Tactical flashlight- Outdoor LED Torch with USB Rechargeable, 3400mAh 18650 LI-ION rechargeable battery, which can work as power bank.
Features:
Fashion patent appearance design, good touch feeling ,compact sizes.
High grade air-craft aluminum body with military type III hard anodizing to protect the body.
Using CREE XP-L HD V5 LED,50000hours life time
Concealed charge and reverse charge module, can provide electric energy to the electronics which use standard USB cable
Standard USB cable charger can be incommonuse with normal mobile phone
Strong & unique hot releasing system Import electrical component with High efficiency constant currentcircuit design to extend run time. Overcharge and over discharge PCB design to protect the battery life.
Body switch easy to adjust the light mode. (Switch life time: 10000cycle)
Gold plating contact pin never rust.
Do you know what is the use of light flashlight except lighting?
We have to understand the application of light flashlight scene, the use of high-power flashlight to the extreme, then what is the use of leading flashlight?
Cosmo Technology Development Ltd. tells you the use of flashlight.
1. For outdoor sports, mountain climbing lighting, it is light and strong, waterproof and anti-damage, It is the best choice to outdoor enthusiasts for lighting.
2. For the field help: optical glass lenses and focusing system using high-tech process technology, light range, can be used as lights and lights for help.
3. As military equipment: a waterproof, explosion-proof, drop, anti-rolling characteristics, can be used as the military police escort security team essential equipment.
4. As defense weapons: with a high lumen, as a strong light strobe, can be used for security weapons.
The USB Recharge Pocket Clip Flashlight B62;Patent appearance design, compact size easy to carry; Using USA CREE XP- L HI V3 LED, and 18650 Li-ion battery. only 5.04 inches in length, B62 delivers max 900-lumen output. Safety & high efficiency circuit design, gold plating spring never rust, and mode: hide high-high-middle-low-hide low-flashing-SOS. hunting, camping, Riding and so on.
The Use Method And Precautions For The Bright Flashlight In Outdoor Operation.
With the development of bright flashlight technology, ultra-bright and bright flashlight has the characteristics of long life, reliable durability and extremely low maintenance cost.
According to the environment and scope used by the bright flashlight, it has the function of lighting, intimidation, alarm and high pressure self-defense.
Using constant pressure drive to ensure the brightness of bright flashlight, ensure the reliability, longevity and light failure of LED flashlight.
But there are a few things that consumers should pay attention to the use:
1.Do not use the battery for other purposes,other than the led flashlight;
2.Do not put the battery in the fire.
3.Do not use other batteries or other batteries to replace the original batteries.
4.Don’t touch the glass with your hand when the explosion-proof flashlight is on, so as not to burn the hand;
5.Avoid collision and fall of led light flashlight;
6.In order to avoid pollution, waste batteries should be processed according to local regulations;
7.Do not disassemble or attempt to repair the strong light flashlight,Need to send back to the factory to do a after-sales.
