Lumileds Luxeon V, test of a 4000K 70CRI emitter
208 posts / 0 new
led4power
led4power's picture
Last seen: 9 hours 31 min ago
High drain cells and DD drivers are not good combination for low Vf LEDs like Luxeon V and many new Nichias,Crees... But it's nice too see that it can survive for quite a bit of time under way over spec conditions, most other LEDs just turn blue and die.
khas
Last seen: 1 week 3 days ago
The Luxeon V is one tough emitter, it’s still working after all the abuse and after I sliced the dome the dark spot is less visible. I did put a new Luxeon V in the Sofirn but this time I used a LD-B4 6 Amp driver instead.
As long as you use a host with good thermal path it’s hard to get the Luxeon V to turn blue, I have only managed to do it in a Skilhunt H02 with a FET driver.
g_damian
g_damian's picture
Last seen: 55 min 49 sec ago
I have a LD driver with luxeon configured it in DD mode on turbo. on fresh battery it never takes more than 8A.
khas
In the Sofirn C8 I just put together with a LD-B4 using 22AWG wires from the driver to the LED and a high current spring without bypass I get 5.64A on CC and 9.36A on DD with a Sony VTC5A.
KevinZA1988
KevinZA1988's picture
Last seen: 1 day 4 hours ago
Will it be okay to push 7A regulated current with this LED? How will it hold up in the long run with regular turbo runs? External OTP will be done with L4P driver and MCPCB.
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
djozz
djozz's picture
Last seen: 10 min 34 sec ago
7A should be fine although my sweetspot would be 6.
No one knows what happens in the long run until reports are coming in that Luxeon V’s are failing. At least my tests do not tell what happens when leds are overdriven longterm.
KevinZA1988
Thanks djozz
Tom E
Tom E's picture
Last seen: 4 hours 27 min ago
Pretty much all my Luxeon V lights have lost amps and output - thought this was known well? I'm gonna convert what remains over to something else.
Hoop
Hoop's picture
Last seen: 3 hours 28 min ago
How dramatic are the losses? Could you talk about how you ran them? Were they DD’d, etc.?
Tom E
Tom E's picture
Hoop wrote:
How dramatic are the losses? Could you talk about how you ran them? Were they DD'd, etc.?
Oh boy, @work now, but again, thought this was common knowledge. Initially in a SD Mini w/FET+1, the V did 8.5A on a GA cell at 4.16V, ~2200 lumens at start, 2000 at 30 secs. Now I think it's down to ~1500 lumens, not sure of amps. Think it's in my notebook somewhere but I don't have a cross ref to find it easy.... No time now to research.
Again, though everyone knew this? Anyone knows of it? Am I crazy?? smilefrown
KevinZA1988
I don’t think driving this LED with FET is a good idea. I lost half of my output (physically two of the 4 four emitting surfaces stopped working) using a LD-A4 driver. I had high mode set to direct drive and it was a huge mistake. Had to replace the LED. Currently, I’m running high mode constant current at 5.25A.
It’s been months of heavy use and lots of turbo runs and it’s still as it was since I tested it after the new LED was installed.
Tom E
Tom E's picture
Ahh, ok - that helps somewhat. Soooo, I take it running/testing at 8-10 amps wasn't good? Didn't know there were 4 separate emitting surfaces - need to take a closer look at mine.
Scallywag
Scallywag's picture
Last seen: 7 hours 12 min ago
I hadn't heard of it. My D4 is using Luxeon V and still doing quite well AFAIK. Of course, that's a bit different than direct driving a single emitter. I should do a test with the bezel open and measure the voltage across the LEDs, since I don't have any good way to measure current (especially current that high).
EDC Rotation: ZL SC62 | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01
EagTac D25C Ti | DQG Slim AA Ti | UF-T1 by CRX | Olight S1 | Klarus Mini One Ti
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
In-progress: Supfire M6 3xXHP50.2
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
KevinZA1988
A single Luxeon V that’s FET driven with proper springs or bypasses is not a good idea. VERY bright, for a VERY short time.
Agro
Agro's picture
Last seen: 28 sec ago
It’s a news to me that this LED has problems with sustained FET use.
It’s also a news to me this LED has 4 dies.
So…thank you both for your reports. Smile
Tom E
Tom E's picture
In a quad, probably 5 amp per LED at best, so sounds like it's still in the safe zone. 20 amps is pretty high for typical compact quads.
So guess for those using the V's on a quad, you reflowed the 4040 V onto 3535 pads? I was only using L4P's 4040 MCPCB's.
Scallywag
Scallywag's picture
KevinZA1988 wrote:
I don't think driving this LED with FET is a good idea. I lost half of my output (physically two of the 4 four emitting surfaces stopped working) using a LD-A4 driver. I had high mode set to direct drive and it was a huge mistake. Had to replace the LED. Currently, I'm running high mode constant current at 5.25A. It's been months of heavy use and lots of turbo runs and it's still as it was since I tested it after the new LED was installed.
I missed this. A bit confused: Is the Luxeon V 4 dies?
No, I'm using Led4Power's 20mm 4xV MosX MCPCB
Tom E
Tom E's picture
Ohhh - that 4040 quad is not listed under his MCPCB's, so guess he doesn't sell them bare Facepalm
Yep, I'm still confused bout the 4 dies as well.
And since a couple guys chimed in about running these at high amps, djozz is either unaware, or didn't take time time to update his OP, because reading the OP, everything is fine and dandy with the Luxeon V at up to 12 amps or so...
Certainly that L4P quad or triple seems to be the best way to go with these LED's, or, be sure you constrain the amps way down, under 6 I suppose.
M3CSL
M3CSL's picture
MOSLED EXTREME ( mosX ) ceramic insulation 4XV 4040 quad MCPCB (BARE) is here:
https://led4power.com/product/mosled-extreme-mosx-ceramic-insulation-4xv...
It is on page 2 and easy to miss. Can only find the AL version though.
Convoy S2+ 219b triple, Astrolux FT02, Maglite 3D, Solarforce L2t
Agro
Agro's picture
Lumileds claims that Luxen V has a single die:
https://www.lumileds.com/news/299/50/Lumileds-Transforms-High-Power-Cate...LED
KevinZA1988 do you have any pictures of the failed LED?
Scallywag
Scallywag's picture
Yes, ideally both lit partially as described, and un-lit.
led4power
led4power's picture
I think Kevin is talking about Luxeon MZ, which is quad 4x2mm2 die LED. Luxeon V is single 4mm2 die LED.
MosX boards more than good enough for triples, quads etc. because no one run LEDs at absolute max. in those setups - difference between DTP and mosX is marginal when you run LEDs like XPL, Luxeon V at 50-70% of max. current.
Tom E
Tom E's picture
MZ explains it - details, details...
What's your definition of max current?
Are all MosX boards aluminum? Guess so... From this listing on a Luxeon V quad, I had no idea a MosX board is alum - would have fooled me for sure...
I'm surprised in triple and quads you are saying alum is no worse than copper - think about it, quads have 4 times as much heat, though amps per LED is lower, but the heat is not reduced.
Agro
Agro's picture
Tom E wrote:
led4power wrote:
I think Kevin is talking about Luxeon MZ, which is quad 4×2mm2 die LED. Luxeon V is single 4mm2 die LED.
MosX boards more than good enough for triples, quads etc. because no one run LEDs at absolute max. in those setups – difference between DTP and mosX is marginal when you run LEDs like XPL, Luxeon V at 50-70% of max. current.
MZ explains it – details, details…
What’s your definition of max current?
Are all MosX boards aluminum? Guess so… From this listing on a Luxeon V quad, I had no idea a MosX board is alum – would have fooled me for sure…
I’m surprised in triple and quads you are saying alum is no worse than copper – think about it, quads have 4 times as much heat, though amps per LED is lower, but the heat is not reduced.
This PCB w/out LEDs is in the “MCPCBs – ALUMINUM” part of the shop. And there’s no copper mentioned anywhere. And weight is low for copper.
Tom E
Tom E's picture
Yep, I know all that for the bare alum board, but for the pre-mounted quad in the listing I linked -- nothing about alum, copper or weight.
It's confusing without reading every post on BLF about this stuff...
Agro
Agro's picture
Tom E wrote:
Yep, I know all that for the bare alum board, but for the pre-mounted quad in the listing I linked — nothing about alum, copper or weight.
It’s confusing without reading every post on BLF about this stuff…
Actually weight is available under “Additional Information”.
But I agree, these could have been clearer.
djozz
djozz's picture
Here is a quick picture of my C8F with Luxeon V’s . You can see that one is only lighted half. I did not know that one-quarter and three-quarter were also possible. You can not see individual dies though, I do not know how the led is built up.
Scallywag
Scallywag's picture
Ouch, no fun.
Agro
Agro's picture
Thanks djozz! That’s very interesting.
Marc E
Last seen: 5 days 11 hours ago
Is that definitely the die failing and not the dome separating from the die?
