that was the culprit, but after sanding it off the flashlight worked.
Anodizing essentially”grows” a layer of Aluminum Oxide on the surface. Aluminum Oxide is not electrically conductive, but has a relatively high thermal conductivity.
If you were able to clean the part with acetone and got conductivity then it was for sure NOT anodized. You have to scratch through the anodize to get some conductivity.
