A tactical flashlight, also known as a tactical light, is simply a flashlight for tactical tasks. Tactical flashlights are mainly used by military and law enforcement personnel. Therefore, its performance, such as high and performance, sealing performance, corrosion resistance, durability, illumination, color temperature, etc., much higher than ordinary flashlights.
2.What is the feature for the tactical flashing ligh
1.The flashlight spot must is kind of circular regular, must be very uniform, not dark and bright spots, have a relatively smooth transition zone between the central spot and the surrounding light, gradually reduce the brightness, and the center of the beam spot of a cone shape, have a certain divergence angle, generally in 15 degrees, as the use of different tactical flashlight.
The reflective bowl used for tactical flashlights is usually designed with a wrinkled reflector bowl, and the reflecting surface is like an orange peel to ensure the spot has the above characteristics.
2.The spotlight of a tactical flashlight must also be resistant to high heat.
The USB Rechargeable Flashlight G70;Fashional patent compact design body; Using CREE XP-G2 R5 LED, and 18650 lithium battery. only 6.34 inches in length, G70 delivers max 250-lumen output. Beautiful patent appearance design with compact size, and mode:high-low-flashing-SOS. Pedestrian lighting, camping, hunting and so on.
