Forward switch for Convoy C8?
17 posts / 0 new
slowpoke
slowpoke's picture
Last seen: 10 months 1 week ago
Bonjour à tous!
I want to add to some Convoy C8 I use at work (the newer model, with the 12 group programable driver) a forward switch so I no longer need to full click and release to turn the light on.
This will be used only with single mode group.
I have been looking for a direct replacement with no luck…
any tips, ideas or links?
Merci beaucoup in advance! Big Smile
Jerommel
Jerommel's picture
Last seen: 2 months 5 days ago
Forward clicky switches are usually a bit taller, so it’s possibly not an easy swap.
Simon (mr. Convoy) has these:
https://www.aliexpress.com/store/product/flashlight-forward-switch/33041...
..waiting for parts..
Still looking for 5” parabolic reflector (for recoil light)
slowpoke
slowpoke's picture
Thank you for the fast reply.
I asked monsieur Convoy time ago about if this fits in the C8 and he told me “no, won’t fit. Only for L series”
Crying
Jerommel
Jerommel's picture
I think you have to shorten the middle thing in the rubber button, and then it will fit.
slowpoke
slowpoke's picture
oh, I see.
I am a flashy newbie, and since the C8 is such a very popular model I was expecting a direct replacement.
Thanks!
dmsoule
Last seen: 9 hours 3 min ago
blueb8llz
Last seen: 3 hours 29 min ago
dmsoule wrote:
I believe this is a direct replacement:
http://www.mtnelectronics.com/index.php?route=product/product&product_id...
Can anyone verify this? I would also like to order a few of these for my c8.
Especially the spring tail braided version.
g_sintornillos
g_sintornillos's picture
Last seen: 1 week 1 day ago
You need eliminate the internal nipple of the rubber button
I use original board
I change only the switch, desoldering the original and soldering this: http://kaidomain.com/p/S005339.DIY-LED-Flashlight-Forward-Clicky-Switch-...
If you use the ones from MTN you must lower the diameter to about 16.5mm
Sorry for my bad English (gogole transtorla)
rizky_p
rizky_p's picture
Last seen: 1 day 13 hours ago
wouldn’t the forward clicky interfere with how we change mode in Convoy C8 since half press is basically on, so changing mode can only be done while in off position.
Phlogiston
Last seen: 1 day 15 hours ago
Normally, yes. However, the OP is using a C8 with Biscotti, and plans to set mode group 12, so it will only have one mode (full power). The one potential problem is if he does many momentary flashes in rapid succession and accidentally gets into configuration mode.
rizky_p
rizky_p's picture
ah yes, didn’t read the OP thoroughly.
Sledgestone
Last seen: 1 week 4 days ago
Sorry but I don’t see how you made the switch fit on the board? I have the same switch and there’s just no way. The metal pegs on the switch is nowhere close to the original switch.
Hunter
Last seen: 3 days 2 hours ago
All my C8 lights have forward switch, they work fine, you just select mode first and then use flashlight…
Sledgestone
What switch do you use?
g_sintornillos
A picture is worth a thousand words
Sledgestone
Ah, yes. After I wrote the comment I had to look again. And it was no problem, however it still isn’t possible I’m my host. The height is the issue now. Even if I just screw the retaining ring on the first thread I pushes all the way through the tailcap. Even after I removed the little raised plastic inside it.
blueb8llz
Can you send us a link to the place you purchased your switches? Thanks
