Just asking - who would be interested in a 2s4p battery tube for the Q8
17 posts / 0 new
tekwyzrd
tekwyzrd's picture
Last seen: 1 hour 50 min ago
A 2S4P tube would facilitate mods such as quad xhp or mt-g emitters or 2s2p xml or xpl configurations. This may be the prime moment to pursue this option – while production of the Q8 is in progress.
tekwyzrd
tekwyzrd's picture
I’d buy 2 and another Q8.
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 hour 11 min ago
Ditto, same for me too! Thumbs Up
KB1428 “Live Life WOT”
The Miller
The Miller's picture
Last seen: 3 weeks 1 day ago
Interesting.
This mainly is another tail PCB and tailcap with rotating PCB to keep alignment right, right?
tekwyzrd
tekwyzrd's picture
The Miller wrote:
Interesting. This mainly is another tail PCB and tailcap with rotating PCB to keep alignment right, right?
Double length battery tube. 2x cells long. What could be simpler with tooling already in place?
KawiBoy1428
The Miller wrote:
Interesting.
Something like this but 4P instead of 3P….
If I’m not mistaking…. Big Smile
The Miller
AH yes, of course, simply longer.
Sounds very good, will check with Barry right away
KawiBoy1428
4-XHP70.2 P2-1A’s + XHP70 DTP board + SRK-FETDDdrv. + 8-VTC5A’s = Shocked MY!!!!
Tom E
Tom E's picture
Last seen: 2 weeks 3 days ago
We'd be seeing 32K lumens there, wow! cool
maildroid
Last seen: 6 hours 45 min ago
So with more batteries will that make it brighter and or longer battery run time ?? Please forgive newbie questions .
"Let your lite shine "
tekwyzrd
tekwyzrd's picture
2s4p battery tube would allow use of 6v emitters like xhp or mt-g if the driver is replaced or modded to allow 2s voltages. In the case of xhp the runtime would be much shorter since each pair of cells would be powering 4 dies.
maildroid
Thanks for the explanation.
tru3s1lv3r
tru3s1lv3r's picture
Last seen: 1 day 10 hours ago
Count me in! Basically a Nitecore TM28 killer!
Aspiring Fhashlightaholic!
leaftye
Last seen: 1 hour 18 min ago
Definitely.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
tekwyzrd
tekwyzrd's picture
tru3s1lv3r wrote:
Count me in! Basically a Nitecore TM28 killer! !{width:40%}https://i.imgur.com/HGsRB7R.jpg!
Thumbs Up
Jinx
Jinx's picture
Last seen: 2 days 13 hours ago
Like the idea of this mod, however this paragraph doesn’t make sense to me.
‘Each pair powering 4 dies’ but you have 4p so how can a pair power anything separately?
If you go from 4p to 2s4p then capacity remains exactly the same but voltage will double. Current drive to the emitters will determine run time.
djozz
djozz's picture
Last seen: 38 min 30 sec ago
4xXHP70 is 4 times the amount of dies of the stock Q8 so about 20K lumen, I expect not 32 , especially since it is only 2 times the amount of batteries.
