Fenix PD35 TAC
5 posts / 0 new
A-MAC
Last seen: 9 months 3 weeks ago
Fenix PD35 TAC
Fenix PD35
This light was provided by FastTech for review.
The Fenix PD35 is a pretty well known and respected light in the flashlight community. It offers great output, functionality and quality in a package that won’t break the bank. The TAC variant is no different, overall it’s a great light. It offers five modes plus strobe, beacon and SOS, with the later three “hidden”. This light will accept two CR123s or one 18650 as a power source. With either choice output and run time are great, on that note runtimes are in line with the manufacturer advertised values. It comes in a simple cardboard box with a pocket clip, lanyard, sheath and instructions.
The PD35 is activated via a forward clicky rear tail cap switch. The forward clicky switch offers momentary activation with a light press. The light will come on in the last mode you used before turning it off (mode memory). While on, a press of the side switch advances the brightness mode, pressing and holding will put you in strobe mode from any previous mode. While off, pressing and holding the side switch until the led flashes will put you in “tactical” mode. This only allows access to high, low and strobe. I’m not normally a fan of clip on style pocket clips but this one is sturdy and doesn’t leave me thinking I will eventually lose the light. The lanyard is pretty cheap compared to what other companies send you but it does the job.
Now with all that out for he way, on to what I don’t like. There isn’t much that I consider a negative on this light and I could definitely get over it in time. The first night I had it I used it as the dog walk light and right away I noticed it is tough to find the side switch in the dark. My Fenix PD32 and Nitecore P12 both have rubber side switches, their texture is very different from the flashlight head that surrounds the button, you know when your thumb is on it. The PD35 TAC has a smooth silver button and the texture is basically identical to its surroundings making it difficult to find in the dark, at least for me. The second gripe I have is that when you put the light in “tactical” mode, you lose the ability to switch modes with the side switch. In “tactical” mode you have to use the rear click switch to change modes. Along those same lines, in “tactical” mode you don’t have the choice of not accessing strobe while switching modes. I mean, I get it, it’s “tactical” but come on. I definitely like the idea of being able to switch mode groups and making it so I only have access to low and high but in my opinion, making me cycle through strobe also I asanine and could potentially give you away in a situation where you were using the light “tactically”. Also, putting the light in “tactical” mode basically turns it into a different light, by that I mean you essentially have to learn a different UI which is annoying. If it were my only light I could probably get past that but two different user interfaces for one light is annoying.
In the end the Fenix PD35 TAC is a great light. It’s provides great build quality and functions well, not to mention is backed by a reputable company. It’s similar to other lights out there and it comes down to what features you want and don’t want in a standard 18650 light, I keep this style light on both nightstands. Mode memory and a forward click switch make it easy to put into use when you need to find the cat that’s throwing up in the middle of the night SOMEWHERE in the house.
BBC5_B499_5_D16_4_B2_A_9_C29_991_F8_ADAD93_C
731_E8_F95_2_BA5_4_E6_B_B8_A6_39_BDF1_E2_A8_F1
DC0_AAF99_1_BB8_40_EA_83_B0_8_F715_CE931_FC
DFB61268_5097_4836_84_BA_B6296_CA235_EC
F303_A7_A8_C966_41_FE_9_B2_E_282633288416
50_E59_BC2_6480_4097_A1_CB_3_FA33_F2_FCF0_E
212_F22_F9_9_C8_B_4_CE4_A5_E5_0_D7_DA874_A1_FD
C63_D8_B15_748_D_403_D_870_F_F1_B8_E65963_BA
1_B92_D301_82_EB_4_D02_8_C6_E_CE9872_F691_BE
63_A315_C4_C853_4106_A500_9_A21_E09_AAFF0
11_F14_D7_B_5_C02_4_F1_E_81_F2_C792_C7_EE2_C31
9_B432900_C4_AA_4434_A08_A_57_F932418_B96
B4_DCC247_A2_EC_4_D9_D_9_E13_4674139_F3_EBE
A37_A0_C4_B_798_C_408_F_B80_C_DA62_DA8011_F6
771_E8611_680_C_4_D66_A74_D_7_D21_F9_E93795
ACEE5_BFE_667_F_40_C3_A469_34560417727_F
upload image sites
Edited by: A-MAC on 09/25/2017 - 22:37
A-MAC
Yes. The threads are smooth.
A-MAC
I haven’t tried and I probably won’t. I don’t need to and I wouldn’t want to mess it up. Sorry.
jf_smm
Last seen: 11 hours 31 min ago
husky13 wrote:
Never mind. I found an old, I mean very old thread which explained how to dismantle the PD series.
Thanks Wink
link?
I have a friend who bounced his and already got a replacement so I’d like to try and take it apart.
Sean
A-MAC
