Test/review of Nitecore Intellicharger new i4 2017
9 posts / 0 new
HKJ
HKJ's picture
Last seen: 13 hours 45 min ago
DSC_1152
DSC_1153DSC_1154
This is Nitecores “simple” charger in the 4 slot version.
DSC_1128 DSC_1129 DSC_1130 DSC_1131
The cardboard box lists lot of specifications, battery types and features.
DSC_1145
The box contains the charger, a mains cable, manual and a warranty card.
DSC_1155
The charger has two power connectors, one for mains input (100-250VAC 50/60Hz) and one for 9-12 VDC input.
DSC_1157
The user interface has buttons and the leds are place behind a dark cover.
DSC_1209
It has 3 green status leds and a red led to signal full current (1.5A). The status led also has a secondary function, they are used as indicators for selected voltage.
The charger is a bit special with current selection, usual it will select current depending on battery length and chemistry, but it can be overridden in one case: Two long LiIon batteries can be charged at 1.5A, but then they will be charged in sequence, not simultaneously.
To change voltage or current tap the C button until a single green led above the required slot lights up. Then hold C or V button to adjust current or voltage. C button can only turn the red led on, the V button will change between the 3 green leds for the 3 different LiIon charge voltages. Press again shortly on C or wait for timeout.
DSC_1158DSC_1159
The slots uses the usual construction and works well. They can handle batteries from 28mm to 70mm long.
Notice the long bar at the plus end, due to this the charger can handle anything up to D or 32xxx size.
supportedBatteryTypes
supportedBatterySizesDSC_1198DSC_1199DSC_1200DSC_1201
DSC_1202DSC_1203DSC_1204DSC_1205DSC_1206DSC_1207
The charger can handle 70 mm long batteries, inclusive flat top cells.
Measurements
  • Power consumption when idle is 0.56 watt
  • Will charge a LiIon with 0.2mA when charging is finished.
  • Will discharge a NiMH with 0.1mA when not powered
  • Will discharge a LiIon with 0.9mA when not powered
  • Change between long/short cell at around 56mm
  • Below 0.8V the charger will report error (All leds flashing) and charge with about 1mA.
  • Above 0.8V regular charging is used.
  • Will assume LiIon above 2.0V
  • Slot 1 & 3 will time share.
  • Slot 2 & 4 will time share.
  • Charger will not restart if battery voltage drops.
  • Power cycling and insertion of a battery will restart charging.
4.2V LiIon charging
Nitecore%20new%20i4%20%28SA18650-33%29%20%231
This is a nice CC/CV charge curve, the termination is slightly high at 200mA.
Nitecore%20new%20i4%20%28SA18650-33%29%20%232
Nitecore%20new%20i4%20%28SA18650-33%29%20%233
Nitecore%20new%20i4%20%28SA18650-33%29%20%234
The other 3 slots looks similar.
Nitecore%20new%20i4%20%28SA18650-26%29%20%231
Nitecore%20new%20i4%20%28PA18650-31%29%20%231
The two other batteries also charges fine.
Nitecore%20new%20i4%20%28BE18650-26%29%20%231
The old battery has more voltage drop when finished.
Nitecore%20new%20i4%20%28KP14500-08%29%20%231
With a smaller cell the current is automatically reduced to 0.5A, but the termination current stays the same.
Nitecore%20new%20i4%20%28AW18350-IMR%29%20%231
The charger has no problem with this old cell, but due to the high termination current the voltage will drop significantly when current is turned off.
Nitecore%20new%20i4%20%284xSA18650-33%29
With 4 batteries the charge current is fairly low.
Nitecore%20new%20i4%2012V%20%284xSA18650-33%29
And it need abou 0.8A from 12V
Temp4591
M1: 32,0°C, M2: 35,3°C, M3: 37,7°C, M4: 36,9°C, M5: 52,3°C, HS1: 72,3°C
The hot part is probably the internal power supply.
Temp4592
M1: 31,6°C, M2: 35,0°C, M3: 37,3°C, M4: 36,7°C, M5: 53,5°C, HS1: 84,4°C
PoweronLiIon1
The charger starts very fast. It turns current off to measure voltage.
ChargeLiIon14
With batteries in slot 1 & 4 it will only charge with half current, i.e. 0.75A
ChargeLiIon24
If I put batteries in slot 2 & 4 the current is also half, this time due to time sharing.
ChargeLiIon1234
With 3 or 4 batteries it will both reduce current and time share.
3.6V LiIon charging (LiFePO4)
Nitecore%20new%20i4%20%2818650-LiFePO4%29%20%231
Nitecore%20new%20i4%20%28SO14500-LiFePO4%29%20%231
The charger handles LiFePO4 batteries correctly.
4.35V LiIon charging
Nitecore%20new%20i4%20%28LG18650-30%29%20%231
The 4.35V charging looks fine.
NiMH charging
Nitecore%20new%20i4%20%28eneloop%29%20%231
With NiMH the charger current is only 0.5A for any size battery. The charging uses voltage termination without any top-off charge. I cannot see any temperature raise at the end of charge, i.e. the battery is slightly undercharged.
Nitecore%20new%20i4%20%28eneloop%29%20%232
Nitecore%20new%20i4%20%28eneloop%29%20%233
Nitecore%20new%20i4%20%28eneloop%29%20%234
The 3 other slots works the same way.
Nitecore%20new%20i4%20%28eneloopPro%29%20%231
Nitecore%20new%20i4%20%28powerex%29%20%231
Same with the two high capacity batteries.
Nitecore%20new%20i4%20%28eneloopXX%29%20%231
This worn down cell got 7.5 minutes before the charger realized that it was hopeless and terminated.
Nitecore%20new%20i4%20%28eneloopAAA%29%20%231
The AAA cell is charged the same way.
Nitecore%20new%20i4%20full%20%28eneloop%29%20%231
The full cell was detected in about 6 minutes.
Nitecore%20new%20i4%20%284xeneloop%29
With 4 batteries the charger current is about 0.375A, this time at least one battery gets warm (i.e. it is full).
Nitecore%20new%20i4%2012V%20%284xeneloop%29
The charger needs about 0.5A from 12V for charging four NiMH.
Temp4608
M1: 33,2°C, M2: 38,0°C, M3: 43,3°C, M4: 43,9°C, HS1: 72,0°C
Temp4609
HS187,1°C
Some electronic inside the charger gets fairly warm.
PoweronNiMH1
The charger is also fast to start with NiMH batteries.
ChargeNiMH24
With batteries in slot 2 & 4 the charger increased the current to 0.75A and starts time sharing.
ChargeNiMH1234
The charger do not reduce charge current with more batteries, 4 batteries use the same time sharing as two.
Testing with 2830 volt and 4242 volt between mains and low volt side, did not show any safety problems.
Conclusion
The charger is simple to use with the automatic current selection and chemistry selection: just put batteries in and they are charged.
But it is not a fast charger, a single 18650 can be charged in about 3 hours (This is fairly standard), but with four cell it will take 9 hours.
Charging LiFePO4 or 4.35V batteries is a bit more tricky due to the not very user friendly user interface, but it is possible.
I will call it a good family charger, everybody can use it for NiMH and 4.2V LiIon batteries.
Notes
The charger was supplied by a zapals.com for review.
NeutralFan
NeutralFan's picture
Last seen: 5 min 12 sec ago
Glad to see that the i4 continues to be good, basic, universal charger. Thanks for reviewing HKJ!
I’d rather use my flashlight around the house than turn on the lights.
samgalax
Last seen: 1 week 6 days ago
Do you have the new i2 in queue to be tested???
I think it should be almost the same except for the charging current.
Thanks for another excellent review
Please SUBSCRIBE to my youtube channel (flashlights, electronic gadgets and various stuff..)
https://www.youtube.com/channel/UCCF3RcoQ3Ff05Cr4-Gg5qAw
I am a beginner. So please help me to make the channel "grow up"
Thanks!!
HKJ
HKJ's picture
I did test the “new i2” last year: http://lygte-info.dk/review/Review%20Charger%20Nitecore%20Intellicharger...
Has it been updated since?
The only other Nitecore charger I have in queue just now is the SC4 and that will be published next week.
Henk4U2
Henk4U2's picture
Last seen: 44 min 38 sec ago
Nice review. Basically this is the charger I should have bought 4 years ago Wink
Today I have several chargers that are almost perfect, but miss one or two vital capabilities.
For that I have other chargers. But these are lacking capabilities the first one has. And so on……
I always think long and hard before I say something really stupid.
Flomotion
Flomotion's picture
Link Please to best/reliable Supplier.
Flomotion
samgalax
Ouch, HKJ…. I didnt realized that you already reviewed it…. no. No updates. Is that charger. Sorry
Thanks!!
HKJ
HKJ's picture
Using this list makes it easier to see what I have reviewed: http://lygte-info.dk/info/roundCellChargerIndex%20UK.html
samgalax
Ok. Thank you!
Thanks!!
