Does anybody know where to find pictures of the inside of this light? I’m interested in it’s modding potential.
There are also variants with more LEDs. Information about these is also welcome.
Bump …
“bella-headlight” and “Mitko” and “teacher” have this light - maybe one of them has pictures from the inside?
Thanks. I’ve seen bella-headlights post and I guess also pictures in the Q8 thread but don’t want to bother forum members with private mail.
I have this one http://www.ultrafire.com/index.php?route=product/product&path=850&product_id=8168 that was sent to me as a sample.. I have not started any modding yet but the model I have is almost an exact copy of Sunwayman.
The model you have I am guessing that there are some UI changes.
Does it have a solid shelf for the LED board? I’ve only seen hollow shelfes in SRK clones up to now.
I have only opened it once just long enough o see how the emitters were set up... I will open it in little while if time permits. I do recall a lot of open space but I want to look again for myself .
If I do get the time I can snap a couple of pictures and give you an idea.
The head on the one you are looking at may be quite a bit different. I am not really sure what the LED is supposed to do. It may be temp, or just voltage readings. Either way there should be some components in there taking some of the space.
I can tell you that with 4 fully charged 30q's I metered the one I have at almost 3600 lumen. So when I get time I will be swapping out some things...
Thanks in advance!
