Emisar D1 (XP-L HI NW) color and output measurements
12 posts / 0 new
maukka
maukka's picture
Last seen: 21 hours 5 min ago
Quite busy at the moment so I’ll just let the numbers speak for themselves.
I was surprised how cool the hotspot looked on max output. Very neutral but skewed towards green on the low modes which is quite surprising considering it uses PWM. The tint shift from lowest to highest is larger than on the 219C D4. Output matches or exceed the specifications.
The battery tube is visibly lighter than the head on mine.
Here’s some point of comparison.
Edited by: maukka on 10/04/2017 - 10:32
CRX
CRX's picture
Last seen: 31 min 35 sec ago
Thanks Thumbs Up
korpzgrinda
korpzgrinda's picture
Last seen: 21 hours 20 min ago
Location: Eastern Woodlands in the Wilderness of North America
Same thing with my green version, both head and tail cap are darker.
atbglenn
atbglenn's picture
Last seen: 6 months 3 weeks ago
My green D1’s bezel and tail cap is slightly darker than the rest of the flashlight. It’s not noticeable unless you’re looking closely at it.
Boycott Nike
maukka
maukka's picture
In my opinion Emisar should have made the D1 a bit smaller and with an orange peel reflector for better every day use. The D1S will fill the thrower need anyway.
I quickly tried the D1 with d-c-fix. It lost 9% of output while throw plummeted from 44kcd to 10kcd. The beam is very nice and smooth though.
Aussi
Sorry, but did you test it with “maximum heat”?
I did test one, sure, only with my smartphone, but it didn´t step down so fast:
http://www.taschenlampen-forum.de/threads/emisar-d1.58481/page-2#post-83...
maukka
maukka's picture
All tests were done on out of the box settings (49°C).
Aussi
Okay, my ones out of the box settings was 61°C and i did put it on max.
bunnicula
Last seen: 3 months 4 days ago
Thanks for the measurements maukka!
joechina
Last seen: 22 hours 41 min ago
That much, from 440m to 200m reach?
JIGHEADWORM
I put an sst 40 in mine it gets 2400 lumen and 46 kcd but it has an ugly tint.
MAD777
MAD777's picture
Nice balance of flood & throw!
Mike
