Hi all, first time poster here looking to replace a bunch of cheap lights with a new collection.
I’m looking to start with 3 lights in the <$30 range, but there are way too many options for a noob like myself to make a decision.
First, a tube light for indoors. I think I have narrowed it down to the Convoy S2+ and Astrolux S1/BLF A6
-Are there any others in this category I should consider?
-If not, which of these two would you recommend?
-Finally, for the Convoy S2+, do you recommend going with 6x or 8x drivers? Is the more usable (less heat) of the 6x better, or does the brighter 50% setting on the 8x make up for the hotter 100%?
Next, a thrower. I almost went out and grabbed the Clear Convoy C8 but then I saw the KDLITKER C8.2 w/ the XHP50.2 and was wondering if it was worth considering here. I know Convoy has an excellent reputation around here, especially when ordered directly through their store.
-How does Kaidomain’s reputation for reliability and customer support compare to Convoy’s? And how does the performance of that particular flashlight compare to the Convoy C8?
-Again, are there any other compelling options in this category?
Finally, something in between the two (what do you call this segment anyway?) with a combination of throw and spill. The Convoy M1 and M2 seem to fit the bill, although they are using an older diode. I currently have a Thorfire VG10S on order from Amazon, as I found a 20% coupon that was still valid and I didn’t want to miss out. But I can always send it back if I don’t like it or find a better option.
- Anything in this segment that you would recommend?
- How do the M1 and M2 compare to the VG10S?
Oh, and on a final note: batteries. I am planning on getting a Liitokala Lii500 charger, unless somebody would recommend a different (reasonably priced) choice. But I am having a tough time figuring out battery compatibility here. Are any of these lights supposed to use protected batteries? And are there any here that can’t use protected batteries? It would be kind of annoying to get one light that needs protected batteries, and then have another light where I can’t use them. Same goes for battery performance - do any of these lights need high discharge batteries? I don’t want to have to buy something like the NCR18650GA for one light, and have them not fit in another (I think it was certain Convoy models that had issues with larger batteries).
Thanks in advance
