⫹ temporarily closed ⫺ KLARUS Mi1C ✺ Mini-Mighty EDC Flashlight
Mini-Mighty Bright EDC Flashlight Klarus Mi1C
Klarus Mi1C is a unique mini-mighty bright EDC flashlight barely over 2 inches in length. And yet, using CREE XP-L HI V3 LED and one high performance Klarus 16340 battery with micro-USB charging port, this “rechargeable” tiny light delivers 600lumens, with maximum runtime up to 9 days at moonlight mode.
Features
  • Mini-might brightness, thumb-sized.
  • CREE XP-L HI V3 LED, maximum output up to 600 lumens.
  • Extreme runtime, up to 9 days in moon mode.
  • Professional optical lens design, even-lit flood and soft beam.
  • Tail magnetic base function, attach to a metal surface to provide “hands-free” illumination.
  • Fade-in and Fade-out function when the turbo mode is the initial mode for on and off to promote eye safety and improve user experience.
  • Newest Intelligent Temperature protection System(ITS) monitors internal temperature and adjusts output to regulate heat dissipation; protects LED and internal components for perfect balance of output and safety.
  • Intelligent Battery Capacity indicator to view remaining battery capacity at any time.
  • Unique lock-out mode prevents accidental activation; avoiding battery drains during storage or travelling and prevents unintended directly shining into eyes.
  • Reverse-polarity protection prevents damage due to incorrect battery orientation.
  • One-touch low and with mode memory function.
  • Aerospace Aluminum Alloy construction; CNC precision machining; Mil-Spec HAIII anodizing, anti-abrasive, lighter and robust.
  • Compatible with CR123A and 16340 Li-ion battery, KLARUS high performance 16340 battery with Micro- USB port included, no need to bring a charger, easy to use, safe and reliable.
Specifications
  • CREE XP-L HI V3 LED, 50000 hours life.
  • 4 lighting levels, 2 flashing modes.
  • Working Voltage: 2V-4.2V.
  • Compatible Batteries: CR123A x 1 or 16340 Li-ion battery x 1.
  • Reflector: Convex Lens.
  • Switch Type: Side Switch.
  • Dimension: (Head)19.8mm(0.78") x (Body)20.5mm(0.81") x (Lenght)54.5mm(2.15").
  • Net Weight: 27g (0.95oz) (w/o battery).
  • Material: 6061-T6 Aluminum Alloy Body, Mil-Spec HAⅢ Anodizing.
  • Waterproof: IPX8 (underwater 2 meters) .
  • Included Accessories: Spare O Ring x 1, Stainless Steel Clip x 1, 16340 Li-ion Battery with Micro-USB Charging Port x1
If you are interested, notify in this thread (not in PM)
OFFER IS AVAILAIBLE !
Details via PM
My main thread: GearBEST.com Coupon Codes&Flashsales
My other groupbuy threads:
NITECORE DL10 ✺ Dual-light source DIVING light - Interest list ACTIVE
JETBeam TH20 ✺ Tactical flashlight XHP70.2 - Interest list ACTIVE
Interest list
  1. Fin17 2pcs
  2. glide 1
  3. Slayer1
  4. sac02
  5. Athlon2350
  6. zzhawk
  7. I_SpY
  8. X0R
  9. Jerommel
  10. Phantom1
  11. xenith
  12. Mstevens113
  13. Andybibbville
  14. rondohatten
  15. jamaya
  16. Silent_Star
  17. travis
  18. mizou51
  19. ramptosd
  20. glockboy
  21. wle
  22. Klotski
  23. Cythras
  24. Itsme
  25. blueb8llz 1-5pcs
  26. leroycp
  27. slow2go 2pcs
  28. bhorn0002
  29. Gea2427
  30. JLAu
  31. maildroid
  32. Hairy_Steve
  33. southland
  34. ilovejesuschrist
  35. cyropro
  36. Frank A.
  37. MascaratumB
  38. Angel Martínez
  39. tedthebrit
  40. Muto
  41. spinynorman
  42. lumiere
  43. Gerrit
  44. NapoleonsTriumph
  45. ...
  46. ...
Interested.
Me too am interested.
Interested.
A previous thread mentioned something ominous that seemed to indicate the light would always come on in High so I was concerned about the UI - but if your info listed is correct, this is much better:
Interested.
Interested.
Interested.
Interested
Interested!
Interested
pls put me in the list too.
thanks
Interested
This information from the manufacturer's site.
Interested
interested.
thank you.
Interested
Interested.
Thank you!
Interested
im in
thanks
