Review of Haikelite MT07S NW Now with coupon code and Thermal image.
44 posts / 0 new
Terry White
Terry White's picture
BangGood has been kind enough to offer a coupon code for this light, I just received it a few minutes ago.
Please use this URL to get to the product page, I do not get paid or money from any sales this just lets BangGood know that people are seeing the review.  You can find the light here Haikelite MT07S and the discount is for 28% off which puts it just below $60.00 U.S. At checkout please enter this code 138f0b
This is my review of the Haikelite MT07S. The light was provided to my by BangGood in exchange for my honest opinion of this light as well as my true readings and measurements in comparison to what the manufacturer claims.
I have to be honest. This brand is totally new to me. I have not yet purchased any of their models and I have not used or even seen any of them in person.
After arrival.
Opening the box I noticed right away that it was much larger than I had expected. Not huge or even too large just bigger than I had pictured in my mind.
When I picked the light up for the first time I noticed that it was not thin cheap grade of aluminum. This is thick and heavy and very well machined.  There is nothing cheap or dinky about this light at all.
The belt clip thing I still am not sure what it is used for or how a belt comes into play but, I do know you can use it to keep anything from damaging the tripod threads. I decided to leave it off.
It comes with 2 spare O-rings and a lanyard that at least in the package I received is only… well…. What almost looks like a shoestring. There is nothing to attach it as there would be wit most any other lanyard. As I said this could only be in my sample and it is something I can live with either way, I never use a lanyard. I can attach it without anything but the string itself if I wanted to with just some old fashion knots learned in my youth.
The light opens into three sections… Let me re-word that. 3 parts. The tail cap which allows you to insert the cells for use.
The battery compartment can be unscrewed from the head with the tail cap left on or off.
At the base of the head there is a decent sized retainer holding the board into place and at least for now I have decided not to open it up just yet. I am a little pushed for time tonight and when I do open it I do not like to hurry. I will come back and add any information and photos from that.
 Same picture as the one above I just flipped the battery tube upside down so you could see both ends.
The XHP 70.2
Specifications:
Emitter: CREE XHP70.2
Material: Aluminum Alloy , HAIII Anodizing
Battery: 2x18650 / 4x18650 Recommend Sanyo 18650 GA 3500mah 18650
Reflector: Aluminum Reflector
Lens: Double Side AR coating Glass Lens
Bezel: Stainless Steel
Waterproof: IPX8
Max Output: 5000 Lumens
Max runtime: moonlight 0.2 lumens--90 days
Dimension: 175mm x 68mm x 50mm
Net weight: 470 gram
Accessories: lanyard,O rings,Tripod Mounting Screw
Brightness Modes:
Low: 200 Lumens                                      30 hours
Medium I: 550 Lumens                             11 hours
Medium II: 1300 Lumens;                        270 minutes
High: 2300 Lumens                                  150 minutes
Hidden Turbo:5000~5500 Lumens    90 minutes (double click at any time)
Double click again:Strobe
Hidden Moonlight:2 Lumens  45 days (In off status A long click for 2 seconds to access moonlight. )
Thermal control Remove / Activation:MT07S comes with thermal control by default. If you want to remove thermal step-down , turn the moonlight mode on first and press the switch for 3 seconds to remove thermal control function. When you see a signal flash, it means the thermal control function has been removed, and MT07S will have no step down any more.
The thermal control function will recover when you cut off the power supply.
User Interface:
single click on; single click off
Long click to change modes ; Double click to Turbo ; Double click again to Strobe ;
With last mode memory
In off status a long click for 2 seconds to access moonlight mode ; another long click for 3 seconds to remove thermal control. Cut off the battery power to recover thermal control.
Lockout Function:
A single click followed by long click to lockout the switch. Repeat to unlock.
Power indication light:  (LED indicator under the metal switch button)
100%~50% Blue led on
50%~9% Blue led flashes
Blow 9% Red led flashes
My results:
I use my own lumen testing gear that has been calibrated and is continually updated and re-calibrated as needed. It is +/- 5% accuracy on the last 10 lights tested.
Using 4 30q cells matched as close as I could for resistance and all were purchased in the last two months.
Moonlight   .17 lumen
Low              232 lumen
Mid1             619 lumen
Mid2             1354 lumen
High              2300 lumen
Turbo           4515 lumen
That turbo output is correct for the NW version of this light.
I am actually kind of shocked as well as pleased. This is the first light in a long time that hit the numbers that close to what is claimed. I checked all levels twice and all are correct according to my equipment. My lumen tube has been calibrated using more known light sources now than I even keep up with so it is usually dead on and will tell on any company adding lumen.
Nice job Haiklite. I look forward to the model I have requested next.
Low 70 yards
Turbo same distance
Low 200 yards
Turbo same distance
My thoughts and remarks:
If you are expecting a small pocket sized light then you are in for a shock. This is by far not the largest light I’ve owned or tested but it is by no means a small light.
The best part of that is that the machining is excellent. For those of you that may not know the better stock you have to work with and larger thicker tolerances the better product you will turn out. Very tiny thin designs are much harder to machine and keep the quality up. Thin means more corssthreading potential and nothing to help when things heat up.
The knurling is just enough to keep a very good grip but not so much that it is uncomfortable.
The fins do their job very well, the light never became uncomfortable to hold from heat and I really pushed it very hard.
This light has plenty of metal to take the heat of the 4500 lumen output. I kept it working very hard on high and turbo for over an hour and a half and it was still comfortable to hold.
Adding a smooth reflector in this light is a home run. I knew the Cree XHP 70.2 could put out the light but even it need help throwing. The reflector took care of that with ease.
I hate the weather would not allow me to see just how far I could reach out in real life on camera video. We can all do the math and see what distance it should make. I like seeing how far it will go. First clear night, I will edit the video with added beam shots.
I knew very little about this company or this light when it arrived. I honestly did not think it would perform up to what was claimed.
When I am wrong I say I am. I was defiantly wrong about the MTO7S’s performance. I had read some very bad comments and remarks so I was already for the light to fail.
I loved being wrong.
I would like to see them add a case of some sort. This is a large light and really should be in a padded case when stored.
It would like to see the U.I. for Turbo and Strobe separated. What if I need strobe first. I still have to go through turbo to get to strobe. You need to be able to get to strobe right away from any mode or level you are in. This would be a simple change.  Some users may like or want it the way it is but when I want or need strobe I want to get to it fast. Same for turbo when I need it I want it right away. The turbo double click is great but, if I am in high and I need strobe I have to double click twice. The first takes me to turbo the next to strobe.
I am still not sure what a belt claw is or what it does.
Lastly after looking through some online photos of the light it seems my lanyard was just missing some parts. Like I mentioned before I am sure this was isolated, it is just how may sample was when it arrived.
In closing:
I can honestly tell you that Haikelite has earned a new fan today. All the claims were pretty much dead on. Lumen output was just as stated. It throws extremely well, I am sorry I could not show just how well because of the rain.
I can honestly recommend to anyone interested in this light it is easily worth the selling price, worth a bit more compared to others like it.
I have already requested another Haikelite for my next review. I really hope it is decided to send it to me.
Feel free to ask any questions…. I work a lot but I will answer as fast as I possibly can.
The video turned out pretty good considering the weather, if the footage is useful to you please take time to click like and maybe even subscribe.
Terry White
Skype terrywhite1@live.com
Edited by: Terry White on 10/10/2017 - 05:59
sp5it
sp5it's picture
Last seen: 10 min 57 sec ago
Does it have dent under mcpcb like MT01 had?
Mike
Think of how stupid the average person is, and realize half of them are stupider than that. George Carlin
 Anyone offended by my signature please fill Complaint Form. Thank you.
Terry White
None that I can see.
sp5it wrote:
Does it have dent under mcpcb like MT01 had? Mike
Terry White
sp5it
sp5it's picture
Did you remove led to verify that?
MIke
Terry White
No... I didn't see a need to remove it. So far it works perfectly.
sp5it wrote:
Did you remove led to verify that? MIke
Terry White
sp5it
sp5it's picture
So you do not know if there is a dent under a mcpcb.
Be aware guys. 2 MT01 dies because of that:
So I wonder how led shelf look like in MT07
Nicolicous
Nicolicous's picture
Last seen: 5 hours 9 min ago
you can fill the center with solder blob to let heat transfer to the pill.
Nico -.-
Terry White
How is the dent or hole... almost looks like a hole kill the light?
Terry White
sp5it
sp5it's picture
Solder blob to anodised aluminium? Not easy task.
Hole is 1mm deep, no thermal paste, rough surface with deep turning tool marks.
I wonder if in MT07 there is improvement or not.
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 hour 23 min ago
Terry White wrote:
How is the dent or hole… almost looks like a hole kill the light?
Fries the LED due to poor heat transfer.
I keep this stuff handy….
KB1428 “Live Life WOT
hIKARInoob
hIKARInoob's picture
Last seen: 2 min 4 sec ago
^^^ It’s also possible that the “dent” is like a solder splatter on the led board resulting in very poor contact with the shelf. I can see something close to the positive wire that could be a solder splatter. This is much worse than the hole in the middle I think.
KawiBoy1428
The hole from the rough pass drill, the rough surface during the facing of the MCPCB mounting surface and zero thermal grease, WOW! Facepalm
3 strikes your out! Big Smile
Terry White
Yeah I knew how or should say what the hole or indentation came from.
I'm wondering why that one is as large as it looks to be.  And all that I have had a chance to see have had thermal grease.
Better looking silicone than in most I've seen though lol.
Either way it is an entirely different light.
When I go back to work Monday night I will put it in front of the thermal gun. See if I can get a look where the heat is transferring to. Provided there is time. It may take a couple of days depending on what is down when I go in.
Terry White
Tally-ho
Tally-ho's picture
Last seen: 2 days 17 hours ago
Thanks for the heads up…I just checked my MT01 and same machining fail. Facepalm
hIKARInoob
Isn’t that hole there on purpose for stabilisation during machining? So all samples have that, and it’s not a machining defect?
unknown00101
Last seen: 1 month 1 week ago
It’s a defect in the sense that it shouldn’t be there if properly made. I don’t know the exact processes, but the proper set of steps results in a flat shelf allowing the entirety of the led mcpcb to make contact with the shelf.
Having some 25% of the mcpcb not making contact in the most critical area of a heavily driven LED is Not good.
hIKARInoob
Yes true. I do wonder whether this centre hole is present in Haikelite’s CAD drawings. Perhaps it’s not there at all, and the manufacturer just did this for production reasons without consulting Haikelite…
Terry White
Almost looks like when it started it was too deep then corrected quickly.
Surely someone is not turning all these manually.
Terry White
adam7027
Last seen: 8 hours 49 min ago
Thank you for sharing this review. Based on another feedbacks, I was also a bit worried, but I still can’t wait to get my sample (hopefully only in a few days).
Terry White
adam7027 wrote:
Thank you for sharing this review. Based on another feedbacks, I was also a bit worried, but I still can't wait to get my sample (hopefully only in a few days).
I have to admit that this light really surprised me.
I expected from the research I had done prior to it's arrival that this was going to be a tough review.
Once I noticed that I had to search for negative things to point out I had a blast just playing with the light.
Is it the greatest light on earth.... Of course not... But is it worth the price for what you get (at least for sure what my sample is)? Yes...
It totally is and I would purchase this light. With the sales and coupon codes making the price even less I may stock up a few.
I have several co-workers that see lights I have from time to time during testing and they almost always ask where to get one. Once they find they need to order online they shy away. LOL if I have some on hand that I got a good price on... Well I think you can see my point.
I am glad you got something from the information. I can promise you that at least my sample so far is trouble free and is as advertised in lumen count.
Terry White
Terry White
hIKARInoob wrote:
unknown00101 wrote:
hIKARInoob wrote:
Isn't that hole there on purpose for stabilisation during machining? So all samples have that, and it's not a machining defect?
It's a defect in the sense that it shouldn't be there if properly made. I don't know the exact processes, but the proper set of steps results in a flat shelf allowing the entirety of the led mcpcb to make contact with the shelf. Having some 25% of the mcpcb not making contact in the most critical area of a heavily driven LED is Not good.
Yes true. I do wonder whether this centre hole is present in Haikelite's CAD drawings. Perhaps it's not there at all, and the manufacturer just did this for production reasons without consulting Haikelite...
This is a good point... I got my sample from BangGood and I have not taken the head assembly apart. The LED is almost perfectly centered and unless I have a need or reason I like to leave them perfectly centered.
Yeah if I sit here for awhile I will get it just as centered. It may take a few minutes or it may take half a hour.
I want to put the head in front of the Fluke thermal gun we have in the shop at work before I do anything. Once it warms up a bit I should be able to easily see where the heat is and if it is stationary or if the pill and fins are doing what they are intended to do.
They will not allow me to use one of my own SD cards to record the images but I will try taking photos of the screen. This is also not allowed but I have been there awhile and most of the guys in the shop like watching when I do this so I can probably get a picture or two with my mobile phone.
I don't have any direct contact with Haikelite at the moment.. I may remedy that soon as well.
If anyone does this is a good question. It is possible they do not know.
Terry White
Terry White
KawiBoy1428 wrote:
Fries the LED due to poor heat transfer. p. I keep this stuff handy.... p. !{width:80%}https://s19.postimg.org/kfz52xloz/IMG_20160403_163139.jpg![/quote]
Gotta know lol... Where did ya get it.. I have looked in spare time for that for several weeks lol for a light I am going to call Frankenstein if I ever get the time to complete it.
Either way I would love to keep a couple of tubes on hand.
Terry White
KawiBoy1428
Terry White wrote:
KawiBoy1428 wrote:
Fries the LED due to poor heat transfer. p. I keep this stuff handy…. p. !{width:80%}https://s19.postimg.org/kfz52xloz/IMG_20160403_163139.jpg!
Gotta know lol… Where did ya get it.. I have looked in spare time for that for several weeks lol for a light I am going to call Frankenstein if I ever get the time to complete it.
I have been using it for about 4 years to fill minor F-ups in Aluminum, it machines really well once fully cured, so I tried it with and in my lights…as a potting material,body filler and to epoxy battery tubes together and such.
Amazon…. https://www.amazon.com/Hy-Poxy-H-259-Alumfast-Aluminum-Filled/dp/B001HCR4W2
Here is a pretty Extreme Test, I guess..
http://budgetlightforum.com/node/47292
Terry White
Thank you very much. I just placed my order... I remember my dad using it and it always worked well.
Thanks again...
Terry White
Terry White
This is after 10 minutes on turbo. You can see concentrations at the head but the heat is moving out and away... Temp is set to Fahrenheit.
The best pary I totally missed. 7 to 8 minites after turning the light off no part of it was avove 90 degrees F
Terry White
Terry White
I have several from when I first turned it on up to that shot above..
I will try to post the others when I get home...
Terry White
Box
Last seen: 1 month 4 weeks ago
Only 46 Celsius after ten minutes is pretty good
firedome
awesome thermal images! Big Smile
We can easily forgive a child who is afraid of the dark; the real tragedy of life is when men are afraid of the light --- Plato
sp5it
sp5it's picture
Pity, that those images proves nothing about hole under mcpcb I asked.
Mike
DENGOH
DENGOH's picture
Hi Terry, may I know what was the highest temperature?
The picture you shows seems to have abrupt temperature change from the highest temperature to surrounding. Couldn’t that mean heat get trapped?
cool i'll see you when you get there
Terry White
No it proves nothing about a totally different light that I have neither used, held,touched, or tested.
It does prove without a doubt that at this light's highest setting after 10 minutes it is controlling the heat very well.
This thread is the MT07S. The first and only light from this brand I've tested and agreed to review.
I only post or discuss what I can prove about the product I was asked to evaluate.
It makes no difference to me if they had prior issues with other lights... What company doesn't?
This is a young company and mass producing lights of this type is no easy task.
I can not and will not speak any further on the matter of any light I have not tested myself.
The bottom line this is a review of my findings for model MT07S and it has easily shown to be a solid performer that does everything the manufacturer claims it will do.
I have proven that in every way I have available  to me including getting permission to use a $4000.00 Fluke thermal imaging gun fully calibrated.
This light is a total pass and a bargin with the discount provided.
I can find nothing wrong with it at all
That reminds me... I discovered you can go to turbo from any setting even off. Just double click.
For those interested in this light. My honest and true 30 year experienced opinion of the MT07S is if you like it...  Buyit. It is worth the retail price and worth more than the discounted price.
Thank you all for reading and support.
Terry White
