Ampsplus INR18650 3500mAh (Black)
Official specifications:
Size: 18.35mm x 65.10mm
Nominal Voltage: 3.70V
Nominal Capacity: 3500mAh
Rated Capacity: 3400mAh
Charging Metod: CC/CV 4.20V
Discharge Voltage: 2.50V (Average Cut Off)
Charging Current CC: 750mA
Rapid Charging Current: 1500mA
Continuous Discharge Current: 10A Max.
Short Discharge Current: 20A
Battery Rate: 3C
Weight: 48gr.max
Color: Blue , Black
Version: Flat Top
Protection: No
This is a high capacity battery with moderate current capabilities.
Discharge curves tracks perfectly.
At 15A the battery gets too hot and I stop the discharge.
Oops, the battery died before my over temperature sensor stopped it. On the second battery I only tested up to 15A
Conclusion
The is a very good high capacity battery, but be careful with current draw above 10A.
Notes and links
The batteries was supplied by ecoluxshopdirect.co.uk for review.
Compare to 18650 and other batteries
