ENEDED
551 posts / 0 new
DENGOH
DENGOH's picture
Last seen: 6 months 1 week ago
Ya, by default MT03 TA LVP is finely tuned.
The thing is I use its turbo only, the FET mod and 6wires make LVP kick in very early, end up charging battery at 3.8v.
I mod the other MT03 TA with 4 wires, also changed R2 to 50k ohm. Don’t have suitable thicker wires, so have to squeeze 4 wires there, very close to shorting with reflector.
cool i'll see you when you get there
JasonWW
JasonWW's picture
Last seen: 2 hours 19 min ago
What battery are you using? You might want to try a higher drain like VTC5A or 20R.
You can also use Teflon coated wires since the insulation is thinner. Or use a single thicker wire like 14ga, etc…
Did you already bypass all of the springs?
DENGOH
DENGOH's picture
I use VTC6, 30Q, HG2. VTC6 give best performance. I have enough high drain batteries, still have 20+ new batteries unused. So I am not getting any battery soon.
I have thicker wire but they are not rated as 200 degree c. I am using silicon wire that can withstand high temperature better. That’s why i squeeze 4 of them there. Springs are not bypassed, what i afraid bypassing spring will cook something because the current will be very high.
JasonWW
JasonWW's picture
Using extra led wires has a similar effect of bypassing the springs, it reduces resistance and allows for more amperage to pass.
DENGOH
DENGOH's picture
Ya, it has to balance, overdo will cause too high current. The FET and wires method is proven by my other MT03 TA, so i chose same method. Also i don’t like to mess with springs.
Spartan
Last seen: 3 months 4 weeks ago
I’m curious. Do you know there is teflon treated fiberglass wrapped wire that can go very, very high temperatures?
I think it’s about 250c continuous. I have it in one of my heating platen on equipment i built back in the 90s. Still have some hanging around somewhere.
Moses came from the mountaintop carrying a tablet. The Words were....WITH GREAT LUMENS COMES GREAT REPONSIBILITY.
DENGOH
DENGOH's picture
I definitely don’t have those. Is it soft and flexible like silicon wire?
JasonWW
JasonWW's picture
It’s stiffer than silicone.
DENGOH
DENGOH's picture
Silicone wires are really the best for our mod i guess. Inexpensive, soft, high flexibility and temperature resistant. I bought a few meter of black and red color many years ago and can’t finish them at all.
JasonWW
JasonWW's picture
There are pros and cons to each. The Teflon insulation is thinner, so you can get more wires together without adding bulk and it can withstand higher temperatures. You see it used in high temp appliances like stoves, dryers, etc… the down side is it’s stiffer.
Silicone can’t handle the same high temperatures and is thicker, but it’s much more flexible.
It’s definitely better than the average low temp wire insulation you see on cheap wire.
