Test/review of Vapcell Internal Resistance Tester YR1030
10 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 17 min ago
DSC_1962
This is a meter designed to measure internal resistance in batteries.
DSC_1933 DSC_1934 DSC_1935 DSC_1936
I got the meter in a cardboard box with specifications on the back.
DSC_1961
The box contained the meter, 4 terminal probes and a manual.
DSC_1966DSC_1969
The meter is in a standard box, i.e. not a box manufactured for the meter.
DSC_1967
DSC_1968
There are two connectors, a micro usb for charging the internal battery and a usb for probe connections.
Generally I do not like using usb connectors anything but usb connections, but in this case I do like it, because it makes it very easy if I want to make my own probes. The labels above the usb connector is signal names for the connections.
DSC_1963
The probe looks home build, a usb connector with shrink wrap around.
DSC_1964DSC_1965
The other end is two pogo pins in aluminium tubes with shring wrap around.
This means I can easily make new probes if I damage the supplied ones.
The dual pogo pins means that it uses true 4 terminal measurement, there is no errors from contact or cable resistance.
DSC_1971
The display shows the battery status, resistance and voltage.
Both voltage and resistance can be in manual or auto range.
DSC_1970
There is a couple of buttons:
Power is used to turn on/off the device.
Hold/Zero is used to freeze the ohm reading or zero the ohm reading
Range R is used for manual range select on ohms (20m, 200m, 2, 20, 200, auto).
Range U is used for manual range select for volts (2V, 20V, 28V, Auto).
DSC_2453DSC_2454
In addition to this Power can be used to activate the menu system. Here Power is the enter key, Hold is the escape key and the two range buttons are up/down.
In these menus a grading system can be setup, this will make it easy to sort batteries according to voltage and internal resistance in 3 bins. It is also possible to calibrate the meter and set some preferences.
Measurements
ohm
Due to the way the meter works it do not need a battery to measure resistance, but can be used as a general milliohm meter.
Here I am testing on some resistors and comparing to a very precise meter.
The precision is very good.
volt
The same with voltage, again the precision is very good.
10ohm
The meter is using a 1000Hz sinus for measuring the resistance
The meter uses 1uA when off and 60mA when on without background light.
Tear down
DSC_2442
I had to remove four screws to open it.
DSC_2451
DSC_2444
DSC_2447
DSC_2448 DSC_2450
DSC_2449
DSC_2445
DSC_2446
Conclusion
I like this meter, it is very useful for a lot of stuff, not only batteries. It can measure the resistance in a switch, a tail spring, a atomizer and a lot of other stuff.
When used to measure resistance it will give same value as an ordinary DMM except for much better resolution at low values. On batteries the value cannot be compared to the values chargers measures, but usual the datasheet value is measured this way.
Notes
I got the meter from Vapcell.
As reference I used my Keithley DMM7510, it can do 4 terminal ohm measurement.
Internal impedance/resistance of batteries
EasyB
Last seen: 6 hours 28 min ago
So it sends a known current through the test piece (spring or switch) and measures the voltage drop? Sounds like it could be a handy device, but how does it work with measuring cell IR?
HKJ
HKJ's picture
It uses a AC current, this way it can ignore any DC value.
dmsoule
Last seen: 7 hours 58 min ago
Thank you for this review. Does anyone know where this product can be purchased? I’ve only seen it on Alibaba, with a minimum order quantity of 10 pieces.
EagleShield
Last seen: 3 days 13 hours ago
Is this the same item but not the vapcell name?
Link: https://m.aliexpress.com/item/32782073043.html
Edit the link
HKJ
HKJ's picture
Link: “https://www.aliexpress.com/item/32782073043.html”:https://www.aliexpre...
The link do not work, but if it looks the same it is probably the same.
atbglenn
atbglenn's picture
Last seen: 1 hour 50 min ago
I want to get one. Just can’t find it Sad
4Dman
https://www.aliexpress.com/item/Free-shipping-YR1030-battery-Internal-resistance-Meter-tester-for-lead-acid-lithium-nickel-cadmium-nickel-metal/32782073043.html
Model Number: YR1030
Brand: Huayurui
Edit: More than one listing for this and a large price difference.
Edit: 5 vendors on aliexpress
This one has 7 options, with option for an 18650 4 point test jig battery holder
https://www.aliexpress.com/item/YR1030-high-precision-lithium-battery-in...
EagleShield
HKJ wrote:
Link: “https://m.aliexpress.com/item/32782073043.html”:https://m.aliexpress.c...
I edited my link as well the link in the quote.
It was from the NO.1 COM store.
It looks like yours and if you click the item description he have pictures of additional probes but it’s not clear for me what’s included in that buy link.
I sent a message to the seller if the additional probes is included and if they are included it’s probably the cheapest buy if you want the extra stuff.
Let’s see what he responds.
Meanwhile waiting for a response for that seller.
This seller have the complete set for a few dollars more but with options so you know what u get.
Link: https://m.aliexpress.com/s/item/32817594188.html
Edit: put in a link for next best deal while waiting for a response from that other seller.
EagleShield
Ok. The seller have responded.
It wasn’t the full set for that price. Then he wanted 86$ for the full set.
So the changjin zhong’s store have the best price at 65$ for the full set.
