Hi guys,
I’m just after a bit of help please.
I purchase a Nightcore HC50 Headlamp approximately 3yrs ago, and I absolutely love it, when it works…
Unfortunately the unit has recently started malfunctioning, by not switching on at all.(No indicator light, no response from unit whatsoever.)
I have taken the following checks/steps so far to rectify the problem.
- Checked the battery is fully charged with mult-imeter at 3.79v.(have tested 2 separate batteries the same brand etc)
- The battery is a good quality SoShine 3.7 l-ion 18650 (Rehchargable), and is the same I have always used with the headlamp the whole time.
- I have opened up, and inspected the unit as much as possible, and can see no signs of physical damage or water ingress etc, and have cleaned all contact points & threads with alcohol pad.
- I have tested to see if the switch is malfunctioning, by making contact with the negative point on battery while in device, and there is still no power, so suggests that the switch is working.
- I can see no other way of accessing the unit whatsoever, there are no screws or anything visible, it is only one solid unit, apart from the end cap/switch.
I appreciate this model is probably redundant by now, and it would be easier to replace it, but I simply cannot afford to buy a new one at the moment, so I’m hoping someone out there has the same model, and may be able to make some suggestions.
I’m thinking of emailing Nightcore for an out if warranty repair, but I can’t even find the receipt, as I ordered mine in a group buy.
Would greatly appreciate any feedback whatsoever.
Thanks
Craig
