Tank007 KC70 is a lamp with 90 degrees rotation function ,zoom focusing, tail magnetic, direct charge and other practical features etc. As a high-power flashlight, very suitable for duty, maintenance, inspection and so on.
(1) LED SPECIFICATIONS:
Brand & Model: USA Cree XM-L2
LED Lifespan: above 100,000 hours
Max Brightness: 600 lumens
Throw Beam: 300 m
(2) CIRCUIT SPECIFICATIONS:
Input Voltage: 2.8-4.2V
Output Level: 3 modes (High-Med-Strobe)
Chip characteristics: Regulated current for constant output
(3) BATTERY SPECIFICATIONS:
Power Source: 1*22430Li-ion battery
Burn Time: high light- 2hours; low light-10 hours
(4) PHYSICAL SPECIFICATIONS:
Size(cm): 13.7(length)* 2.7 (body diameter) * 3.5(head diameter)
Weight(g): 180 (excluding batteries)
Switch: Button switch in the head (Press and hold the button switch for 1s)
Material: made of durable aircraft-grade aluminum T6061
Reflector: High temperature vacuum coated aluminum mirror reflector
Lens: tempering optical lens Treatment: premium Type III hard-anodized anti-abrasive finish
Waterproof: IPX-7
Anti dropping height: 1.2 m
Color: black
This light has all the features of a very decent quality all-round light.
Quite a Swiss army knife in flashlight clothes. USB, magnet, and so on.
A perfect gift to someone who thinks he (she) needs only one flashlight.
But ………
Why this size battery. A 22430? At first I thought it was a typo.
(but after some .oogling it seems not uncommon with LiFePo4 chemistry)
If you think an 18650 is too long, why not settle for an 18500 or a 26350?
Edit: if I were you, I would add a low or moonlight mode (but I am not).
Thanks for your kind suggestions. But our R&D department advises to build such a flashlight, I think there are some reasons for which they do so. And the battery is also easy to get, do you think so?
I just realized something, this Tank007 KC70 is a zooming angle light! So this light it can’t really be compared to any Rofis, I’m sorry I didn’t notice it’s zooming before.
This is a great concept! I like it! :+1: I’m not aware of any other angle head zooming lights on the market?
But there’s a few things I wish for:
A common size Li-ion battery
Full swivel head like Rofis and others
Higher output, at least 800-1000lm
High-Med-Low modes instead of High-Med-Strobe (you can have the strobe separate, activate with fast double click or?)
More reasonable price
Also, What is the CCT of the LED on this? Cold white or Neutral white?
I am afraid you are right. Many customers tell us the battery problem. We are trying to make a new model similar to this one, which uses common battery like 18650. Thanks for your advice.
