Test/review of Charger Folomov A4
10 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 hours 43 min ago
Charger Folomov A4
DSC_1454
DSC_1456DSC_1455
Folomov is new on the charger market and has started with some fairly powerful chargers. This is a four slot charger that can charge with up to 3A, but also charge with low current for small cells.
DSC_1362 DSC_1363 DSC_1364 DSC_1365
The cardboard box lists lot of specifications, battery types and features.
DSC_1452
The box contains the charger, a power supply and a instruction sheet.
DSC_1457
The charger has one 12V input barrel connector.
DSC_1459
The user interface has four buttons, one for each slot and large display.
After putting a battery in a slot the current will flash for some time.
When flashing a short press on the slot button will change current in this sequence 250-500-1000-2000-3000-2000-500-250, holding down the button will change chemistry between LiIon and LiFePO4.
The user interface is slightly slow, i.e. a two fast presses is not detected.
I have one complain about the interface: When a current is changed for one channel, the adjustment time for that channel is extended, but not for the other channels, i.e. with 4 batteries in the charger you do not have time to adjust each slot in sequence, before the last slot starts. The solution is to put one battery in at a time and select current for it, then the next.
DSC_1652
The display is fairly simple, each slot has a large animated (when charging) battery symbol, a chemistry text, a charge percent, the voltage and charge current.
DSC_1653
Display during charge, the bottom line will change between current and voltage.
DSC_1461DSC_1462
The slots uses the usual construction and works well. They can handle batteries from 29mm to 69.9mm long. The new 70mm cells are a very tight fit and very long protection 18650 will not fit.
supportedBatteryTypes
supportedBatterySizes
DSC_2326DSC_2313DSC_2327DSC_2315
DSC_2328DSC_2329DSC_2659DSC_2658
DSC_2316DSC_2319DSC_2317DSC_2318
The charger can nearly handle 70 mm long batteries, there is no problems with flat top cells.
Measurements
  • Charger will charge a LiIon with 0.4mA when full.
  • Charger will discharge a LiIon with 0.25mA when not powered.
  • Charger will discharge a NiMH with 0.05mA when not powered.
  • Below 0.7V the charger will show “Er” and charge with about 3mA
  • Between 0.8V and 2V NiMH is assumed
  • Above 2.0V LiIon is assumed
  • Voltmeter is within 0.02V in the full range.
  • Voltmeter will stop updating when charging is stopped.
  • Charger will restart if battery voltage drops to about 3.9V.
  • Charger will restart if battery is removed or power is cycled.
  • Power consumption when idle is 1.05 watt
4.2V LiIon charging
Charge current can be selected from 250mA, 500mA, 1000mA, 2000mA and slot #1 and #4 can do 3000mA, but not when the charger is filled.
Folomov%20A4%201A%20%28SA18650-33%29%20%231
A nice CC/CV voltage charge curve with termination at about 100mA
Folomov%20A4%201A%20%28SA18650-33%29%20%232
Folomov%20A4%201A%20%28SA18650-33%29%20%233
Folomov%20A4%201A%20%28SA18650-33%29%20%234
The other 3 channel is the same.
Folomov%20A4%201A%20%28SA18650-26%29%20%231
Folomov%20A4%201A%20%28PA18650-31%29%20%231
The two other capacities works fine.
Folomov%20A4%201A%20%28BE18650-26%29%20%231
This fairly old cell is handled nicely at 1A charge current.
Folomov%20A4%200.25A%20%28SA18650-33%29%20%231
Charging with 0.25A also works fine.
Folomov%20A4%200.5A%20%28AW18350-IMR%29%20%231
Folomov%20A4%200.5A%20%28KP14500-08%29%20%231
These two smaller cells I charged at 0.5A and it worked fine.
Folomov%20A4%202A%20%28SA18650-33%29%20%232
A 2A charge, termination current is about the same. The charger do not have perfect control of the CV phase, but it works fine.
Folomov%20A4%203A%20%28AWT18650-30%29%20%231
3A works the same way
Folomov%20A4%202A%20%284xSA18650-33%29
Four cells at 2A
Folomov%20A4%202A%2012V%20%284xAWT18650-30%29
When charging with a total current of 8A it needs nearly 4A from the 12V input.
Temp4666
M1: 46,0°C, M2: 47,5°C, M3: 47,3°C, M4: 43,1°C, M5: 46,7°C, HS1: 66,8°C
Temp4667
M1: 61,8°C, HS1: 64,0°C
PoweronLiIon
The charger takes about 10 seconds to start.
PoweronLiIon3A
If the button is pressed during that time the current is changed and the time is extended.
3.6V LiIon charging (LiFePO4)
Folomov%20A4%200.5A%20%28SO14500-LiFePO4%29%20%231
Folomov%20A4%201A%20%2818650-LiFePO4%29%20%231
The LiFePO4 charge curves looks good.
NiMH charging
Charge current can be selected from 250mA, 500mA, 1000mA, 2000mA and for slot #1 and #4 3000mA
Folomov%20A4%201A%20%28eneloop%29%20%231
This is a voltage termination with no top-off charge and no trickle charge. This means the batteries will not be filled completely.
Folomov%20A4%201A%20%28eneloop%29%20%232
Folomov%20A4%201A%20%28eneloop%29%20%233
Folomov%20A4%201A%20%28eneloop%29%20%234
The other slots is the same.
Folomov%20A4%201A%20%28eneloopPro%29%20%231
Folomov%20A4%201A%20%28powerex%29%20%231
The two high capacity cells works the same way.
Folomov%20A4%200.25A%20%28eneloop%29%20%231
The voltage termination also works fine at 0.25A.
Folomov%20A4%200.5A%20%28eneloopAAA%29%20%231
Here with an AAA cell.
Folomov%20A4%201A%20full%20%28eneloop%29%20%231
Voltage termination gives fast detection of a full cell.
Folomov%20A4%203A%20%28eneloop%29%20%231
Fast charging at 3A.
Folomov%20A4%202A%2B3A%20%284xeneloop%29
With four cells the charger can do two cell at 2A and two at 3A.
Folomov%20A4%202A%2B3A%2012V%20%284xeneloop%29
For charging NiMH at maximum speed it needs about 2.5A from 12V, it is easy to see on the input current when the 3A charge is finished.
Temp4674
M1: 66,7°C, M2: 62,5°C, M3: 62,1°C, M4: 64,9°C, M5: 55,4°C, M6: 63,3°C, HS1: 92,2°C
Temp4675
M1: 62,8°C, M2: 48,7°C, HS1: 66,6°C
PoweronNiMH
NiMH also needs about 10 seconds to start, the charger turns current off to measure voltage.
PoweronNiMH3A
When adjusting the current the wait period is extended.
ChargingNiMH
A closer look at the pauses, they are 0.1sec every second.
Testing with 2830 volt and 4242 volt between mains and low volt side, did not show any safety problems.
Conclusion
This charger may look a bit simple, but it has what is needed for charging two types of LiIon and NiMH and it can do it slow or fast, depending on what is needed. I like the simplicity of the user interface, but would have liked it a bit more responsive and a longer timeout when using it.
Because it terminates NiMH on voltage a one or two hour top-off charge would have been nice.
I will rate it as a good charger.
Notes
The charger was supplied by a Folomov for review.
Pete7874
Pete7874's picture
Last seen: 10 hours 36 min ago
Thanks for the review.
Capability aside, is it safe/advisable to charge AA Eneloops at 3A?
HKJ
HKJ's picture
Safe: Yes
Advisable: No
You can get chargers with higher charge current from brands like Duracell and Varta
The high speed is fine if you need the cell charged asap, but not if you want a long life from the cell.
Box
Last seen: 4 days 20 hours ago
Thanks for the review HKJ! Looks like good charger. Another to the buy list.
Flashy Mike
Flashy Mike's picture
Last seen: 11 hours 20 min ago
Thanks for the review!
I don’t understand why manufacturers don’t give their slots the additional millimeter to make it fit all cells.
Pete7874
Pete7874's picture
These large current fluctuations near the end of the charging cycle, what is causing them? And are they in any way harmful to the cell?
HKJ
HKJ's picture
The control loop* is probably not designed perfectly, making the regulation a bit too lively. As long as the current mostly stays below maximum current and slowly drops it will not harm the battery.
The control loop is the part of the circuit that takes the measured current and use it to increase/decrease the charge current. The way to increase/decrease charge current may be to change a pwm oscillator (or it might be something else).
Speed4goal
Last seen: 2 weeks 6 days ago
Thanks for the review this charger is on sale at one for 25. I picked it up and it’s 2 cell sibling it’s on sale for 15 dollars. Can’t beat it for 15 2 cells at 2 amps or 1 at 3 amp. I’ve had it about 2mobths now. And it’s been a great charger. I like how it starts at 250mah. If you have quick fingers you can put all 4 cells in and adjust the current. But it’s not a deal breaker for me. If I don’t need the cells quickly which I had don’t I have piles and piles of cells. I’ll just let it charge at 250. Sometimes 500 if I’m hard on my cells on discharge. Why be hard charging them.
But I’ve used the 2 amp and 3 amp charging just to try it out and it works great. Only did the 3 amp on some 26650s
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
Parametrek
Parametrek's picture
Last seen: 1 week 2 days ago
Has anyone had issue with their A4? Ozythemandias found an interesting glitch where at first one bay appeared to charge extremely fast. And then later the bay started acting like a battery was always in it.
Try the largest, fastest, most flexible flashlight search engine: parametrek.com
40 brands, 1936 models and still growing!
NEW: sleeping pad search engine, battery database
Speed4goal
I’ve had that happen to mine once but not exactly like that. And it was exactly in slot 3 as well. Also real quick if you touch the charger or turn a battery while it’s charging and sometimes removing one battery while the other 3 are charging the voltages and percentages jump up across all the batteries. Try it sometime.but it always terminates correctly with my dmm. 4.19 everytime. I don’t know what the refresh rate is on it. Battery was done charging, took it out to put another in the screen was back to the regular screen. When I inserted the new battery it went straight to full. When I knew it was completely dead. I took it back out and unplugged it. Plugged it back in and havnt had it happen since. I will say though I’ve seen some other reviews say this. If you use the 2 amp charging on all 4 slots it makes a lot of heat. It will start fading the screen display while it charges until it cools back off. IDK if it will become permanent with repeated use. I’ve seen one imr review where the screen failed I believe or another battery site. I see it with mine. If you do 2 amps on all 4 slots put a fan on the charger where. It gets a decent amount of airflow. It really needs a fan or a more expensive screen that can take the heat. Even my a2 has the screen fade a 2 amp charging on both channels the display gets really hot. The batteries don’t get dangerously hot but the charger gets up there. All in all with that said I’d buy the charger Again no hesitating, my a4 and my opus run 24 hours a day. I usually limit my charging to 1 amp. That’s all that’s needed mostly. I have enough batteries I don’t need to really charge at 2 amps. Most of the time.
