Yes, I think you get the idea. I usually think of tint shift in two different ways:
1. How the color changes in a beam profile, as you move from the center out to the edge. For example, many Cree LEDs will give a beam pattern that has a warm yellow hot-spot, a green corona, and a cool purple spill. Okay, that’s an extreme example, but some are like that. The tint shift can often be made worse by anti-reflection coatings on the lens.
2. How a LED’s tint changes as more current is applied to the LED. i.e., the tint (and CRI) can be slightly different on max brightness, as opposed to a (constant-current) low brightness. Some people complain about this, and it is measurable with equipment, but I’ve never personally been able to see the difference even when I use a camera to expose beam profiles to the same perceived brightness.
The coating sometimes has a color of its own, so the light going through it gets changed. Angles can make it worse, so the shift across the beam might be different. It depends on the quality of the coating. I think a good anti-reflection coating doesn’t cause any tint shift.
Tint shift use to have the second meaning walkintothelight posted above only, but recently, because of the popularity of asphericals and more recently, third generation Cree LEDs, the meaning has to be amended. lol
In my experience, the anti-reflective coatings (i’m referring to the pink-ish coatings,) on windows, hardly affects the tint of the beam however, many claim that makes the light a little cooler. (There are greenish and blueish coatings too that may add a little unfavourable tint.)
I bought a new flashlight from Olight the Marauder Mini. It does not seem like a bad light. I’ve had other lights with some tint shift around the edges etc. However this is the first light I’ve personally had that has a weird tint in the center of the hotspot on spotlight mode. I’ll leave a photo link for viewing. Basically my question is, is this normal and something common? Or is the coating on the LED defective? I’m still learning the ins and outs thanks in advance!
Does that light use a convex/aspherical lens? That ring around the periphery looks like a chromatic aberration that’s typical of those lenses. When the lens is focused right on the LED it’s almost like a magnifying glass effect. The blue area could be a manufacturing inconsistency or minor damage to the phosphor layer, which becomes more apparent with that type of lens. That light should come with a warning, do not shine at white walls. Anyway, just a guess. I’m no expert.
