Clone of On The Road M3 ~$13
259 posts / 0 new
Bernon
Last seen: 2 years 3 months ago
Anyone know if it can be used without batteries inside, powered up directly via USB? (I know it can be powered up via USB with batteries inside)
JasonWW
JasonWW's picture
Last seen: 7 hours 16 min ago
Nope, both red and green lights turn on, but no main light.
Lick
Lick's picture
Last seen: 1 week 5 days ago
Is there a 18350 version of this? Only thing keeping me getting it is the fact that I'll need to get new batteries again, and even lower mAh ones.
JasonWW
JasonWW's picture
Lick wrote:
Is there a 18350 version of this? Only thing keeping me getting it is the fact that I’ll need to get new batteries again, and even lower mAh ones.
No, and it comes with a good battery.
It looks like the newest version is a darker gray and has the name/logo printed on it.
JasonWW
JasonWW's picture
It also looks like the jaxmnve store has a new model clone light with the same UI as the M3 clone. It’s an 18650 adjustable head light with built in charging. Looks a bit like a Rofis.
Link here
Comes in either CW or NW with a 2600mah battery for $18. Not bad.
If only the 3 brightness levels were batter spaced, it would be a great light. Maybe even slap on an 18350 tube! Always room for improvement. Lol
Lick
Lick's picture
 Oh it does and comes with ramping? Wow, I'm sold on it! How many mAh does it have?
Their store is interesting, they also have a small 18650 light that has a terrible UI. Can this light actually comfortably be used on a hat? Do you know if there is a 18650 battery tube that can fit on this too?
I'll probably get one since it comes with a battery
JasonWW
JasonWW's picture
Lick wrote:
 Oh it does and comes with ramping? Wow, I’m sold on it! How many mAh does it have?
About 600 mah which is average.
The ramping is linear meaning it gets real fast at the lower levels and is tricky to stop it where you want.
The 3 preset levels are: 145, 240 and 470 lumen.
The lowest level in ramping is about 50 lumen.
So the UI is not great, but for $13 total price it is a good bargain.
You can’t convert it to 18650 because the battery tube and head are one piece.
Lick wrote:
Their store is interesting, they also have a small 18650 light that has a terrible UI. Can this light actually comfortably be used on a hat?/p>
I’ll probably get one since it comes with a battery
They have a $13 18650 light called the M8 which looks like it still has their older UI which is medium-high strobe. That really does irritate me because you have to always cycle past strobe.
They also have a $27 18650 light called the M18. I would skip that one because there are much better lights in a similar style for around the same price.
For an 18650 based light, I would look at that twisty head light. It’s only $18 and includes a generic battery. It’s got the same UI as the current M3 model. Plus it’s got the adjustable head. These bendy head type lights are typically in the $40 to $80 range from other manufacturers. $18 is by far the cheapest I’ve ever seen one.
In fact, I just ordered it along with their M1 stainless light.
Bernon
Thank you! Smile Sadly only few can work in that mode. Sad
pennzy
pennzy's picture
Last seen: 7 hours 50 min ago
Can anyone tell me which emitter color choice is closest to NW ? The 2 choices are white light and light yellow. Thanks.
Petr J.
Petr J.'s picture
My today’s fast morning test. Left WUBEN A21 APOLLO NW, right JAXMNVE M3 yellow.
pennzy
pennzy's picture
Thanks Petr J, just ordered yellow.Was afraid the cool would be blue.
Boaz
Boaz's picture
Last seen: 53 min 23 sec ago
 Is this light just a roche F6 ?
JasonWW
JasonWW's picture
Nope, completely different.
JasonWW
JasonWW's picture
vwpieces wrote:
Used a completely waterproof magnetic connector, no more Micro USB.
VW, can you expand on the charger. Did you hardwire the connector to the light or did you just slide the connector into the micro usb port and use silicone to seal it?
I was thinking of this:
It looks like you cut away the aluminum around the port to make it fit. Since the connector is steel, could you just grind the top of the connector so it will plug in or would the cable not fit to it properly?
wle
wle's picture
Last seen: 7 hours 57 min ago
folomov EDC-C3 does that – the head has the USB jack, you can take it off the body and it will run from USB.
Though the usb supply you use may limit max output..
also it is kind of expensive. but it can also function as a power bank, with a special cable that it comes with.
wle
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
JasonWW
JasonWW's picture
Link here
My review of this light is done if anyone is interested.
http://budgetlightforum.com/node/61993
pennzy
pennzy's picture
Received my Jaxmnve M3 today . Cool little light. Any suggestions as to how to unscrew the bezel . A couple of specks of dirt on the emitter and gasket I’d like to clean up. Must unscrew as they include a spare lens and o ring . Other wise all good. Warm tint. Usb charging , 16340 cell , clip and lanyard all for $13.60. Might share duty as pocket work light with my Sofirn SP10. Oh , magnetic tail cap also.
Never mind about the bezel. Got it off with a rubber band.
Jimmy_Chimichanga
Jimmy_Chimichanga's picture
Last seen: 1 year 4 months ago
JasonWW wrote:
The 3 preset levels are: 145, 240 and 470 lumen. The lowest level in ramping is about 50 lumen. So the UI is not great, but for $13 total price it is a good bargain.
I think what makes it worse is On The Road got the UI so right for their M3 & U16, it makes the jaxmnve that much worse.
I will keep mine for $9 but I wouldn’t recommend the jaxmnve over OTR’s new M3 pro.
joechina
Last seen: 1 week 2 days ago
@JasonWW
Mod from vwpieces:
Q: http://budgetlightforum.com/comment/1227006#comment-1227006
He used this cable with round connector:
Detachable Magnetic Charging Cable Lightning Type-C Micro USB 3-in-1 Charger Cable with Indicator LED Light
Tore into the USB C connector and soldered wires to the back.
https://www.amazon.com/gp/product/B074H89QSZ
JasonWW
JasonWW's picture
Ooooo, thanks for the heads up on the new M3 pro. I stopped carrying the M3 due to no built in charging. I tried the U16, but it’s too big and heavy so I carry the M3 clone.
Now I’m gonna have to get the M3 pro. Big Smile I still don’t like the press and hold on/off, but at least it’s consistent.
I could probably fit a round magnetic adapter to the M3 pro to make charging easier.
Freeme’s thread on the M3 pro.
pennzy
pennzy's picture
I saw the M3 pro for $15 yesterday from one of the affiliates.
Edit: oops, was the U16 that was $15.
JasonWW
JasonWW's picture
That’s a real good price. I bought 2 of the U16 when they first came out for $20 each. I’ve never seen them get back down to the $20 range since then. Unfortunately, they weigh twice as much as the M3 and are bulkier as well so they are just sitting on the shelf collecting dust.
pennzy
pennzy's picture
The Jaxmnve m3 is no longer in their store.
JasonWW
JasonWW's picture
They may be out of stock at the moment.
mobydimk
mobydimk's picture
Got mine today, black with new UI. Warm white is warmer than XML2 4C, may be near 4000k. Standby current is only 0.5µA, lowest current I have seen ever.
pennzy
pennzy's picture
I like mine . Hope they bring it back.Gone from site still.
Nicolicous
Nicolicous's picture
Last seen: 5 min 2 sec ago
u got link?
Nico -.-
JasonWW
JasonWW's picture
Nicolicous wrote:
u got link?
No link, as said earlier, it’s not on their site right now. Here is a link to the store, though. Jaxmnve store
Frankly, I think I’d rather have the real OTR M3 Pro because it’s UI is so much better. It’s about $25, so roughly double what the clone costs.
pennzy
pennzy's picture
I didn’t have high expectations when I ordered mine but I find myself using it often . UI is not terrible. If you turn it off on high, it will memorize that level but if you short click it while off, you can cycle the modes while off . Thus a short press then a long would get you low. 2 short clicks then a long will get you med. A single long click will get you high. Kind of cool. Mine has perfect charging and the LVW works (no LVP).For it’s size, it puts out a decent amount of light. Run times are short though, to be expected with 16340 cell provided.I paid under $10 for it so I give it some slack.
JasonWW
JasonWW's picture
The lack of any true low mode is what bothered me most. I would use the ramping and try to click on the lowest level I could. Then leave it there. Silly
