Test/review of Delipow 9V LiIon 800mAh (Yellow-green)
6 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 hours 14 min ago
DSC_2110
Official specifications:
  • Battery Type: Li-ion Battery
  • Rated Capacity: 800mAh(0.2C discharge)
  • Rated Voltage: 8.4V
  • Discharge cut-off voltage: 7V
  • Charging Voltage (standard): 9V
  • Discharge current (standard): 50mA
Delipow%209V%20LiIon%20800mAh%20(Yellow-green)-info
A cheap LiIon 9V battery from China
Overcharge protection on the A cell kicks in at 8,46 volt and over discharge protection at 5,53V
Overcharge protection on the B cell kicks in at 8,46 volt and over discharge protection at 5,56V
DSC_0244 DSC_0245
DSC_2111DSC_2112
DSC_2113
DSC_2114
DSC_2115
DSC_2116
Delipow%209V%20LiIon%20800mAh%20(Yellow-green)-Capacity
It do not have the rated 800mAh, but the discharge curves looks good for a 590mAh battery.
Delipow%209V%20LiIon%20800mAh%20(Yellow-green)-CapacityTime
Delipow%209V%20LiIon%20800mAh%20(Yellow-green)-CapacityTimeHours
Delipow%209V%20LiIon%20800mAh%20(Yellow-green)-Energy
Delipow%209V%20LiIon%20800mAh%20(Yellow-green)-Charge
Conclusion
The capacity rating is too high, but it looks like a acceptable LiIon 9V battery.
Notes and links
Compare to other 9V batteries: Alkaline/NiMH/Lithium/other
My website with reviews of many chargers and batteries (More than 1000): http://lygte-info.dk/
Edited by: HKJ on 09/13/2017 - 17:05
lagman
lagman's picture
Last seen: 4 hours 12 min ago
It looks like there is no overdischarge protection?
My English isn’t perfect but I’m trying to improve it. If you see something that doesn’t sound right or is just plain wrong, please feel free to point it out! Smile
HKJ
HKJ's picture
Sorry I forgot to add that, it is included now.
I will expect it to be below 6V and it is.
firedome
Last seen: 4 days 4 hours ago
But what do we know about the protection circuit? Has anyone seen good data on these protection circuits tested or examined for quality?
“We can easily forgive a child who is afraid of the dark; the real tragedy of life is when men are afraid of the light.
-Plato
WalkIntoTheLight
Last seen: 1 hour 30 min ago
8.4 volts (when freshly charged), and around 7.5 volts over most of the run time, just won’t cut it for a lot of devices that require 9 volt batteries. I have smoke detectors that start sounding the low battery warning at around 7.6v. I use NiMH 9v batteries in them, but they use 7 internal cells for a total of 9.6v.
This battery would start sounding the warning way too soon. Though, the greater capacity might still give it a decent run-time.
BTW, how do you charge it? It must come with a special charger?
Barkuti
Barkuti's picture
Last seen: 3 hours 28 min ago
Battery seems equipped with a proper management system. Undervoltage protection is likely set at 2.75V/cell (battery cut offs: 5.53 and 5.56V). Cell balancing may be absent, of course.
There are some specific chargers for this sort of stuff, WalkIntoTheLight, Soshine has some for example. Peek here: “soshine 9V charger” search at FastTech
It can also be done with a generic CC/CV power supply, just set maximum voltage and current to the desired values. HKJ used 8.4V and 0.2A for the above-mentioned charging graph.
