Review Olight M2R in NW! Added beamshots & comments. Photo heavy!
49 posts / 0 new
mattlward
mattlward's picture
Last seen: 17 hours 48 min ago
Let me get the required stuff out of the way…
This light was provided for review by The OlightStore.com and can be purchased at the aforementioned link.
Manufacturers specs:
GENERAL DATA
Beam Distance (ft) 682
Beam Distance (m) 208
Max. Performance (lumens) 1500
Charge type Magnetic USB charge base
Compatible Batteries 1 × 18650 or 2 x CR123A
Light Intensity (candela) 10880
Light Form Compact/tight focused hotspot. Ultimate beam distance.
Lens / Reflector Type Smooth reflector (central area and flood area)
Mode Operation Dual Switch
Form/Size Factor Medium size (Permanent Marker)
Series Series M (Tactical, Military)
Unique Characteristics
High voltage 3500mAh 18650 lithium ion battery included, delivering a maximum output of 1,500 lumens.
Comfortable and firm grip with ergonomic knurling allowing the user to operate the tail switch naturally without even looking at it due to it’s smooth, barrier-less tail cap.
Aside from momentary or constant turbo from the standard operation mode, the light also features an enhanced tactical mode for one click instant access to strobe.
Compatible with all conventional 18650 batteries.
Rechargeable through the included 5V 750mAh OLIGHT USB magnetic charging cable or the optional OLIGHT Micro-Dok (II or above).
LIGHTING LEVELS
LEVEL 1 (lumens) 1500
Run-time LEVEL 1
1050 lumens (~700lm);
Run-time Level1 (3m) + 1h50m (700 lumens).
LEVEL 2 (lumens) 700
Run-time LEVEL 2 2h.
2h.
LEVEL 3 (lumens) 250
Run-time LEVEL 3 6h15m.
6h15m.
LEVEL 4 (lumens) 60
Run-time LEVEL 4 20h.
LEVEL 5 (lumens) 15
Run-time LEVEL 5 70h.
LEVEL 6 (lumens) 1
Run-time LEVEL 6 25 days.
Strobe Yes
SOS / BEACON No
TECHNICAL CHARACTERISTICS
Waterproof IPX8
Weight (g / oz) 149 / 5.26
Length (mm / in) 130 / 5.12
Head Diameter (mm / in) 25.4 / 1.00
Body Diameter (mm / in) 24.4 / 0.96
Led Cree XPH 35 HD
Packaging Carton box
Use Standard hotspot diameter with impressive distance. The perfect all-around beam profile.
Package Contents
Olight M2R flashlight x 1
Double Direction Stainless Steel Pocket Clip x 1
10A HDC 3500mAh 18650 Battery x 1
USB Magnetic Charging Cable x 1
Lanyard x 1
Holster x 1
user manual x 1
Alright, lets see what it looks like!
So, typical Olight box. Good stats on the back.
box_frontbox_back
Notice the yellow plastic cover? Remove the battery protection tab and basic how to change from standard to tactical mode.
basicsbox_inside1
The light is a very attractive light, pretty typical of Olight. It is fairly long, not crazy about that. It has a very good solid pocket clip and a blue bezel with mild crenelations. Notice the tail switch??? This tail switch serves many purposes, depending upon mode group selected. In standard mode a half press gets momentary turbo and full press locks turbo. In tactical mode a half press gets turbo and a full press get strobe.
frontrear
The LED? XHP35-HD in neutral white! Well centered within an orange peel reflector.
led
It is a big light, this is an 18650 Zebralight for comparison. Maybe an unfair comparison since the Zebra does not have a tail switch and is one of the most compact 18650 lights out there, I will add a couple more for comparison.
size
Lets look at the tail cap in more detail. This tail cap is also the interface to the normal Olight magnetic charging system. There appears to possibly be some electronics in the tail cap, but not 100% certain of that. The center and the outside silver ring to appear to expose battery voltage. I am not sure if it is a direct path to the battery or if there is something that eliminates the possibility of a full current short. I am trying to figure out how to test that in a non-distructive manner. Maybe a light gauge wire that will act as a fuse if there is full current. Also notice that batt+ goes toward the tail cap of the light! I did a reversed battery test with no ill effects. It also works fine with any 18650 that I placed into it!
tailcaptailcap_inside
On to the battery tube. I noticed right away that the battery tube is sleeved. I was not able to test current draw, because I was not able to jumper and activate turbo. I will try this again. I assume that this is so there will be a current path to the tail switch when the side switch is off. Also, notice the very well machined square threads at the tail! They should last forever. Also note the light has 2 springs on the batt+ to carry more current without failing. There are also dual springs in the head.
tube_endthreads
This light comes with a few extras such as a “High Drain” protected 3500mAh cell, magnetic USB charging cable (750mAh), basic lanyard and a really nice holster! The battery is very long, any cell you own should fit and work. This light will charge any 18650 internally as well. The Samsung 30Q flat top worked very well in the light. Please keep in mind that Olight does recommend a protected cell with this light.
batt_sizeholster_sidekit1
Beamshots in order from low to 1500 lumens!
M2R_lowM2R_med1M2R_med2M2R_highM2R_1500
Closing observations and personal thoughts
This light is a large deviation from the normal Olight fare, with the new tail switch and new operating modes.
The addition of the tail switch allows for the light to be gun mounted with easy access to the switch during operation. If the light is in standard mode, you can have momentary or locked on access to 1000 lumens. If in tactical mode, you have access to momentary 1500 lumens or locked on strobe. The side switch operates as expected in either mode. This light has electronic lockout via the side switch, from off hold the switch until moon comes on and goes back off. To unlock it, hold the side switch until moon comes back on. While in lockout the tail switch is also locked out. The side switch lights up red to indicate lockout when either switch is pressed. If the light is on and the tail switch is pressed and released the light will revert to off, so the tail switch will not provide a bump in output and return on the last used level. The light does have mode memory and will remember moonlight mode. Memory works regardless of how the light is turned off. Memory is cleared if the battery is removed.
Pros:
Very bright.
Standard cells will work with charging system.
Charging system terminates as it should.
Great hand feel.
Easy to find tail switch and side switch.
Moonlight mode memory.
Electronic lockout.
Cons:
Tail switch locked out on a tactical light
Tail switch half press and release turns off light, would be nice for a bright bump returning to last mode.
Battery goes in backwards, at least compared to many tube lights.
Physically very long for single 18650 light.
I like it. For a first generation tail switch tactical it is a good light. I would like to possibly see some consideration or discussion around locking out the tail switch. I personally think this is a bad move for a tactical light. The tail switch is recessed and tough enough that I do not think it could be accidentally locked on. I would like to see a remote switch for this light, would be a great light for a shotgun or AR. I love the new clip when it is mounted on the tail of the light, not so much when mounted forward. It provides and extremely deep pocket carry when mounted to the rear. I would expect this light to be very durable as Olight is good at making tough lights.
So, good first generation tactical light! Generation 2 should even be better and I am glad to see them venturing into this market.
Thanks for looking!
Matt
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
Edited by: mattlward on 10/22/2017 - 23:46
stephenk
stephenk's picture
Last seen: 1 month 4 days ago
Thanks for the review. Interested in the UI and how long it lasts until the inevitable step down!
mattlward
mattlward's picture
UI is very Olight with regards to the side switch… Tail switch is a little different. Step down is at 3 minutes, but it can be bumped back up.
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
jimahi
Last seen: 15 hours 22 min ago
Did Olight include a tail switch memory mode in the version you reviewed? Or does the tail switch only let you turn on the light in turbo / strobe?
Seems Olight had a prototype version that had a memory mode for the tail switch… but the other info I’ve seen says the memory mode did not make it to the final production model.
mattlward
mattlward's picture
The tail switch is only on or off or momentary. The light does have memory and does remember moonlight mode!
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
maukka
maukka's picture
Last seen: 3 hours 10 min ago
You can test the tailcap current safely by using a protected battery with over current protection below your DMM’s max current and then shorting the contacts with your meter. Only a couple milliamps flow, so the M2R is safe.
EyeballFryer
Last seen: 3 months 5 days ago
Can you pass the word to olightstore.com to fix their reflector info? They say it’s smooth, but your pics show orange peel.
jimahi
Does the memory work with the tail switch? Or does the tail switch only turn the light on in turbo?
stephenk
stephenk's picture
3 minutes is pretty good considering the output!
Trevi_lux
Trevi_lux's picture
Last seen: 7 months 1 week ago
Is great, rechargeable any 18650?
What is you opinion about recharge inside not protected?
Deputy Dog
Deputy Dog's picture
Last seen: 2 hours 34 min ago
Anything about the magnetic tactical pressure switch, promised at the shot show?
mattlward
mattlward's picture
No tail switch memory, turbo or strobe only. I am fine with that in this design and for the stated purpose.
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
mattlward
mattlward's picture
I am interested in that option as well and have already asked the Olight rep I work with about that option. Will update when I have an answer.
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
mattlward
mattlward's picture
Trevi_lux wrote:
Is great, rechargeable any 18650? What is you opinion about recharge inside not protected?
The charger seems to terminate at a proper voltage and only charges at a max of 750mAh. I think it would be fine for any cell, but bear in mind Olight does strongly suggest a protected cell. Given that the included cell is rated for 3500mAh, unless you deplete the first cell there should be plenty of capacity if you manage the recharge after use. I will be doing a cell test in my Lii500, likely this weekend so I do not have to leave the unit unattended.
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
mattlward
mattlward's picture
Did not catch that, sure will! I also revised the output and runtime wording for the highest level, was very confusing.
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
mattlward
mattlward's picture
One more thing to note… the tail switch does not override electronic lockout! I really wish it did, this might be considered a flaw in a tactical light!
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
Deputy Dog
Mattlward
Sure is! It would be like a gun without ammo, when you may really need it. Though I can understand not wanting accidental discharges as well. Lighting yourself up at the wrong moment could/would be bad.
mattlward
mattlward's picture
Deputy Dog, I have also decided that it is a flaw. This light will end up on an AR or a 10/22, in either case I want to know it will always turn on. I do not think that this was a good choice since the likelyhood of pocket pressing the large tail switch is likely, even less likely would be locking it on in a pocket. Maybe in a a pack with a bunch of loose crap, but the switch is not that easy to engage. I just got the light yesterday and wanted to get some info up, today is my first day of using it as an EDC, something I always do before I can honestly finish a review. I like to carry any new light for a week and really put good sound observations into my reviews.
Thanks for your thoughts!
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
Deputy Dog
mattlward
I hear ya… nothing worse than a “OH $H!T!” moment with a firearm. Facepalm
DB Custom
DB Custom's picture
Last seen: 8 hours 35 min ago
Can you establish if the inner tube is ground or not? I can see where it’d be tricky to get a tail current reading, with the e-switch, but is the body ground or positive? The cell goes in backwards, right? Curious, the many differences this light has over a standard light.
mattlward
mattlward's picture
Hey, I was able to determing that the batt+ spring and the main tube are connected when the button in the tail cap is pressed. So, it appears to be body tube positive.
Also!!! Copper DTP star! I will not tear it down any further, this is actually a nice light that could you a couple of minor things to be a great light. I am going to carry it this week and will update the review after a week or so of carry. The star appears to be glued in place.
!LED2!
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
robo819
robo819's picture
Last seen: 1 hour 18 min ago
I had mine apart to do some amperage readings for my review I am working on……the MCPCB in my sample has regular white thermal paste under it and with a side to side wiggle it popped right up when the tension was disturbed from the slight suction under it.
Click any link to see MY REVIEWS:
Maxtoch M24 Sniper / Maxtoch 2X Shooter (2016 factory dedomed) , 2X - XHP 70.2 / Maxtoch Xsword / M1 Archer *** ### ThruNite // Archer 2A V3 / Ti4T / TN4A HI / TH10 / TH20 / C2 Mini / TC12 V2 / T01 /  , neutron 2C V3 , TC20 / Catapult V6 / TC15 / TC15 CE *** ###  Olight // H2R Nova , S10R III / S30R III / H1 Nova / H1 R Nova / X7 Marauder , PL Mini ,  M2R warrior //// Orca T11 / Nitecore EC20 / BLF A6 / Custom Convoy C8 / Lixada Triple 3800LM / Lixada 1000LM / LuxStone X30 / Manker E02 / Manker E14 II /  ### Thorfire /// PF03PF04 , Upgraded PF04 , C8 , S-50 ,  VG-10 , VG25 , C8s , BL30 , TK4A  , S1 , VG15 S  , TK 18 //// ##WowTac// A4 , A1 (original) , A2 headlamp , A3 //// Acebeam L16 /// Massdrop (Lumintop) Brass EDC
cncyana
Last seen: 8 months 5 days ago
Like many of you, I am a NON-tactical user. I am not an LEO, Fire, security, etc.. Just a regular ordinary guy wanting a nice double e-switch light. I would love to see Olight add firmware to select between Tactical (instant turbo at tailcap switch) and mundane Civilian (memory mode at tailcap switch or better yet, same UI as side switch).
Life’s Questions/Answers here: http://www.answersingenesis.org/home/area/qa.asp “So then, each of us will give an account of himself to God.” Romans 14:12
DB Custom
DB Custom's picture
cncyana, that what you wish for may already be present to some degree, there is an option to change interface actions but it remains to be seen whether it suits your purpose or not. I have it on good faith that the beam profile and extended reach is quite nice. Wink
cncyana
I assume you are talking about something more than picking between momentary/constant turbo and turbo/strobe at the tailcap?
More UI flexibility should be more than possible now with better chips to handle and store the extra firmware. The next version of the upcoming Zebralight SC600 is supposedly going to have several UI groups to pick from.
jimahi
As I look through the comments on the various forums and even Olight’s website, I see several folks saying the lack of flexibility of the tail switch UI is keeping them from buying this light. It’s surprising that none of the reviews I’ve read seem to think this is a limitation.
If Olight put in a secret mode that enables the light be configured to allow the tailcap to control something other than full blast or strobe, I would think it would be in their best interest (increased sales) to let folks know about it.
Deputy Dog
jimahi
Quote:
As I look through the comments on the various forums and even Olight’s website, I see several folks saying the lack of flexibility of the tail switch UI is keeping them from buying this light. It’s surprising that none of the reviews I’ve read seem to think this is a limitation. If Olight put in a secret mode that enables the light be configured to allow the tailcap to control something other than full blast or strobe, I would think it would be in their best interest (increased sales) to let folks know about it.
I think things like UI flexibility will likely be seen in newer S, R and SR series lights, whenever they come out.
mattlward
mattlward's picture
In my review, I do not see it as a problem since the light has a tactical design. The idea is one thing, a very simple method of access to something very bright or very blinky. This light is not designed to be an S30R with a tail switch. This light is meant to be either an off hand pistol light or a rifle mounted tactical light. The tactical use is considerably different than the typical EDC use. I do suspect that we may see this physical interface appear in other platforms. It also appears that a remote tactical switch will be out for this light, Olight has not confirmed when it will be out yet.
The only “bug” I have really found so far is that the tail switch does not override electronic lockout. I think this is somewhat serious in this platform. Use in a holster or pack would suggest that one locks out the light, but in a situation requiring quick access to the light… one would have to hold the side switch first to unlock the light before it could be used tactically.
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
Deputy Dog
mattlward
I noticed you didn’t say much about the bezel. I really like the aggressive design of my M18 striker (the M1X striker has the same one). I wonder why they went away from that with this light, I could understand the M1R with milder crenelations, but, the length of this light almost demands it to be a more aggressive tool.
Your thoughts?
mattlward
mattlward's picture
Deputy Dog wrote:
mattlward
Your thoughts?
I am not sure where their thoughts are with that bezel. It looks nice, but is very mild. Personally I am not a fan of the uber defensive bezel designs, I like the more conservative Solarforce style designs. I am kinda glad they chose it since more aggressive crenelations would have increased the lights length. This is a handful light, if it were rolled in the hand and used for mass during defense it would make a dent!
I am EDC’ing it this week and trying to figure out what I really think of it. I do like it, it is a big first step toward an EDC tactical light for them. I have emailed a few of my thoughts to them and I hope to get some responses back before I finalize the review. I want to get some night shots, but have been suckered into helping with Homecoming this weekend and it looks like rain at night. I do not get out of town at night to remote locations to test lights except on the weekends and this one looks shot. May have to update with everything except beam shots this weekend. BTW very bright and not a bad beam profile at all. It has a few XHP35 artifacts in the beam, but the OP reflector really cleans it up.
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
mattlward
mattlward's picture
Deputy Dog, are you a LEO? Do you find the bezel to make a real difference in that line of work?
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
